Question about Panasonic DMR-E50 DVD Recorder
Corrupt discs If recording a program each week, after around 3 or 4 weeks halfway in to disc I get a message "bad disc please check!!!!" recording stops and unit goes into recover mode making disc unusable, small padlock is locked and can't be unlocked( Disc will still play in unit but not finalise) this has happened alot on DVD-R discs I was told it is because I take the disc in and out to many times so have tried  recording and saving on sky+ then recording them all in a continuous run leaving disc in the player this has been better, but still happens now and again, I then tried Panasonic type 2 RAM discs in a cartridge, still it happens. All disc are new and scratch/finger print free does it on cheap and top range discs. I also have a second machine that has just started to do this as well my local agent said the drive unit has gone down and needs to be changed.
  • 1 more comment
  • Gareth Walker Jan 23, 2008
    Will try then get back
  • Gareth Walker Jan 25, 2008
    Has now gone completely wont even play pre-recorded discs now.
    Think laser has gone.
    A new head is about £40
    Is it pos to change the laser head without expensive kit.
    ie: just swap it and hope for the best or does it need fine tuning?
  • Gareth Walker Dec 03, 2008
    I finally solved the problem stuck it in the bin and bought a new one thanks for the help but drive was a write off....
    Found the same model brand new in Currys Managers Clear out for £50 no leads no remote no instructions. (Still had all this stuff) bought as seen, had it 10 months now and no probs.
  • 1,003 Answers
I suggest changing media Use memoreX dvd-r and see if this helps this.
Posted on Jan 23, 2008
I have a toshiba dvd recorder D-R160SB and am trying to record from sky plus to a verbatim dvd-rw (as recomended by the manual). When i put the disk in the dvd recorder it immediately starts to format the...
Two in ten discs usually are corrupt out of the box unfortunately. Try a different brand. As for it coming out in 4:3 or 16:9 try the settings on your SKY box. This should work.
Mar 01, 2014 | Televison & Video
Error message can't record on disc
I would try to burn at a lower speed. If this doesn't work. Try to burn the cd but don't finalize it. If this goes through fine then try to finalize the cd.
Mar 17, 2009 | Computers & Internet
dear sir.
"checking disc comes up" this message is hard disk message and it's showing becoust missplase of harddisk thru yr laptop scoket if u know bout laptops u need to plug off then reconnect yr laptop harddisk otherwise contact system wonder near u.. it's help u.
Jan 01, 2009 | Computers & Internet
Disc indicates "disc full" after only a couple minutes of recordi
Brand of disk or bad laser alignment can cause this. if you have changed brands of disks go back to the others and if you have not then laser alignment is the most likely cause and can be fixed by a certified technician in this field.
Dec 26, 2008 | Philips CDR770 CD Recorder
Recording prob with my sony handycam
buy a new disc or if it is u got a bad batch of disc
Dec 03, 2008 | Sony Handycam DCR-DVD108 DVD Camcorder
LG DR 165 DVD Recorder problem
hi , how are u friend
i have problem pls can y help me
lg dr4810 afiche in lcd (please wiat )
Sep 28, 2008 | LG DR-4810 DVD Recorder
DVD+RW playback problem(s)
same prob with the shows freezing up
with a DVD+/- RW disc the amout of time keeps dropping because with every recording process the disc loses a life you can burn those disc 200 times before they become useless so the disc might be beyond the life peroid or bad
my prob is with the DVD-/+R disc tho and i figured it out the disc was bad
for the grinding noise if its hi piched its normal thats the disc spinning up to read or write speed
if that not the case something is rubbing in there and that might explaine the writting errors
the disc manurfacture dose not take resposnablity for defective disc and any loss they have caused(if the data is lost)
Aug 23, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Was recording fine then message to check disc when turned back on
Unless you've been unlucky and had two bad discs in a row its probably the camera. have you tried resetting the camera and trying again?
Jul 13, 2008 | Panasonic VDR-D100 DVD Camcorder
Wrong Disc message when trying to play a DVD
have same problem but mine has never worked. guess you get what you pay for.if anybody knows were i can get remote codes for the tv please post.
Apr 10, 2008 | TruTech PLV16320 Television
Won't Read blank disc!!
I my DVD-HR735 wont recognise any discs at times, and is getting worse. I've now discovered (out of frustration) that if I tip the front up to between 30-45 degrees, it will play all the discs it says were unreadable. I've started jamming three dvd boxes under the front of the machine when i want to play dvds.
Nov 18, 2007 | Samsung DVD-HR735 DVD Recorder/HDD...
Panasonic DMR-E50 DVD Recorder Logo
59 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
