Question about Compaq Presario M2000 Notebook
My laptop screen goes white without warning every now and then. Can you explain or help me? Thanks
  • JDTec
    JDTec May 11, 2010
    Does this happen when you move the LCD screen?
    Problem Solver:
  • 11 Answers
It Sounds like The Screen has a short in it! Or maybe a COLD solder joint, twist it back an forth and see if it comes back, if so then that is what is wrong, or dos it happen when you open and close it, in this case sounds like the cable strip from the screen to the mother board,
Either way sounds like it will need to go to a shop.?
Posted on Nov 26, 2009
Testimonial: "thanks for your help. Strangely tyhe problem seems to have gone away."
    President:
  • 2,653 Answers
Usually that means the lcd is going out or the GPU has a problem. When it finally does I'd recommend a new laptop. Or u can fix it for 100 or less locally...but laptop prices have dropped so much that it's probably best to put that money towards a new faster system that has a warranty in place.
Posted on Nov 20, 2009
Acer Aspire 7736z-4088 keeps shutting off randomly
Is the fan and vents free of dust? Is the laptop getting sufficent air flow? It sounds like power issues maybe multiple issues. Does it overheat? Difficult to say for sure. If your remove the battery?
Dec 01, 2012 | Computers & Internet
Easynote lj65 Laptop go off with out warning
check your screen saver properties. below is the power button
click and change the warning time when the computer turns off.
It is possible that your battery is dying they do have a life span.
please inform me if this helps
Sep 16, 2012 | Computers & Internet
My Acer z5600 just shuts off while I'm doing something without any notice.I gets very hot at the top of the screen and then shuts off without warning.The screen just goes black and I can not turn
Your processor is overheating. Or the fan for the CPU is dead or the way to eject the warm air is blocked. Try to work with your laptop on a table, if the problem persists, is the fan other way you have to work everytime on the table.
Aug 06, 2012 | Acer Aspire Z5600 PC Desktop
White Screen - Unable to See Desktop GUI.
Two separate problems, sounded like..
White screen? If external video is okay then it's likely (1) a bad screen, or (2) a disconnected video cable.
If the system shuts down, I'd check the fan - if the fan is reasonably clean and running, then it's probably a bad motherboard.
Mar 15, 2010 | Toshiba Satellite 1805-S274 Notebook
I dropped my RTI T3 remote and now the touch screen went blank (white light). Touch screen works, but icons are gone. I tried taking out the battery to reset, but still no icons. Help!
T3s and T2-Cs are very delicate and often go to the White Screen of Death WSoD when dropped. (a play on the term BSoD from windows)
The remote needs to be serviced to fix this. If you explain the remote goes to white screen when you call RTI they will understand.
their tech support number to get a return authorization is here. They will explain how to pack and ship it.
(952) 253-3136
Dec 26, 2009 | Rti Technologies Rti T1 Remote Control
My HP dv6000 laptop screen goes black suddenly, without warning. It is solid black if on battery power; if I have it plugged in to power supply, it is black with flickering white lines.
Your inverter is failing. Under battery power there is not enough DC power for the inverter to convert to High voltage AC power and it goes black. Even under charging, there seems to be evidence that the inverter is failing because there it is unable to consistantly convert the needed power. Check the cables on the back of the display and change your inverter.
Nov 02, 2009 | Sony FD Trinitron WEGA KV-36HS420 36" TV
White screen
hi thanks for using fixya!
I suggest that you shoud bring your laptop to a service center to check exactly the errors are. This is the best option for now.
Best Regards!
Apr 19, 2009 | Acer Aspire 4315 Notebook
White wireless cord??
On the card itself should there be 2 x connection points,the black one is ,already connected and the other should be right next to it,within an inch(25mm) ,you can remove the black lead to see clearer what the connection point looks like,they are push on connections,and will be 2x tiny brass or gold coloured female connectors,side by side,
apart from that ,
the length of the leads will not stretch too far from their place of connection,
Both power the wireless card,
One is positive(+) and the other is negetive(-)
Hope this helps,need a photo to explain???
GOOGLE it,
try typing in the card number of the cards sticker and select image search,
Thanks and have a great night,
Misterdj
Jan 14, 2009 | ASUS A6U Notebook
Notebook goes blank
your battery may be getting to weak to work.
try booting without the battery.
Apr 26, 2008 | Computers & Internet
Compaq Presario M2000 Notebook Logo
253 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
