Question about Mitsubishi WS-55819 55" Rear Projection Television
I have a mitsubishi WS55819 and every time i turn it on the top and bottom center colapse and the picture is distorted but if i hit the tv it pops back to normal however the problem is starting to get worse what can i do
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
I suspect what you are describing is a convergence problem---when it acts up go into the customer menu and select convergence--then advanced--it will bring up a grid of lines---if red, or blue is skewed this is your problem.
I have repaired hundreds of these sets--this model uses two of the STK-392-570 convergence chips and I have seen many where the convergence comes and goes--what happens in these sets is not a soldering problem but the pins inside the chips come loose--Each chip has about 16 pins--I have had ones that when I removed the solder pins fell out of the chip.
The pair of chips can be bought on Ebay for about 12 dollars plus shipping (I know the best seller there) and if you or someone you know can do it you can save the set and a lot of money.
Most shops are going to charge at LEAST 300 for this repair--and some will not do it in your home--it can be easily done in the home and takes about 1 hour.
I HAVE START TO FINISH, STEP BY STEP INSTRUCTIONS FOR THIS REPAIR IN THIS MODEL.
If you think you can do it yourself let me know and we will get the instructions to you.
If you have any questions or need help--let me know by replying to this solution. I am here to help people.
If this information has helped you, rate this solution as I do this for FREE.
Thanks for using FIXYA!
SD TECH
Posted on Nov 20, 2009
    Guru:
  • 1,738 Answers
Your tv has three piture tub guns in there. Your convergence board that controlls them to be in align is acting up.
The picture projects the image with concave lines on the edges. I'll explain further: somehow the picture is distorted in a way that bends the four edges of the picture in a curved-concave manner so that...
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 26, 2009 | Mitsubishi VS-55705 55" Rear Projection...
I have a Mitsubishi 55 inch rear projection tv, ws55819 on which the convergance is gone bad. I'm getting a concave picture with multiple colors and black lines with a blurred picture. this happens mutiple...
Your reference to concave picture suggests a high voltage problem and not convergence. If the raster can't scan from left to right , top to bottom, your having High voltage trouble. if your colors are not dropping on top of each other that is convergence. I would suggest it may be time to consider a purchase of the new HD set for the cost of this repair. good luck
Jul 03, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Distorted picture on a mitsubishi ws-55613 tv
Their is no more you can do.
Seen this before.
You need a professional.
Stop using the TV until it is repaired.
Continue to use the TV and your problems WILL multiply.
Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc
Milwaukee, Wisconsin 53405
(414) 762-8600
Established 1974
Mar 24, 2009 | Mitsubishi WS-55613 55" Rear Projection...
The screen colapsed into a thin line running from the top center
The deflection circuit is most likley bad. You need a service center to repair . If you can TEST THE BIG FAT TRANSISTORS AND CHANGE OUT IF BAD, THEN YOU CAN FIX IT. They are usually on a big metal finned heatsink ...
Mar 07, 2009 | RCA F35755MB 35" TV
I have a KV27FS210 sony wega trinitron tv. It turns on and has a single horizontal line across the center of the screen then buzzes shows a continuous zigzag line from the top to bottom of the screen with...
The single horizontal line is a problem with the vertical circuit. Look for a small flat id attached to a heatsink that should be marked LA7837 or something similar. Try resoldering the pins of this IC first. If that does not resolve it, replace the IC.
Keep us posted.
Dan
Feb 20, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Concaved distorted picture in 1080 Mitsubishi 65" TV.
This is a convergence rpoblem that is either bad connections on the pins of the convergence ICs or defective ICs. If you can solder and are comfortable working inside TVs where there are potentially dangerous high voltages, let me know and I'll provide additional details and instructions for fixing this yourself.
Dan
Dec 11, 2008 | Mitsubishi WS-55807 TV
Mitsubishi tv model WS-55809
that happened to me and i just gently hit it on the top and it fixed itself
Jun 28, 2008 | Mitsubishi WS-55809 55" Rear Projection...
WS-65907 picture problem
Try resoldering the convergence ICs mitsubishi has been known to be a little stingy on the convergence IC solder in the past.
May 15, 2008 | Mitsubishi WS-65907 65" Rear Projection...
Concave distortion on top and bottom of screen
Bad convergence IC's ....change both for reliability...part number
STK392-570...located on center PC board.................T.
Feb 11, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Bowlike effect convergence all screwwed up
I suspect you originally had an intermittent solder connection on the convergence circuit board. This may have damaged the convergence IC's on that board by now if repairing those connections doesn't fix the set.
Mar 10, 2007 | Mitsubishi WS-65819 TV
Mitsubishi WS-55819 55" Rear Projection Television Logo
170 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
