Question about Whirlpool SB160PEE Gas Single Oven
Took the oven door off and now cant get it back on
  • 5,603 Answers
Typically one cannot fight the hinges while putting the door on.
USUALLY you can move a hinge down/open and there is a hole to put a nail through to hold each hinge down while you get the door in place.
Posted on Nov 20, 2009
Testimonial: "yes thanks was easy once i knew the trick"
Took maytag oven door off to clean cannot get it back on hinges will.not stay open and keep.snapping back fingers r sore took a pipe to pull them back but they wont stay How do I keep them from snapping...
It is a two person job unless you want to pull the whole stove out and take the cover off and then remove the springs. Put the door back on and put the springs back and the put the cover back on.
Oct 10, 2014 | Ovens
Bulge plate touching new element- will this be a problem?
as long as its not touching door or rack should be fine
Sep 25, 2013 | Belling XOU252 Electric Single Oven
Took apart glass oven door on a whirlpool. Where
Hello, bd_lft_up.gif bd_top_bg.gif bd_rt_top.gif bd_lft_bg.gif OVEN DOOR bd_rt_bg.gif bd_wpl_oven_door1.gif bd_wpl_oven_door2.gif clear.gif bd_lft_btm.gif bd_btm_bg.gif bd_rt_btm.gif Oven Door
#1 -- Oven door liner
#2 -- Oven inner glass
#3 -- Oven door hinge
#4 -- Retainer, glass
#5 -- Bracket, handle
#6 -- Door glass seal, top
#7 -- Door glass seal, side
#8 -- Oven outer door glass
#9 -- Door handle
#10
Read more: http://www.appliancepartspros.com/bd_whirpool_oven_parts.aspx#ixzz0pj5Z78oi
http://www.appliancepartspros.com .
Hope this helps.
Thanks
May 30, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Cant get griller door back on
If your prob has not been solved yet, try this solution.
In your browser bar type in youube.com
Then in the sesrch box type in fitting oven door hinge
Click on appropiate video and follow instuctions.
This should help.
Plz rate my solution.
Thanks.
Dec 22, 2008 | Ovens
Can't get the door back on the oven
Yes, take a pair of pliers to pullout the hinges. They are springloaded and it seems hard but they are designed to keep the door shut tight.
Nov 30, 2008 | Kenmore 47783 Electric Single Oven
Whirlpool oven door
The metal bars go under the top door handle part, put them under the part you need to screw back in.
Sep 15, 2008 | Whirlpool RBS245PDS Electric Single Oven
Smeg se375mfx5 / stainless steel
i suspect you took the door off without locking the hinges
you will have to put the hinges in the lock position before putting back.
lay door on a blanket with hinges upwards. force the hinges back and bring the locking arm up to lock the hinges.
this requires considerable strength
Jul 05, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Smeg Double Oven SD08
this can be hard to do as you should have locked the hinges with the door fully opened before taking it off. the hard part now is (with the door off) you have to push the spring loaded hinges down and lock them with small hook located on each hinge once locked the door will go back on the oven. you then open the door fully and unlock the hinges, good luck
Feb 17, 2008 | Smeg DO81CSS Electric Double Oven
Whirlpool double oven rb130pxv
As long as you line up the hinges with the receptacle in the door, it should slide right down. Try a shot of WD-40 on both.
Sep 08, 2007 | Whirlpool RBD305PD Electric Double Oven
Oven Door
http://www.repairclinic.com/0088_13_1.asp.... good luck
Aug 06, 2006 | Kenmore 30169 Electric Single Oven
Whirlpool SB160PEE Gas Single Oven Logo
175 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
