Question about HP f1905 19" Flat Panel LCD Monitor
HP f1905e tilt and Height adjustment
Monitor has height and tilt adjustment but will not stay at set height. Monitor sinks down and rests on monitor feet.
  • Bob Ward
    Bob Ward Jan 29, 2008
    I also have a height adjustment problem with the hpf 1905. I can't find any way to tighten it up. It just sinks to the lowest level. It obviously has a weak spring or tensioner. Wonder is there is a replacement part?
    Let me know if you find a solution.
  • Anonymous Feb 15, 2012
    Thanks for the good info the cover over the arms comes off in two pieces (top and bottom) it splits at the midline if you use a small screw driver and twist/pry it from the base towards the monitor a little at a time they come off without breaking any tabs. I repaired mine as mentioned above and it works and stands alone just fine.
I figured it out! Just takes a phillips screwdriver and a 5/16" open end wrench to tighten up some nuts inside the plastic housing. The plastic housing doesn't come off with the screws, but has to be slightly pryed up to release the little plastic catches. Be careful though, you don't want to break the plastic tabs. It's ok to break maybe 1 because there are several to take up the slack. At first I thought it was the nuts that are 1/2" (there are two that are close to 2 springs. But that was just for the tilt forward and backward. Actually there are 4 nuts (5/16") that need to be tightened. Don't over tighten or it will not tilt at all. I took photos of the disassembled base. If you have skype, then skype me at "golfbob" chino hills, and I can send the pics or talk you through it. Good luck.
Posted on Jan 29, 2008
  • Bob Ward
    I also had to pry off the plastic cover that I have written on to get the wrench on the nuts. Also meant to say "do not over-tighten because you will not be able to raise or lower the monitor (not tilt).
  • Bob Ward
    Another view with plastic covers removed.
  • 788 Answers
Tighten any screws that may be visible on the monitor stand.
Posted on Jan 11, 2008
How to adjust height
If you can adjust the height on your monitor, look at the back. There is usually a button that you push as you press down on the monitor. If you don't have that, then I recommend a phone book or two.
Nov 17, 2014 | Computers & Internet
Can the monitor height be adjusted. It seems to be fixed to the stand with no adjustments?
No but you could always put something under the stand most can only be tilted for lighting reasons.
Jul 04, 2011 | Princeton Digital VL1916 19" LCD Monitor
How do i adjust the height of my monitor?
Hey mate to change the height of the image, there shoul be buttens on the monitor one saying menu or something like that... the height settings are in the menu its self
Apr 13, 2010 | Computers & Internet
Our viewsonic monitor tilts forward. how do we tilt it back?
Hello again.
The ViewSonic VG1930wm has a height adjustment range of 3.2", TILT capabilities, and a swivel range of 360 degrees.
So yes your monitor should be able to tilt back and forth.  Most likely if you hold the base of the monitor, and press somewhere on the front at the top or bottom (do not press on the screen itself) then it should easily tilt back and forth.  Occassionally there is a switch you may have to hold while you push on the front-top/bottom of the monitor which acts as a lock for the tilt angle.
Hope that helps, and don't forget to vote/rate!
Height adjustment range 3.2", tilt, swivel range 360º
Mar 12, 2009 | ViewSonic VG1930WM LCD Monitor
LG Flatron Monitor-adjust height and color,%20Swivel,%20and%20Vertical%20Extension
4:29:29 If locked in the down position, 1. Push the monitor down, 2. Press the Lock down / release button on the bottom rear of stand to unlock the monitor. 3. Lift the monitor up and extend the stand to the desired height.
Jan 15, 2009 | Computers & Internet
Height adjust for Dell UltraSharp 1907FP 19" LCD Monitor
Is it stuck, or just not adjustable? Try setting it on a phonebook. I'm kidding. If it is an adjustable base, sometimes they need a little downward pressure before the button will depress and allow it to move upward.
Jan 03, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
The monitor screen will not stay up on my HP f1905e monitor
Inside of the base support there is a spring mechanism. I have seen the spring come off from its support, or some parts of the mechanism itself go defective. In some cases I had to order a new support from the manufacture.
Jerry G.
Jan 02, 2009 | CTX S762A 17" LCD Monitor
HP f1905 19" Flat Panel LCD Monitor Logo
1,752 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
