Question about Kitchen Ranges
Hello; I have an AirKing Valecia 755 range hood. I dissambled it in order to remove a birds nest and clean. When I reasseblem and installed the hood, it now does not function. No fan or lights. I checked the wire configuration and it is ok. I visually see a fuse anywhere that may have been tripped or blown. Any Suggestions? Thank-you Stephen
  • spkl350 Nov 20, 2009
    Hello;
    The green/yellow is ground. I have it connected to the copper bare wire. Wires from the hood are green ( ground), blue ( hot) and brown (neutral) the corresponding wires from the wall are white, black and bare copper. I have is connecyed as black---Blue, White---brown and Green/yellow--bare copper. I even change the wires to be the oppsite ( i.e. Black--brown, White blue) still no change.
    Thanks
    Stephen
    Hello;
    Could the wire break or disconnect thateasily form the wall?
    I have used a multi-meter to test resistance but not volatge. How does one do this. Change the dial to volatge and the touch red probe from multi metre to hot(blk) wire from wall and blk probe from multi-meter to white(neutral) wire from wall and then see what the reading is. Sould be around 120Vac?
    Thanks
    Stephen
  • 10,865 Answers
Hello Stephen. Don't you hate it when this happens. OK. There is no fuse in the unit. Therefore, check your electrical panel and look for a tripped breaker or a blown fuse. Also, revisit the spot where the house wiring is connected to the hood. Disconnect it there and use a test light to see if you have power that far. Chances are that is where the problem is. A loose connection, or a broken wire. Good luck.
Posted on Nov 20, 2009
  • 6,927 Answers
Check to see if the green is your ground,it should be,if it is,on the ground on the hood,then switch it to either black or white wire.
  • Ronny Bennett Sr.
    Ronny Bennett Sr. Nov 20, 2009
    Is it possible that the wire is dead ?It may have come loose from where it connects in the wall,either test the voltage coming out of the wall,or disconnect it,and use a old extention cord,and hook it to the cord,and plug it in a known good plug outlet,to see if the hood will actually come on,if it does,then there is no power on that group of wires coming from the house.
How to get rid of lice on small birds
No idea of your country but a 20Second google search revealed this;
To remove lice, it is recommended to use a mild pet insecticide, such as "Nuvan." After spraying the plumage, wait for 2 - 3 minutes and then gently ruffle the feathers over a white tray or plastic sheet to collect the lice which fall from the feathers.
I found that one great way to remove lice and mites from your birds is to sprinkle Sevin Garden dust under their wings and tail, and on the back. Check the birds the next day and if there are still lice present, repeat the process, as needed. I found Sevin dust [active ingredient: Carbaryl (1-napthyl N-methylcarbamate)] equally effective in getting rid of red mites.
Avian Insect Liquidator is another way to get rid of mites, lice and other insects in the birds' environment. This all-purpose insecticide from Vetafarm contains a water-based insecticide that is harmless to birds but effective against insects.
Prevention:
Sanitize and treat the birds' environment (cages, perches, aviaries, nesting areas, etc.). Secondly, allow your birds to bathe daily. Most birds enjoy doing so and if you provide them with a shallow clean dish, they will usually be happy to bathe without encouragement. Some birds like to be misted, or even sprayed. Sprinkling Sevin dust underneath nest bowls and around nests will eliminate all kinds of insects.
Aug 06, 2017 | Birds
Thread keeps tangling on underside
Called thread nesting or bird nesting.
Install a brand new needle that is compatible with the thread and fabric you are using.
Remove the top thread totally from the machine.
ALWAYS RAISE the presser foot and rethread the top thread from the beginning.
Confirm the thread path is correct.
Retest your machine.
What causes Bird Nests Superior Threads
Birds nest under the fabric big loops of thread top side looks good...
Jul 23, 2017 | Sewing Machines
Nesting thread on bottom of fabric
This is called bird nesting or thread nesting. It occurs most often because the thread is not seated completely in the tension disk.
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning.
Verify the thread path is correct.
It also may help to use a brand new needle.
Jul 19, 2017 | Sewing Machines
HOW DO I OIL A VIKING DESIGNER SE EMBROIDERY MACHINE, TRYING TO FIX THE PROBLEM OF BIRD NESTING.
bird nesting is from needle thread tension being too loose
increase the tension up
May 02, 2017 | Sewing Machines
Elma supermatic balls up under machine after a few stiches
Thread nests (also called bird nests).
Remove the top thread.
Apr 23, 2017 | Sewing Machines
When I sew I have thread bunching up underneath the fabric, I've changed needle size, thread, bobbins and cleaned out around the bobbin holder. I'm frustrated and out of ideas.
Susan--
Easy peasy, once you know the problem and how to fix it. It's called "bird nesting" or "thread nesting" or what I refer to as thread "barfs."
Install a brand new needle.
Remove all the thread from the machine.
**ALWAYS RAISE** the presser foot and rethread the top thread.
Verify the top thread path is correct.
Install and thread the bobbin case, make sure it is correct.
Set the top tension to the midway point.
Now retest your machine. Birds nests gone? You may need to tweak the top tension because the factory standard changes due to age and use.
FWIW, problems appearing under the fabric are an issue of the top thread. Thread problems appearing on top of the fabric is a bobbin issue.
WHY IS THREAD BUNCHING UNDERNEATH MY FABRIC
Mar 25, 2017 | Sewing Machines
Machine will not look stitchesw also bundles up bottom thread
increase the needle thread tension as it indicates that the tension is not tight enough
Feb 26, 2017 | Sewing Machines
The burners go out block bird nest How to clean?
Air line, flue brush , what ever will fit to clear it . not water.
Oct 27, 2012 | Williams 3003622 Ceramic Wall Mounted...
Hello; I have an AirKing Valecia 755 range hood. I dissambled it in order to remove a birds nest and clean. When I reassembled and installed the hood, it now does not function. No fan or lights. I...
Check and make sure green is ground,any metal.White,and black are hot,check them with a volt meter,make sure they are on the right sides of the switches.
Nov 20, 2009 | Microwave Ovens
Vent was cloged with a birds nest now it wont heat
IF POSSIBLE REMOVE THE DRYER VENT FROM THE REAR OF THE DRYER AND VACUME OUT AS MUCH LINT FROM THE DRYER ITSELF SOME LINT MAY HAVE GOTTEN BACK INTO THE BLOWER
Sep 02, 2009 | Whirlpool GEW9200L Electric Dryer
Kitchen Ranges Logo
20 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
