Question about HP Compaq ProLiant DL580 G4 (430811001) Server
Server dropping off the network
I am running into a problem where my server ocassionally drops off the Network. I an not ping in or out of the server however the server is up and running. We are on Service Pack 1. The network is Gigabit. It seems that the only way to get the server back on the network is to do a re-boot.
Do you have any Ideas?
    Novelist:
    Scholar:
  • 117 Answers
SP1 of what?
Is there any error message in the event logs?
Have you tried just disabling the NIC & re-enabling it?
Is there a second NIC onboard which you can switch to & see if it does it on that as well?
Try resetting TCP/IP with NETSH.
If all else fails, rather than spending hours on it (which presumably is expensive :), get an Intel server-grade Gb NIC (around £70 in the UK), install that & use it instead of the motherboard NICs which I'm guessing is what you're using now.
Posted on Jan 12, 2008
We have an HP Proliant G4 Server, the onboard NIC Card is does not power up when it is connected to the Network, i have checked the device manager and the BIOS setting if it is working fine which was so, i...
Have you checked firewall settings. It's possible that the Server's OS has a firewall blocking pings and\or the server is running antivirus software that has a firewall setup again blocking pings.
Feb 03, 2011 | Computers & Internet
Tip
How to Troubleshooting Network
Here you will learn network troubleshooting tips, fix tcp/ip errors, tcp/ip settings, internet connectivity errors, how to fix pc errors, lan connectivity issues, traceroute and ping commands. Whether your operating system is Windows or Linux network problems are likely to arise. Many times the network problems arisee due to improperly configured TCP/IP settings. Following is the basic checklist to identify and troubleshoot the basic networking errors.
1. First of all you should learn what stopped working server or client computer also see if the outage affecting the other computers or only one.
2. If you server stopped working you should inform the users of the server and you should start working on fixing the error.
3. If a single client computer stopped working or disconnected from the network, ask the user of that computer that what recent changes cause the server to stop working such as newly installed software or games, service packs, internet software, new hardware or any other thing.
4. Check the physical network connectivity. The most network problems arise due to the physical layers failure.
5. Check all the network cable connections. You can start at the NIC and check if the green light is blinking then check the hub and see if the computer is getting the link across the cable.
6. Get a cable tester to check the connectivity of the cables.
7. Finally start pinging the network both Windows and Linux have the PING command. You can use ping command in this way start > Run > cmd > type "ping" then IP address of the other computer
on Mar 25, 2010 | Computers & Internet
Ipsec problem in asa
Use the ping command to check the network or find whether the application server is reachable from your network. It can be a problem with the maximum segment size (MSS) for transient packets that traverse a router or PIX/ASA device, specifically TCP segments with the SYN bit set.
Jan 22, 2010 | Cisco ASA 5510 Firewall
I am on wireless network cannot hook up printer according to network magic it sees printer but does not print I have updated the driver
pls check the ip addreess of the print server
ping the ip address from your computer
by>start>run typr "cmd"
ping <ip address>
if you get reply.that means no problem in the connectivity
if it requset time out
check the cable of the print server
Nov 02, 2009 | Computers & Internet
I get kicked due to high ping what should i do?
When choosing a server try to sort the list by ping rate and go with the lowest ping you can that is offering the map and amount of players you are looking for. If you frequently get disconnected or see connection_error on your screen while playing it could be a problem with your actual internet connection dropping packets. To test that you will need to ping a well known server like google or microsoft and see what ping times you get and if any packets are lost. This can by done by clicking start -> run and typing cmd then pressing ok. In the dos box that pops up type ping -n 20 www.google.com and press enter. Significant packet loss and high ping times could mean your connection is saturated from other downloads/uploads, there is some bad cabling or network hardware somewhere, or your ISP is having some problems. If you are connected to a router or other network equipment and assuming you have a high speed connection try connecting directly to the modem provided to you and see if that helps. If the problem continues you will need to contact your internet provider for additional troubleshooting.
Mar 17, 2009 | Electronic Arts Counter-Strike: Source for...
Can't send e-mail
Check your network connection. Can you visit web pages? If not, check your network cable, modem, etc.
If your connection is good, try pinging your outgoing mail server.
If the ping fails, phone whoever maintains the server, and ask them when it will be back online.
If the ping is successful, try closing, then opening your mail client. Doublecheck the settings for outgoing server, port, encryption options, username and password.
Sep 17, 2008 | Gateway Computers & Internet
MySQL can't connect Error
Guess you are referring to this error message -
Check your username & password, and make sure that you are authorized to access the server.
If your password & username are correct, there might be a network problem that prevents you from connecting to the machine where the MySQL server is running. To make sure that they are no network failures, click on the "ping" button.
This will "Ping" the MySQL server host. If the host is available (no network failure), you will
receive a message similar to this -
Reply from 127.0.0.1: Time=0ms TTL=128
Reply from 127.0.0.1: Time=1ms TTL=128
If you don't it means there's a problem with the network.
Jul 27, 2008 | Sun MySQL
Networking problem
yup..i have a symantec antivirus..i also turn off the firewall of my computer.
May 23, 2008 | Computers & Internet
Linksys wrt300n gaming wirelless lan problem
Can I assume all the computers on the network are running the windows OS? You might want to double check that firewall is turned off PC acting as the server. Also try to ping the IP Address of the server (probably something like 192.168.1.1xx) from all the other computers on the network:
  1. Click Start -> Programs -> Accessories -> Command Prompt
  2. Type in "ping xxx" where 'xxx' is the IP of the PC acting as the server.
You can get the IP Address for your computer:
  1. Click Start -> Settings -> Control Panel -> Network
  2. Double click on the "Wireless Network Connection" (if you're connected wirelessly) or the "Local Network Connection" (if you're connected via an ethernet cable)
Hope this helps!
Feb 01, 2008 | Linksys WRT300N Wireless Router
Documents not printing
Hi How to check the print server is in the wireless network or not!! Check under the Router Setup page Router's ip address... Check if you are able to ping the Print Server Ip address....Since it the router will assign a ip address from DHCP range.. If you are able to ping the router's ip address and the print server ip address then the print server is in the Wireless LAN... Try the following steps. 1. Go to run and type "cmd" press enter 2. type ipconfig. 3. Check the range of ip address...if its 192.168.0.XX 4. Try pinging that ip address.. 5. If able to ping the router and print server.. Then the wireless network is fine... Somehow some of the printer's don't work with some of the print servers.. Check if D-link does support the printer or not!!!! for this particular model of the router...
May 30, 2007 | D-Link DP 301U (DP-301U) Print Server
HP Compaq ProLiant DL580 G4 (430811001) Server Logo
154 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
