Question about Whirlpool Duet GHW9150P Front Load Washer
Dryer is not getting hot its a whirlpool duet?
  • 491 Answers
IT SOUNDS LIKE THE HEATINGS ELEMENTS HAS BURNT OUT REPLACE THEM AND YOUR DRYER SHOULD WORK FINE.
Posted on Nov 20, 2009
I have whirlpool duet gas dryer. It is leaving brownish moon shaped streaks on my white clothing. I have looked inside and cannot find anything that looks like it is causing this. Can you help?
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 15, 2011 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
My whirlpool duet electric dryer will turn on run for a minute than turn off and smells hot
Check the dryer vent,some times they will get stopped up with lint causing the dryer to shut off on high temperature.
Mar 03, 2011 | Whirlpool GEW9250 Electric Dryer
Whirlpool duet dryer, dryer gets to hot, even on delicate cycle, clothes to hot to touch
may be the heat sensor(around 10Kohm) or the heater relay on the control stuck in the on position.(new control)
Oct 29, 2010 | Whirlpool GEW9250 Electric Dryer
My whirlpool duet is not drying....it is not getting hot. It appears to be drying but it is not getting hot. I have to run the dryer multiple cycles.
Check for crimp in your vent line, Check your breaker. It is a dual breaker if one side pops it will run with no heat. Check those first.
Aug 22, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
I have A whirlpool duet dryer and it is getting hot but taking about 3 hours to dry a small load of clothes... my landlord has come and cleaned the vent from the outside... Could it be a heating element?
I would check behind the dryer to see if the vent is crushed. Everytime you lean against the dryer there is a chance of crushing the elbo on the back of the dryer restriction air flow. Very common problem.
Oct 06, 2009 | Whirlpool LAB2700ML Pedestal Drawer for...
My Whirlpool duet dryer is getting too hot
YOU NEED A NEW THRMO KIT
STEVE'S APPLIANCE
516-300-3249
Mar 15, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool Duet Dryer is scorching clothes
there is a sensor in the exhaust line in the dryer, near the motor. this tells the heating element to shut off when it gets to a certain temp, either during reg cycle or if the exhaust gets clogged, it is meant as a safety measure, but it sounds like yours is bad so the heating element never shuts off. it is not an expensive part and easy to replace
Oct 27, 2008 | Whirlpool GEW9200L Electric Dryer
Whirlpool Duet Electric Dryer will not get hot
Here are the source codes that pop up on the dryer with the "fix" PF Power failure "PF" flashes to indicate that a power failure occurred while the dryer was running. Press HOLD TO START to continue the cycle, or press OFF/Pause to clear the display. E1 Thermistor open Replace thermistor if found defective E2 Thermistor shorted Replace thermistor if found defective
Sep 12, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
167 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
