Question about Creative Labs ZEN V Plus MP3 Player
"rebuilding library" mine turned off but when i turned it back on it rebuilds the library but it stops half way every time even if i push the restart button its the same every time i tried letting the battery drain and when i plug it to the computer its the same crap. do you know what to do?
It happens also with my zen. I think that this device has some fabrication failures. The problem for me is that I live in Colombia and the waranty dont apply.
If you know how to solve this please write the solution in this blog
Posted on Jan 15, 2008
  • 233 Answers
Take a look at this video
thanks for rating
Posted on Jan 11, 2008
Resetting does nothing!!!! just back to rebuilding library and freezes again!!! nonstop circle
maybe use up all the battery life (until it won't even turn on any more) and wait an hour or two, then turn it back on... just a suggestion
Mar 23, 2010 | Audio Players & Recorders
Zen player mosaic crashes re-building library (uses flash memory)
I've been having the exact same problem. No matter how often I reset it it still becomes stuck on the rebuilding screen. I was thinking I may just copy all of my music onto my computer and then do a complete reset on my Zen and copy it back but I don't want to go to all that trouble if there is an easier way to fix it.
Jan 25, 2010 | Creative Labs Creative Technology Zen MP3...
Sony walkman NWZ-B135F doesnot turn on properly.. When turning it on 'Walkman' text appears and '.......' is appearing. after that no action.tried resetting also, no use
First guess. you have a large library and just added something. it is rebuilding its index
Second guess: you have other files than just music on here. it is rebuilding the library and has to scan all the non-mp3 files. Mine takes about 2-5 minutes to boot after adding / removing files
Oct 06, 2009 | Sony Walkman NWZ-S616F MP3 Player
Creative Zen Rebuilding Problem (Freezing)
Hold the reset button with a paper clip AND the play button at the same time while flipping the power switch. The ZEN should go into recovery mode. You probably want to do format all but you can try the different options. You also may need to download/update the firmware here.
Feb 07, 2009 | Creative Labs Zen Digital Media Player
Creative Zen Freezes on Rebuilding
My Zen locked when I turned it on. It wouldn't play the track the screen was on so I pressed the reset button and turned it on again. It was then still locked on the same track so I tried turning it off which then froze as it was shutting down. After another reset it went through the rebuild screen then locked again. I then used the above fix (pin in reset, then hold play and power switch down). Taking me into the kind of bios screen I formatted the contents. Then added my library again. It's now working fine.
This is the second Zen I've had because the first one had the same problem so I took it back without trying to fix it. Both times the problem occured when I had my Zen plugged into my car stereo auxiliary jack whilst switching the ignition on in my car. I can't understand why this would cause the problem but I'll avoid doing that in future.
Dec 27, 2008 | Creative Labs Zen Digital Media Player
Mp3 stuck in rebuilding library mode
hello guys sorry to hear your problems i have same problems too. Ok first plug ur zen player (mines V PLUS.. heheh) to ur pc then hold play button then keep pressing the reset botton until it turns on RECOVERY MODE then select YES to all (clean up, format, reload firmware) then download the RECOVRY TOOLS at creative site install it then plug ur zen player and run the recovery tools (cross ur finger) hopes it works mine a big smile hehehe email me at oracle101rage@gmail.com if it works..Gud Luck guys
May 18, 2008 | Creative Labs ZEN V Plus MP3 Player
Creative Nomad Zen Extra 40 Gb
I think the problem was related to the id3 tagging, but i wasnt able to conclusively determine that. I had to uninstall the nomad explorer, and reinstall it. That didnt stop it from happening again, but each time the same solution worked. Then the thing crapped on itself furthur. It would turn off then back on, and say it was rebuilding the library. Then it would turn itself off midway through that, and start over. I removed the battery, and put it back in. The thing made it all the way through the rebuild of the library, then just had a little icon on the display saying firmware problem. The solution was a firmware upgrade. I had to hold down the play button while sticking a paper clip in the reset. Then a menu came up and i selected reset OS. It deleted the OS, and re-upped one from the file i found at the creative website. The problem recurred at least once, and the solution was the same each time. It never lost any content while going through this rigamarole, but i did lose some hours fggin with it.
Mar 04, 2008 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Frozen
if it keeps on rebuilding the library the disk had a bad spot on it try going in to recover mode and do a clean if that doesn't work do a format if that doesn't work download the latest firmware if that doesn't fix you will need a new hard drive or flash drive.
Nov 15, 2007 | Creative Labs Zen Micro MP3 Player
Rebuilding Library to Firmware Problem error...HELP
try downloading the
MP3 player recovery tool from Creative's website (the tool contains the latest firmware update available -- 1.15.03). Plug your ZV+ into your PC, run the program and let it update the firmware. Then format, reload your music and try it.
By the way, before updating the firmware, let the battery have a full charge, ok?
Oct 08, 2007 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Creative Labs ZEN V Plus MP3 Player Logo
63 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
