Question about Polaroid TDA-03211C 32 in. LCD HDTV
HORIZONTAL SIZE INSUFFIENT WITH VERTICAL SIGSAG PICTURE ON RASTER
    Guru:
  • 1,738 Answers
Video issues.
Posted on Nov 20, 2009
Raster is ok but signal comes either RF or AV,there are horizontal and vertical lines in front of picture
Video processor section IC has damaged. If you wish to get more information, check this link. Pull up older posts there.
Mar 20, 2013 | Televison & Video
Toshiba CZ32V61 no picture
1) you have problem with the Raster
2) the main causes are a) raster b) picture c) sound d) synch
3) since this are not video, the problem is raster. your must
test the voltage from section horizontal out +125vdc+vertical output +80v+all other circuit +12vdc
4) test the power supply for defective. see the diagram attached
Jul 12, 2012 | Toshiba CZ32V61 32" TV
The screen image has enlarged on its own. I have try to fix it by going to the horizontal and vertical settings and and I tried to adjust them but nothing worked. I would appreciate any suggestions, thank...
The normal basic troubleshooting for a TV; 1) Raster 2) Picture 3) Sinchr 4) Sound)
Since you have a Raster +Picture you must Test the section 3)Synchr bad is included by differentiator and integrator
see the block diagram attached and proceed very well, with Troubleshooting.
God bless you
Jul 07, 2012 | Televison & Video
Sony projection tv 48inch year model 1997. we have only sound no picture.?
Your have problem in the power supply, since there is sound meaning the other section were working. Your Raster is missing or the horizontal and the vertical or your dont have high voltage to run the tube screen. Either the problem would be open Fuse or open resistor on the power supply or the Horizontal output stage damage.
Aug 15, 2011 | Televison & Video
IM A TV TECH. I HAVE A SONY LCD KP-60XBR800 I HAVE NO RASTER. POWER OK, MENU OK BUT NO RASTER ON TUNER, TUNER VOLTS OK,CAN YOU HELP ME PLEASE. THANKS my email sergioaguirre0182@hotmail.com
check the high voltage with the screen control turned up high where there is no raster. suspect problem within the video circuit where there is no high voltage or defective picture tube.some time when the screen is black and the screen control advanced,you can see if the tv has video or vertical or horizontal problems on the screen.service the high voltage circuit if there is no raster or high voltage is seen.no raster can be caused by the no heater or filament in the CRT.---- a defective picture tube can cause many problems, such as, poor brightness ,missing colors,intermittent picture,poor focus,a single-colored raster,arching in the gun assembly,retrace lines in the picture,negative picture,chassis shutdown,noheater or filament lit and no raster to name a few.an open filament or heater can cause no picture or no raster symptom.a defective CRT can have an extremely bright screen.loose particles of the cathode element can lodge between the grids and cause an intermittent black and white picture. simply tap the ends of the CRT gun assembly and notice if the picture begins to flash off and on.---- with a leaky picture tube after turn on the raster dims and get extremely bright.a dim picture with no green in the raster can result from a bad green assembly. a heater-to-cathode short can cause a raster to change colour or a result in no raster at all.replace the picture tube if there is severe arching in the neck of CRT. excessive brightness with retrace lines and a vertical collapse to a thin line can be caused by a bad coil on the neck board of the picture tube.rejuvenate the picture tube when there is very bright green screen. check for the resistance change on the resistors of the CRT neck board for an excessively bright picture with retrace lines.excessive dust inside the CRT spark gaps within the picture tube socket can cause the very bright raster and the chassis shutdown.a defective video amp,luminance buffer,or reference transistor can cause a bright picture with retrace lines. -------- for getting any required parts to replace you can get it from www.radioshack.com or from www.partstore.com or from www.shopjimmy.com --------- thanks.please do rate the solution.thank you for using fixya.keep updated.
Sep 06, 2009 | Televison & Video
Philips TV (old) showing a horizontal line in center of screen
Check for the cracked solder joints on the IC or dried capacitors on the vertical side
Mar 28, 2009 | Televison & Video
No vertical deflection, only a thin horizontal line.
Hi and welcome to FixYa,
A few ideas you may want to consider/explore;
  • While it is true that capacitors do dry out, the values that you posted (22uF & 32uF) are relatively low for the pump/boost capacitor which is responsible for the "top of the picture was a couple of inches short". Normally this should be around 100uF connected between pin8 & pin 12 of LA7836;
  • agree that the Vertical IC LA7836 is busted hence the single line;
  • in most vertical designs, there would be a diode from pin7 that goes to pin12 that needs looking into for a leak;
  • pin7 is the Vert B+ ~ 24VDC while pin1 is secondary B+ 9 ~ 12 VDC. In some designs to accomplish this, there is a dropping resistor from pin 7 to pin 1 and sometimes a zener diode from pin1 to GND parallel with a filter capacitor;
  • pin11 is the vertical output that goes to the yoke. From the yoke some design uses another capacitor (about 1000uF) before going to the ground through a low resistor (~ 1 ohm);
  • above mentioned parts need to be checked out of ciruit preferable and special attention to possible leaks of the diode when testing in reverse bias mode.
Good luck and thank you for using FixYa.
Jan 30, 2009 | Panasonic CT25G7 25" TV
No vertical deflection,only a thin horizontal line.
Hello dede27,
I suspect you have some background in electronics so I'll ask you some questions.
First, I know that you changed the output ic and a capacitor, the capacitor caused excessive beam current, that's bad, remember that beam current is dangerous because it can produce X-Rays. Remember to use the exact value of parts for X-Ray generating areas of the TV. So replace the C555 with the rated value by the manufacture.
As far as the vertical deflection problem it sounds like you may have a shorted vertical deflection coil (part of the yoke transformer). I would suggest testing the coil to see if it is shorted (A ring test will determine this). The Sencore LC102 has a ring test feature or you can lookup how to build a simple ring tester. In any event replace the IC and test the yoke transformer for shorts on the vertical winding.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
I need to find the pincushion circuit on my RCA F32632SB TV to check a problem with the TV displaying an hour glass picture. Where can I find a picture of this or a manual to guide me to the circuit?
The pincushion it intimately related to the horizontal circuits,the electron beam must travel farther to reach the corners of the crt and it does to the middle and so without pincushion circuits the raster would be bowed in on the sides on crts 27 inches are larger.Pincushion corrections straightens the raster by modulating the horizontal yoke current at a vertical rate.In an RCA tv the pincushion circuits are usually numbered 4800and the pin amp will probably be numbered 4801,its drive transistor should be Q4802,R4802 will be the width control,and R4805 the e/w pin amplitude. its inputs from the vertical should be Q4801 (subtractor) Q4803 (buffer) you should have a parabola waveform at 4801,yoke current can be modulated here without effecting high voltage.when Q4802 conducts voltage should decrease across Q4801 and the voltage drop across the yoke increases. The east west pin amp control 4805 controls how much of the vertical parabola is input to U4801 to compensate for changes in width caused by variations in beam current.By varying the e/w control resistor you can know if the circuit fault is in the input or output,if the picture varies in size the fault is in the input to U4801,if it does not vary check the output or U4801......hope that helps
Jan 15, 2009 | RCA F32632SB 32" TV
Horizontal setting is Out
Once you're ruled out your PC and video card by trying a different monitor, I would suspect the problem is a bad video / signal board inside the monitor. If so, it needs component-level electronic troubleshooting to locate the bad part(s).
Jan 10, 2007 | Microtech JTX V5 15" Flat Panel LCD...
Polaroid TDA-03211C 32 in. LCD HDTV Logo
27 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
