Question about Kodak EASYSHARE Z1485 IS Digital Camera
Hi my daughters camera only worked for a month now it will not turn on we have replaced batteries several times with proper batteries recomended. PLEASE HELP!
    Genius:
  • Kodak Master
  • 1,099 Answers
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
If problem still persists. There is a 28 days return garantee from the shop. If the sales date have past this you can arrange a repair:
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Nov 20, 2009
Stopped Working All Together
Hi, bring to your nearest service center to repair it.
May 18, 2013 | FUJIFILM Instax 210 Film Camera
Doesn't remember time and date
Keith, it sounds like the camera internal battery for the memory is dead. Normally they will last several years, however I have seen them go bad in one to two years. These batteries are not easily replaced on the Kodak models and requires disassembling the camera and soldering in a new battery. My recommendation would be to keep good lithium or rechargeable batteries in the camera, removing them only when they need replacing, or if the camera is going to sit unused for more than a couple months.
Apr 21, 2010 | Kodak EasyShare C613 Digital Camera
Cannot turn on my Kodak easyshare c713
Hi I had the same problem with my daughters c713. Tried several bateries found out that the camera is specific with its bateries brand. When i put in new ones from kodak itself from my sons camera a c913 the c713 turn on again. Tried a new pack local brand checked them first and voltage was ok but didn´t work again. Back in those from kodak and ok again. Tried philips also ok.
So try different brand and find out. Good luck.
Jaap Davids The Netherlands
Jun 17, 2009 | Kodak EasyShare C713 Digital Camera
Digital Camera Turns oFF,While viewinq pictures or while taking 1
hi...ensure that the camera is turned on. If applicable, ensure the lens cover has been removed before taking pictures. the LCD backlight is turned on by pressing the DISPLAY button several times until the screen appears. Depending on the camera model, the DISPLAY button may be labeled as DISP or with a display icon. This button could be a standalone button or it depends upon the camera model..... If operating the camera with a battery, ensure the battery is fully charged.
Ensure the battery is inserted properly in the camera.
If operating the camera with the power adapter, ensure it is plugged into a working AC outlet.
Ensure no Audio/Video (A/V) cables are connected for viewing pictures on a TV; the LCD screen will not display when an A/V cable is connected.
Perform a reset procedure on the camera....
thank u rate me!!!!
Feb 16, 2009 | Sony Cyber-Shot DSC-T5 Digital Camera
Psp will not turn on unless the cord is plugged in
ok your son's psp has malfunctioned and instead of trying to charge the batteries it drained them. i would recomend for u to get ur son a new psp and buy a another battery for your daughter.
there is a newer battery being sold that you put AA batteries inside
to make it work. check out your local best buy and wal*mart
Dec 23, 2008 | Sony PlayStation Portable (PSP) Slim...
FE-230 Failure to come on
Hi Gary
Is the camera under warranty and registered with Olympus? If not registered, make sure you do that online first. It also extends your warranty to 13 months. If no receipt, It was a gift.
You most likely have a bad lens assembly (was it dropped?) or microprocessor. Here's your link...
Olympususamerica.com
Consumer division, customer service 1-800-622-6372 M-F 8 to 7 EST
Outstanding people to deal with
Hope I could be of some help. Regards, Paul
Aug 16, 2008 | Olympus FE-230 Digital Camera
Olympus FE-270
First check your warranty - you may be able to return it for repair under that - and yes it needs a repair. The metering system is now broken, The chances are you'll recieve a new one as it is more cost effective to them to do this. (keep the batteries)
Jun 18, 2008 | Olympus FE-270 Digital Camera
Polaroid i631 digital camera
Daughter received camera as Christmas gift. Camera beeps three times and does nothing. I guess this camera is only good until the warranty runs out, 90 days. We have tried several new batteries and the expensive rechargeable type also. VERY UNHAPPY!!!!!
Jan 31, 2008 | Cameras
Polaroid i533 digital camera
Here is how I fixed this problem. I grasped the lens around the base (larger part) like you would if you were going take off a beer bottle cap.
Very gently while sliding my thumb and index finger around the lens, I rocked it back and forth. DO NOT TRY TO TWIST OR PUSH,.....It felt like it "popped" back on track.
My assumption was it was probably hit from the side, and could not retract, once it was rocked back on track, it worked fine. It felt like it loosened a tiny bit as well.
Good luck.
Jan 03, 2008 | Polaroid I533P Digital Camera
Pink screen
Back to store or maker with it. Check out the makers Tech support site but this needs a new camera replacement.
May 16, 2007 | Kodak EasyShare C643 Digital Camera
Kodak EASYSHARE Z1485 IS Digital Camera Logo
80 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
