Question about Measuring Tools & Sensors
How to install a 3phase power meter device - Measuring Tools & Sensors
  • 5,603 Answers
The three phase power meter will have sensors or terminals to run TWO of the three load leads through. In addition you will have a voltage input or two.
The exact connection will depend on the model of your device.
Only two load leads are needed since the third will have the sum of the other two leads (including the phase angle in the sum).
Posted on Nov 20, 2009
3phase to 1phase transformer
when your dealing with a high leg as long as your using two phase wires it is balanced. any two legs will give you 240 volts a.c.
Aug 29, 2015 | Heating & Cooling
Im trying to wire up a 3phase 480 volt contater with a 120 volt coil contacter didnt come with any drawings not sure how to wire it up using a remote start stop button
If you are trying to wire the coil only you wire it just like a light bulb and the light switch would be for remote operation. The 3phase power in will go to T1,T2,T3 and your load goes to L1,L2,L3. If you are working with a starter and not a contactor the hookup is different. A starter is a contactor with an overload attached to it. A starter hook up is too difficult for me to explain in this format and I would suggest getting someone to do some hands on instruction. Hope this helps, good luck.
Oct 13, 2014 | Heating & Cooling
Just bought a s8000 3phase, straight petrol pramac generator, can I run my large 3 phase mixer and a 240v hand whisk at the same time?
Look at the name plate ratings on your devices, they should give you the KVA load of the device. Add all of these up. If the load exceeds the output of the generator, then it wont work
Sep 17, 2014 | Electrical Supplies
Wiring diagram for Dayton IKRT9 portable electric heater
Sounds like it's the on/off switch.
what colour are they. . Usually one is the power supply to the switch and the other will be the return from the switch to the load.
Check these wires with with a multi meter.
Jan 06, 2014 | Kitchen Ranges
Sorry bought magnum compressor 3phase but also runs 240v cannot get it to run on 240v any info would be realy helpfull ta Peter
if you have a 3phase motor it will only run using 3 phase power no matter what voltage or you can get a phase converter but they are pricey and varies with what horsepower your motor is
Oct 19, 2010 | Magnum Air Tools & Compressors
I have a 3phase electric motor 440 v amps.7.6 and drive thats 440
Allowing for start up current I would put a 16amp 3 phase breaker/trip in circuit. If this trips then use a 20amp.
Aug 01, 2010 | Heating & Cooling
Only have two phase power power company refuses to install three phase can i run my hobart h600-t mixer serial#31-1068-582 ml# 104385 with just two phase?
first thing, there is no 2 phase pwr. there are only single phase or three phase.you have 2 choices either you can convert mixer from 3phase to 1phase which will be expensive, or you can get a rotophase which will make 1phase pwr to 3phase pwr to run mixer, dont go with static phase inverter, only the rotophase inverter
Jan 19, 2010 | Hobart H600 Stand Mixer
How do I wire a 30amp 3phase 250 volt receptacle for proper phase rotation ie x,y,z on the device with phases a,b,c in the panel?
You will either need a phase rotation meter to identify the rotation, or, if it is a motor, reverse any two leads to spin the motor the opposite direction (this works on single phase, too).
i hope this is helpful
matthew
Oct 31, 2009 | Gb Electrical 1 30 Amp Ground Fault...
Converting from three phase to single phase
Do you want to convert 3 phase to single phase?What voltage do you currently have (220v 3phase)?
May 07, 2009 | Kitchen Appliances - Others
Wrong voltage rating
Hello. If the unit is rated 460v, 3phase, the only way you can get it to meet your supply of 208v, 3phase, is:
a) have a transformer installed to make 460 from your supply by an electrician, or call your power company and see if 460 could be supplied to your building, but it would only be for that machine.
or
b) replace the heating elements for the 208v supply, have the pump motor checked to see if it will work on 208v, and a control transformer for the control circuit, as well as all the wiring related to the pump and heaters, as on 208v, they will draw more current than on 460.
so, can it be done? yes. Is the expense worth it? only you can answer that, However I would suggest that you resell that machine, and get the correct one from the start.
Hope that helps, and thank you.
Feb 16, 2009 | Jackson 25 in. TempStar HH Free-standing...
Measuring Tools & Sensors Logo
48 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
