Question about Hunter 20531 Vista Brushed Nickel Ceiling Fan
Just replaced circline bulb and the new one only lights up dimly within 2 inches of where the plug goes. any advice?
  • 4 Answers
Http://www.atlantalightbulbs.com/ecart/nw012104/BALLASTVEB82122.htm
Posted on Jun 19, 2010
I had same problem. The ballast is bad and I'm lloking to see if I can get just the ballast. I know the ballast is bad because I had an identical light kit that I hadn't installed on another light yet and used it to see if the first ballast was bad. It was. I suspect I (we) will have to get a new light kit. That kit won't be anything fancy, just something that will take a regular lamp.
Posted on Jan 22, 2010
Can I replace the VEB82122 ballast on my hunter fan with a "regular" light kit?
Use an 8 inch Circline T9 daylight LED and directly relamp fluorescent FC8T9 bulb without rewiring
Feb 18, 2017 | Hunter Dryers
I need to replace a bulb in ceiling fan.The dead bulb is a 30 Watt Slyvania #FC9T9/DSW/RS I need to know the size as no one carries it.
You should be able to use one of the following as a replacement:
S6505
FC12T9/WW
32W T9 4 Pin Base Warm White Circline Fluorescent Light Bulb
Satco
S6507
FC30/SW FC9T9/SW FCL30LEX
30W T-9 9in 4-Pin
Satco
11085
FC12T9/KB
32W -Bulb: Circline T9 -Base:4-Pin G10q Single-End -
GE
20037
FC12T9/WW/RS
32W -Bulb:Circline T9 -Base:4-Pin
Sylvania
20233
FC12T9/DSW/RP
Sylvania
391227
FC12T9/SOFT WHITE
32W -Bulb:T9 Circline -Base: 4-Pin
Philips
Dec 01, 2014 | Dryers
\1991 geo metro dim headlight pass side
in low beams or high or both?
that is caused by:
1: bad held lamp. old lamps can go dim.
swap left and right, if dim follows bulb, bingo weak bulb or wrong type bulb. buy matching blubs (same brand and P/n)
2: bad wiring to lamp. damaged wires, or connectors to same.
4: bad combo switch. (if low beams)
5: bad fuse or holder, corrosion , to either.
head lamp fuses. there are 2. left and right.
6: hackers, many hackers put in wrong lights. inspect it.
Sep 30, 2013 | 1991 Geo Metro
HP Laserjet 3330. Scanner bulb warming up doesn't go away. I have done the "solution 1" as discribte but nothing is happening. It goes like: - i put the power on, hewlett packard is flashing, the...
How does the bulb look? Is it bright or kind of dim. The bulb warming error is designed to halt use of the machine until the scanner bulb reaches the correct output level. As these are basically a flourescent tube, they will dim over time and at a certain point they will not generate enough light to enable proper scanning. If the bulb is dim, it will require replacement.
Mar 14, 2011 | Office Equipment & Supplies
When I turn on the bright lights, one headlight goes out. when I turn off the bright lights, the other headlight goes out
you may need 2 light bulbs. check real close, if they go out compltely or really dim.... if dim, you have a ground wire issue, if they go out completely the bulbs are bad.
Oct 15, 2009 | 1994 Chevrolet S-10 Blazer
Been following everyone's advice checking
I would start suspecting a DMD board
Aug 01, 2009 | Televison & Video
Dimmer light won't work.
you are using incandescent bulbs because most dimmer will not work with Fluorescent otherwise sound like a bad switch, if it new return it. They are fairly easy to replace. Hope this Helps Paul
Jun 17, 2009 | Kenmore 51840 Kitchen Hood
Motor moves 5 in" and reverses and light blinks 5 times
In the manual it says if you can hold the wall button down & door closes. You have a short in the wiring to the reciever eye. Try substituting some new bell wire in its place, or test the wires for continuity.
Jan 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
1992 Honda Accord LX Brake Light Switch Repair
Of course you can make this repair! I'm wondering about the faulty bulb that shorted out all the brake lights...not sure if that's what happened. Your brake light switch is located on the brake pedal, up above where your foot goes. It has a plug in connector which you unplug, then loosen the locknut where it attaches to the pedal.Put in the new switch, lock nut 1st, then plug it in. Note that the locknut is the adjustment point that determines when your brake lights go on. Adjust the locknut so that the brake lights go on when the pedal is depressed within 1/2 an inch (13mm)of pushing down on it. If the switch is adjusted without enough play (say 1/8 inch or less), brake lights may flicker on and off when you go over a bump.If over 1/2 inch, brake lights might go on only if great force on pedal is used (or not at all, yikes!).For good diagrams of parts check out South Bay Honda (hondapartscheap)web site. You enter the year, model, engine, and you can scroll thru tons of parts. If you have any more questions, do not hesitate to post it for me. countrycurt0
Aug 05, 2008 | 1992 Honda Accord
Hunter 20531 Vista Brushed Nickel Ceiling Fan Logo
689 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
