Question about Acer Aspire 4520-5582 Notebook
My aspire 4520 will not turn on.Battery is good & the green led light comes on but not the power pack light, but still won't turn on. Have tried taking battery out unplugging power to reset everything still no joy, didn't drop it, was using it ok had lunch came back to it & it had turned off & won't turn on .Help please.
  • robtracy1 Nov 20, 2009
    Would like to add that the green light comes on , on the power pack but not on laptop.
    Brigadier General:
  • 4,090 Answers
Check the power plug as it may have thrown a fuse in that circuit try a power plug you know works( plug in a lamp in to check it)
Please rate my help++++Thanks for using FIXYA
Posted on Nov 20, 2009
  • dennis bullard Nov 20, 2009
    having the green light on the pack does not guarantee it is outputting power to the unit. If you can access a multimeter checjh the centre pin and trhe outer of the plug to LaPTOP to see the output power . compare this with thye specs on the back of laptop 5V input or 12v input.
    I would still try it in another part of the circuit of where you are or plug a working device into the same plug to ensure fulkl power is being delivered to the transfoirmer.
    Your transformere may be faulty.. also check that the plugs are in firmly at transformer end
My acer aspire 5735z won't switch on.
Solution posted in your latest post,
http://www.fixya.com/support/t11566511-acer_aspire_5735z_doen_39_t_turn_just
Feb 03, 2012 | Computers & Internet
I have an acer 4520 lap top. I can't get it to power up at all. When I push and hold the power button the green light comes on around the power button and the three lights in the upper right side flash...
first remove your battery and try to switch on your laptop with good power adapter if still have the same issue ?? just remove your memory and reinstall after clean your memory if still have the same issue ?? remove your memory and cmos battery and switch on it with a good power adapter.after 2 minute you can re install back your memory and cmos battery and try to switch on it.
Sep 14, 2011 | Acer Aspire 4520-5582 Notebook
I have been using my Acer Aspire 4520 laptop for four years. Recently while working, it turned off abruptly, and when I tried to restart it, it didn't turn on. Upon pressing the power button to start...
Have you come up with a solution yet? Mine does the same exact thing nothing seems to be helping. I'm at a loss here and I feel helpless, and hopeless!!!
Sep 10, 2011 | Acer Aspire 4520 Notebook PC
My Acer make Laptop model: aspire 4520 not power on , power led and dvd led flashes at the same time and screen blank.
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
4. The power button could be bad.
5. The motherboard could be defective & needs to be replaced
Sep 11, 2010 | Acer Aspire 4520-5582 Notebook
I plug my ac adapter in my laptop usually when you charge it turns the battery light in red then after few seconds turns to green! do you think the charge is not working?
Hello my friend this looks like a battery problem or a bad connection between DC-IN power jack on the system board,first try to wiggle the power cord and if power LED and battery charge LED start flickering then is the DC-IN power jack`s problem ,if its not is battery problem and you should change the battery
I'm waiting for your response
Good luck my friend:)
Jan 27, 2010 | Acer Aspire 4520-5950 Laptop
My acer aspire won't power up
Try to connect your PC with the battery on the power outlet if it lights and charge normally. If the lights still orange, try to open the hard disk case and pull it out then try to put it in place again. If still doesn't go, try the memory card and clean it.
But I suspect that the battery has been overly charged. Try to look for another battery of the same model if it works with another and new battery.
Thanks
Nov 27, 2009 | Acer Aspire 4520-5582 Notebook
Green & Yellow light on 14.4V charger
It sounds like your battery is bad.
If both yellow and green LEDs come on, this indicates
a deeply discharged or defective battery pack.
Allow the battery pack to remain in the charger for 15
to 30 minutes. When the battery pack reaches normal
voltage range, the red LED should come on. If the
red LED does not come on after 30 minutes, this may
indicate a defective battery pack and should be
replaced.
n After normal usage, a minimum of 1 hour of charging time
is required to fully recharge battery pack.
Nov 24, 2009 | Ryobi Multi-Volt Battery Charger
I have a acer aspire 4520. It is not powering up. When the power switch is pressed the hard drive and wifi switch light up for a fraction of a second but nothig happens at all. I can't hear the fan...
Just check the battery pack normally this occurs when the battery pack got exhausted
Thank You
Please rate me as it will be just one CLICK
Don't find fault, find a remedy. - Henry Ford
Oct 23, 2009 | Acer Aspire 4520-5950 Laptop
Hi Hoping some one can help me I have an acer
U ARE HAVING PROBLEM WITH UR POWER CORD OR YOUR BATTERY
Jul 15, 2009 | Acer Aspire 4520-5582 Notebook
Acer Aspire 4520-5582 Notebook Logo
623 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
