Question about Sony Cyber-Shot DSC-P71 Digital Camera
It won't take a picture-everything else is fine
I put in New batteries,hit the reset button, reset the time date stamp,reset to factory settings by removing the batteries and holding the power button for 10 seconds, everything is fine but it won't take a picture!All ready to go but nothing happens..Screen is working, I can see my old pics when i want, menu and settings all work but it won't take a pictureI need this for my ebay auctions.puleeeeeeeze help! Cynthia
jackboy
  • 2985 Answers
SOURCE: E:61:10
Sony Technical Support team is the play to go
Posted on Jun 26, 2007
avaya pimp
  • 23 Answers
SOURCE: Date and/or time stamp
date and time are already imbeaded in each picture.
for you to print it with the date and rime stamped on it......you'll ned a software to enable it before printing. The software that came with the camera have that feature.check print settings.
Posted on Jan 30, 2008
  • 230 Answers
SOURCE: sony digital still camera cyber-shot dsc-f717
http://esupport.sony.com/perl/news-item.pl?news_id=161&mdl=DSCF717
Posted on Apr 21, 2008
SOURCE: Date/Time stamp
HI everyone I was reading your coments and actually in order to put the Date and Time stamp on the pictures, you will need to Use the Picture Motion Software that came in the Installaiton CD of the Sony Cybershot camera. There is no other way to put the date on a picture with a Sony camera.
Posted on Jul 14, 2008
SOURCE: E:61:10
It seems to be a mechanical problem that can be fixed by placing a bit of pressure on key points. Here is the fix that I did that seems to have worked fine...
open the battery cover
take the battery out
take the memory stick out (inside the battery case)
leave the battery cover open
carefully remove the 7 small silver screws (put them in a cup so you don't lose them!!)
slightly pry the front cover away from the camera starting at the bottom
wedge something in the side to 'pop' out the top retaining tabs towards the top
the front cover should now pop off the camra
Make small paper spacer #1:
Cut the adhesive strip off of a post it note.
Fold it over again about 5 times so that it has some thickness to it.
Approx final dimensions are 1/8in x 1/4in x 1/32in(??) thick
Stick it in the upper right corner of the black plastic lense housing.
See photos attached.
(There is a nice flat rectangle at that spot about the same dims.
This spacer should fit neatly right over that space.)
Make small paper spacer #2:
Approx final dimensions are 1/4in x 1/4in x 1/32in(??) thick
Stick it in the bottom left corner of the black plastic lense housing.
(There is a nice flat rectangle at that spot, but you want the spacer
to be a bit bigger so that it covers the vertical line in the plastic.)
Put the front cover back on the camera.
Make sure it is mechanically secure, but don't install the screws yet.
Put in the battery and memory stick.
Try it. You may have to play with the spacer thickness to get it to work.
Once it is working well again, then put the screws permanently back in.
Posted on Aug 26, 2008
How do i turn on the date stamp on my Canon Powershot SD750 so that the date prints on all my pictures?
Move top selector all the way to right,
1.put in auto mode
2. Hit Function set button
3. Where it lets use choose sizefrom L, M1, M2...scroll to Post Card 1600x 1200
4. hit function set again
5. Hit Menu, now you can select time date stamp
6. took me awhile to figure it out
Jan 31, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
I received a canon powershot as a gift last year and am just now really starting to use it. The pictures seem fine, but the it seems like I am frequently requested to put in the date and time (i.e. about...
There is a button battery in your camera (CR1220) that remembers the date and other settings when you remove the main batteries. It probably needs to be replaced. It's in a slide-out holder next to the AA batteries (see page 184 in the manual).
You turn on the date stamp by using the photo size settings. Press the Function key and scroll down to the bottom item (usually L). Then scroll over to the Date Stamp icon (to the right of the L, M1, M2, M3, S options). Press the Function/Set key again.
Nov 15, 2009 | Canon PowerShot A590 IS Digital Camera
How do I take a picture with the date and time stamp in the picture
The date stamp only works in "Postcard" resolution. Press the "Func Set" button, then scroll down to the bottom to select postcard resolution.
Then press the menu button. Select the "Camera" menu, then scroll down to the the Date Time Stamp selection to turn it on.
Nov 05, 2009 | Canon PowerShot A530 Digital Camera
How do i set the time and date to stamp on my pics for canonsd870 is
hi the following procedure is to set the date and time...
just do the following steps carefully.
