Question about Toshiba Televison & Video
Bad fuse - Toshiba Televison & Video
    Guru:
  • 1,738 Answers
You can try usually if a fuse is blown it could be something serious. Fuses are cheap to buy and if it does take care good for you.
Posted on Nov 20, 2009
SX4 2.0. Replaced alternator. Why isn't it charging?
could be a fuse in the circuit blown, bad wire , bad earth (ground) , faulty regulator if it is not in the back of the alternator
Oct 10, 2015 | Suzuki Cars & Trucks
Headlights won't turn on
Five most common possibilities:
1. The headlight bulbs are burned out
2. Blown fuse or fuses
3. Bad lighting relay
4. Bad light switch
5. Bad electrical connection; could be a bad ground, bad connection in a plug in the harness, bad connection to a switch or relay, wire worn through the insulation and causing fuse to blow
Feb 03, 2015 | Cars & Trucks
Digital display for weather and copass is out
check fuses
you blew one. if it is keeps blowing , that feed line has a short.
use voltmeter at fuse,
or remove the suspect fuse, and use ohms, 0 ohms good, infinity bad.
if fuse looks bad, it is
if fuse looks (eyes) good, it can in fact be bad.
Apr 06, 2014 | 2000 Jeep Grand Cherokee
Dash light went out, but all other lights are still working, don't know what wrong? Maybe a bad switch to the dash? Or fuse? Help!
Check all your fuses, one at a time with a continuity tester. Replace each fuse before you remove another fuse so you will not put the fuse in the wrong place. Also, if you find a bad fuse which you can purchase at an automotive parts place, make sure you replace the bad fuse with the correct amperage fuse. Do not go up on the replacement fuse amperage. The amperage number is on the fuse handle. You can buy a very inexpensive continuity tester at radio shack and they will teach you how to use it. Good luck.
Dec 03, 2012 | Cars & Trucks
Location of the turning signal fuse
GET A GOOD FUSE TESTER, TEST EVERY FUSE. 2 BOXES ONE UNDER THE HOOD & ONE INSIDE THE VEHICLE. THE FUSES HAVE TEST POINTS FACING OUT. POWER ON ONE SIDE, BAD FUSE POWER ON BOTH SIDES GOOD FUSE, POWER ON NEITHER SIDE, SPARE FUSE.IF THE FUSES TEST OK, YOU MAY HAVE A BAD FLASHER, OR BAD TURN SIGNAL { COMBINATION } SWITCH.
Jan 06, 2011 | Daewoo Lanos Cars & Trucks
Model 2002 the horn doesent work
3 possible problems, Horn is bad, fuse is out, wires fell off.
Locate horn in car, and check the wires leading to it. If they are attached, then check the fuse box. The fuses are labeled under the lid. Check to see if the fuse is bad. Remember fuses are themselves not bad, so if another fuse blows, there is a problem with the wiring or the horn is bad.
good luck and don't forget to vote!!!
Oct 10, 2010 | 2002 Honda Civic
My gas gauge is not working.
One of three things. Bad fuse, loose wire, bad gauge, or bad sending unit (located inside of fuel tank)
Sep 09, 2010 | 2002 Buick LeSabre
200 chevy blazer 4x4 is not workin it is push button and the indicator lights dont light up at all
Check the fuse in the fuse box first and replace if the fuse is bad. If the replacement fuse goes bad again, check the wire harness at the encoder motor on the transfer-case. Look for any damages causing a short making the fuse to go bad, once the harness and connectors are good. Inspect the encoder motor, check to see if it's not the problem causing the fuse to go bad and if it is. Replace the encoder motor, good luck and keep me posted.
Feb 21, 2010 | 2000 Chevrolet Blazer
Fuses part 2
If the fuse is bad get the ratings off fuse and go to radio shack. Cost under a dollar, In fact bring the bad one with you.
Mar 05, 2008 | RCA P60920BL 60" Rear Projection...
Televison & Video Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
