Question about Kitchen Ranges
My burners and broiler works but my oven will not I dont know what to do?
  • 491 Answers
IT SOUNDS LIKE YOUR HEATING ELEMENT HAS BURNT OUT TO FIX FIRST TURN OFF THE POWER THEN LOCATE THE SCREWS HOLDING THE INSIDE PANEL ON REMOVE ALL SCREWS AND PANEL YOU SHOULD SEE THE ELEMENT REMOVE IT FROM ITS CONNECTION PLUG THEN BRING IT TO A ELETRICAL AND PLUMMERS SUPPLY STORE FOR REPLACEMENT REFIT IT TO YOUR OVEN AND IT SHOULD WORK FINE.
Posted on Nov 20, 2009
Frigidarie stove model#PLGFZ390ECB burners and broiler works oven dont replace iginitor still do not work.
Good Afternoon Cheryl,
I understand that the burners and broiler are working in your Frigidaire range, model# PLGFZ390ECB, but the bake element does not work. I also see that you have replaced the igniter and it is still not working. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine why your oven will not come on. Hope this is helpful.
-Best Regards-
WP
Jul 01, 2014 | Frigidaire 24" Built-In Single Gas Wall...
Cannot get oven to work
I need more info, dose the top buners work ? dose the broiler work ? Did you take a flashlight ad look over the lower cal-rod or element ? for damage get back to me on and off here all day and some nights till 9 pm
Dec 13, 2011 | Ovens
SET DIGITAL THERMOSTAT TO SAY 350 DEGREES WILL NOT TURN ON OVEN,,, ? IF I SET TO BROIL BROIL WORKS BUT OVEN WILL NOT TURN ON ?
Possibly the ignitor for the main oven burner has failed--
An observation question:
When the Broiler 'lights' and comes on, do you notice the ignitor glowing bright, before the gas valve (to the Broiler) opens, and you get the Broiler lighting---
Now-- for the main burner to come on, -- there has to be a similar bright glow from the MAIN BURNER ignitor, before its main burner gas valve can open-- No Ignitor?-- No ignition, and not Main Oven burner!
Let me know what you need from this point on --
Mack B
Dec 30, 2010 | Maytag CWG3100A Gas Single Oven
I have no heat coming from the oven portion of my kenmore 790 electric range after hearing a "pop" sound. fyi, the element looks intact.
Top burners are working, broiler is working, bottom oven burners dont ignite and dont heat the oven? What can we do?
Dec 30, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
My GE upper oven (Model # J KP27G002BG) just stopped working. No power light when turned on. The door light works. The lower oven works. Any ideas?
The lower burner in the top oven does not work, although the broiler does work. The broiler and lower burner in the bottom over both work. Could it be the burner element or would it be the relay board ?
Sep 10, 2009 | GE Ovens
My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
Dec 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Maytag gas oven
if your clock and broiler work then you need to replace the lower oven ignighter remove the oven racks then the bottom plate of the oven its easy then the flame spreader after that you will see a burner bar at the back of that will be the ignighter and just because it glowes dont mean its good just replace it
Jun 13, 2008 | Maytag MGR5751AD Gas Kitchen Range
Igniter works sometimes.....stove won't heat
Check your oven thermo. sensor at room temp. you should have between 1 to 1.1K ohms. If not replace it. You also should check your burner and oven relays.
Sep 19, 2007 | Jenn-Air JDS8850AAS Dual Fuel (Electric...
Kitchen Ranges Logo
89 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