1. Push the function/set button. Press the directional button down to select Date and Time.
2. Push the directional button to the right then down or up to set the date and time. Then press the function/set button to save it.
Then: to put the date and time on your pictures,
3. Push the selector button up to the camera icon, and press function/set. Scroll down to Date Stamp.
4. Scroll right to turn on the Date and Time Stamp, then up or down to until it says On.
Press function/set when your done.
That is your solution.after u set the date/time stamp is embedded in a picture, you can't take it out. ...
thank u
rate me
Jul 20, 2009 | Canon PowerShot SD870 IS Digital Camera
I DONT WANT MY CAMERA TO HAVE A DATE...IT SHOW WHENEVER I PRINT MY PHOTOS. HOW CAN I REMOVE THE DATE? PLS. HELP.THANKS
hi the following procedure is to set the date and time... just do the opposite of dis and ur date and time will be removed..
thank u!!!!
May 26, 2009 | Canon IXUS i7 Digital Camera
Date Settings
Hi there and thanks for coming to FixYa.
To put the date and time stamp on the images do this:
1) Set the Mode dial to Setup.
2) Hit the Up arrow on the control button to Camera and hit the right arrow on the control button.
3) Select Date and Time with by hitting up or down arrow on the control button then press right on the control button.
4) Hit the conrol button up or down to select Date and Time, then press the center of the control button.
5) Return the Mode dial to the camera postion to start taking pictures.
Rob
Feb 28, 2009 | Sony Cameras
Canon sd 750 how to put the date in the picture?
here is the solution:
The date and time can be included on the pictures taken only with the camera in postcard mode. You must also activate the date stamp option in the menu.
To set the camera into postcard mode, press the [Func.] button on the camera, then use the [arrow down] key to go down to the last option in the menu, and there you can choose the [Postcard mode]. Press [Func.] again to exit the function menu.
To set the date and time stamp, press the [Menu] button and then use the [arrow down] button to go to the [Date stamp] option in the menu. You can set this to "Date" or "Date & Time". Press the [Menu] button again to exit the menu.
dsc_include_date02_tcm14-520511.jpgyour date and time are set now
congratulations!
Rate this answer if it is working with you
thank you
with all my best regards
huetrichard@gmail.com
Feb 25, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
How to make date stamp option ON in Canon IXUS70 Model
Hi there, my name is Rob and I can help you.
To put the date stamp in a picture do this:
1) Make sure you have the correct date and time set in the camera. To do this:
Then:
2) Push the selector button up to the camera icon, and press function/set. Scroll down to Date Stamp.
That is your solution. Remember once the date/time stamp is embedded in a picture, you can't take it out.
Let me know if you have any further questions, and thanks for coming to FixYa. Please feel free to rate my solution a fixya.
Rob
Feb 19, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
TZ 5 not TZ50! Date stamp.
I have the same camera and the only way to do this is to first, Make sure you have set the date and time correctly on your camera. Take a picture or, view picture you want date & time stamped. Press the circular 'Menu/Set' button. Press down arrow to playback mode. Press right arrow on 'text stamp'. Choose whether to apply stamp to single or multiple photos. Press 'Menu/set' to select photo to stamp. Choose which stamps to add. Date, time, age etc.. Press 'Menu/set' again and select 'Yes' in box. The only problem with this is that it will resize your photos to 3m, which can make them grainier if you took them at a higher res. Gillian
Aug 30, 2008 | Panasonic Lumix DMC-TZ50 Digital Camera
Time/Date Stamp Problem
I'm sure you have done this already, but you have make sure you press the OK button after all the fields are set. Something else, make sure the batteries are new and charged.
For printing the date/time...
  1. Rotate the mode dial to A, P, SCENE, Tv, Av or M and turn on your ViviCam 8400.
  2. Press the menu button, then use "right" to select Mode 3 menu.
  3. Press "down" to select the Daet Imprint and change it to ON.
  4. Press the OK button to make this permanent.
  5. Then press the menu button again to exit the menu.
After this, all pictures will print with the date, and cannot be removed.
Hope this helps, if it does, please choose FixYa!
Dec 04, 2007 | Vivitar ViviCam 8400 Digital Camera
Sony Cyber-Shot DSC-P71 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
