Question about Sony Cyber-shot DSC-W90 Digital Camera
Pictures come out with half shaded a different color
When I print color pictures or greeting cards there are different shades of same color horizontally.
Go to canon website an check for software an firmware upgrades also clean printer an make sure ink is installed correctly :-) Hope this helps
Nov 17, 2015 | Canon Pixma MX922
The top half of my pictures with a flash are shaded.
Not seeing the pictures I have to guess. If the shade you mention is not like a straight line, but more rounded, try making the picture without the lens hood. Or use a external flash, when you use another than the standard lens. I don't think you can take a picture in manual, with a shutter speed above 1/250 second, because in such case the top or bottom part could become shaded then, but then the shade is in a straight line from left to right.
Dec 26, 2013 | Nikon D3100 Digital Camera
I want to color my hair but I do not know what shade to go for. How can I make a decision without ending up with a dramatic change in my color?
You don't have to pick a color that is totally different from your natural hair color. The whole point is to enhance your hair look, not to dramatically change you. You should pick a shade that is only a couple of shades away from your natural color. Choose a good make, like L'Oreal and pick a color that is marked 'natural' on the box.
Mar 04, 2013 | Health & Beauty
My Mitsubishi 1080HD model WS-55315 colors are not correct. The blue is good and the green seems to be, everything else seems to be a shade of light brown or tan. I thought maybe the red tube was bad but...
The tv have a problems known as a convergence pictures problems,it is dead.Tv have any colors lines like R,G,B mis alignments,also tv have any colors shaded shadows pictures or a 3D pictures look alike?Yes,than the tv have a convergence board problems and it is dead to causes all of these problems.The tv convergence board must have to repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops repair a DLP tv convergence board will cost u like $300-$350 for parts an labors.
Sep 12, 2011 | Mitsubishi WS-55315 55" Rear Projection...
The left half of the picture has gotten blurry, with pink, green outlining what seems like 3 different pictures of the same thing. The left half works fine and the HD of direct TV is good on that side. I...
The tv have a problems known as a tv convergence pictures problems,it is dead.Tv set have any colors lines like R,G,B mis alingnments,have colors shadows pictures or a 3D pictures look alike?Yes,than the tv set convergence board it is dead to causes all these pictures problems.The tv set convergence board must have to be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv set convergence board to solved the tv set covergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 18, 2011 | Sony KP-65WS510 65" Rear Projection...
L7680 all in one W/big & wide dark vertical line
Open the document feeder and clean the scanner glass.
Feb 16, 2009 | HP OfficeJet 7310 All-In-One InkJet...
3d effect
Shading with a black cartridge will be different than shading with a color cartridge. Replace the black cartridge with a color, and things should return to normal.
On the re-fill cartridge, replace it with a new OEM cartridge, and if that works, the refil is defective.
Dec 31, 2007 | Lexmark JetPrinter Z12 color InkJet
White Balance
Color reproduction differs depending on the lighting conditions. For instance, when daylight, the setting sun or indoor lighting is reflected on white paper, the shade of white produced will be slightly different for each. By setting the WB (White Balance), you can achieve more natural-looking color. You can also preview different color tones by trying the different settings under the actual light source, and checking the result on the viewfinder/monitor. You can choose mode from Auto, Preset and One-touch.
Sep 04, 2005 | Olympus Camedia C-740 Ultra Zoom Digital...
Sony Cyber-shot  DSC-W90 Digital Camera Logo
13 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
