Question about Samsung HLR5067WX 50" Rear Projection HDTV
Samsung HLR5067 has no Video.
Set has audio and OSD but no video. Display shows a plaid looking pattern for all connected sources. Any ideas?
    Guru:
  • 1,738 Answers
Something to do with the video board.
Posted on Nov 20, 2009
My volume on screne display does not work
do any of the controls show on tv? there is a video connection on the back of yamaha marked 'moniter out' and to get the on screen display, you must first have your tv connected to that video output.
Mar 03, 2013 | Yamaha RX-V1000 Receiver
I am trying to connect my Onkyo DS-A3 ipod dock to my Onkyo TX-SR508 receiver and I cannot get the TV to display the ipod menu. I've connected the red and white (R/L) and yellow video cable to the...
Is OSD set to ON? See below
Set the OSD (onscreen display) mode before you start using the RI Dock. 1. Plug in the AC adapter. 2. Turn on your TV and amp, and select the appropriate inputs on your TV and amp. 3. Insert your iPod into the RI Dock. 4. Select the video output mode depending on the video connection. While pressing the remote controller's [SETUP] button, press the Up [ ] button for the component video connection, press the [ ] button for the composite (default) connection. 5. Use the remote controller's [MODE] button to set the OSD mode. On: Playlists (artists, albums, songs, and so on) are displayed on your TV, and you can navigate and select your music or video while looking at your TV. While this mode is selected, your iPod displays the Onkyo logo. Off: Nothing is displayed on your TV and you navigate and select your contents by using your iPod's display.
Mar 15, 2017 | Onkyo Audio Players & Recorders
I used to get OSD on the TV with my receiver, but it has gone and I don't know what setting to do to get it back. It is a Pioneer VSX-917V-s/-K. Thanks
did you happen to change to cable connecting the Reciever to the TV to an HDMI?
please note that the OSD will not appear if you have connected using the HDMI output to your TV.
Use component, S-video or composite connections for system setup.
Dec 30, 2009 | Pioneer VSX-917V-K Receiver
Picture is scrambled after power surge. Have a
Check if it has a scrambled image on all sources ie - DVD- VCR - cable/satellite box. Since the PIP is normal it sounds like the signal source is bad.
Post back with more info about your set up (what's hooked to your TV) if you need more info
Nov 28, 2009 | Samsung HL-R4667W Rear Projection...
Yamaha RX-V730 OSD problem
I assume you have a component connected source coming into the Yamaha to give it sync and you are component connected out to the monitor. If you have no input you won't have osd on component only without a signal to sync lock.
It is always possible that the 730 doesn't actually have component overlay for osd, just its a 2in 1 out switched affair. Hence the manual says you also need the composite/ Svid as well...They certainly don't use both at the same time. Newer units have full up + down video conversion but at this age it won't have.
Oct 31, 2009 | Yamaha RX-V730 Receiver
OSD control from receiver
I had the same problem on my 7200 until I realized that the display comes up on the television screen. I carefully followed the set up required from the manual. I got the Manual online at Marantz.com. I have a cable hook up so I connected the video cable out from the box to the Video in source on the 7200 and monitor out to my Television. I then pressed the Amp button to get the remote to Amp mode. I then pressed the OK button that is in the center of the four direction buttons and the menu displayed itself on the screen . I hope this helps. ercble
Nov 28, 2008 | Marantz SR-7200 Receiver
No OSD on TV connected thru composite video (Monitor Out)
hello you need the s-video/sound usually four pins in each end connect to s-video not composite video..saludos
Nov 22, 2008 | Onkyo TX-SR606 Receiver
RCA P46924 64" Rear Projection TV
disconnect the wii it will eventually ruin your tv game systems can't be used on rear projection because of problems caused you may need to hook everything up at the bottom of the panel and switch back and forth using your remote we had to do that on ours
Oct 22, 2008 | RCA P46924 46" Rear Projection Television
Intermittent display problem, NEC Multisync 1760NX
This usually happens when the resolution is set incorrectly for the monitor. If you have been using the same setup, probably an update changed the driver or setting for the video card. If it is a new monitor, try hooking up the old one and change the resolution to something the new monitor can understand. If you have been using it for some time and this is all of a sudden, then try to borrow a monitor and change the resolution to something the monitor can understand. If you borrow one and can get it working, also look and make sure the video card has a driver installed. Sometimes an update can change things.
Dec 21, 2017 | NEC MultiSync 1760NX 17" LCD Monitor
Samsung HLR5067WX 50" Rear Projection HDTV Logo
77 people viewed this question
Jerry Greenberg
Jerry Greenberg
