Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE frig just starting leaking water at the bottom of the freezer side door
GE SIDE BY SIDE frig just starting leaking water at the bottom of the freezer side door
  • 6 more comments
  • NONICKNAME6 Jan 12, 2008
    No drain
    I think its from the tube that goes up the door at the lower hinge to the water thur the door but how do you open the door panel to look in side
  • Anonymous Jan 14, 2008
    clog drain
  • Anonymous Jan 15, 2008
    Same problem, Appears the drain is restricted. I did not see the solution on how to clear the drain
    How do I clean the drain tube?
  • fixen-jeff Jan 22, 2008
    I have an older GE side by side. It could be the drain in the bottom of the freezer, but also the water / ice dispenser has no drain just a plastic crome plated grate covering a depression to hold a little water that may over flow from a glass. Not knowing the kids were playing in the water and filled the little depression so when you opened the freezer door some ran down the front of the door, but looked like the bottom of the door was leaking. Just a thought.
  • aakhan9 Aug 16, 2008
    my Ge side by side is leaking water from the bottom. I clean it and it keeps on draining every few hours.
    what should i Do?
  • jlrg71 Feb 27, 2009
    GE Refrigerator on freezer side is causing the issue. Ice is frozen on the bottom under the bin and starts to defrost at the edge and leaks out onto the floor.
  • nbctcte Mar 29, 2009
    I have water buidling up and then freezing at the bottom of my freezer causing the door to not close all the way at times and then the excess water will spill onto the ledge underneather the doors. This has been an issue since have the side by side. Any recommendations for correcting the problem. Thanks.
  • Anonymous Mar 16, 2014
    ge tfh22jr leaks water on the floor intermittently under the freezer door.
The water on the floor below the freezer door is due to an inadequate door seal. The door is not closing completely, either a foreign object at the bottom, or more likely, the freezer door gasket needs replacing.
Posted on Aug 25, 2008
    President:
  • 1,314 Answers
More than likely you have a frozen defrost drain look in the bottom of your freezer section there should be a depression there see if its just a big block of ice let me know if this is the case or not and ill tell you how to clear the drain if not then we will look at something else please dont rate me till were done
Posted on Jan 11, 2008
  • David Fleming Sep 26, 2012
    Robert, thank you for your reply. I do not see a drain in the freezer area. Is it hidden somewhere?? def
There is a hose that attaches to drain hole in bottom of freez. remove from back after taking cover off. i found needle nose vise grips work well. it's tight fit and awkward just be patient and don't break fitting for water filter like i did.it plugs w/ food, dust...........chip away ice and that should do it.
Posted on Oct 11, 2010
  • 1tepeee Oct 11, 2010
    you need to remove clamp thus vice grips. try the hot water first see if that works.
If water is coming out from door seal,check for ice under bottom basket in freezer,then defrost drain is plugged either inside or outside of freezer.UNPLUG fridge from electricity!! Clear drain with hot water from tap pouring it threw grill holes @ lower back of freezer.It may take a few minutes to thaw.
If there is ice on back WALL of freezer,see if it leads upto the icemaker hence either icemaker filltube is leaking or the icemaker itself is leaking
If water is coming from door hinge & you have a water dispenser the leak maybe the plastic tube in the hinge area,repair as needed.
If water is coming from dispenser down front of door,check the ice shute door & make sure its closing all the way.
Finally check to see if water dispenser is dripping,this can be caused by air in water resivour if dispenser isn't used vary often or the fill valve can "weep" when it gets old & tired & needs to be changed
Posted on Feb 28, 2009
How do I clear the frozen drain in the bottom of freezer?
Posted on Apr 06, 2008
How do I clear the frozen drain in bottom of freezer? I think this is my problem.
Posted on Jan 23, 2008
My GE Profile side by side fridge freeze the food in the bottom draw. I have set the temp to 43F but keep the fridge at 34 or colder. It frooze the water lines and tank in the fridge several times. What am...
You probably have a sensor issues there are two one for the freezer one for the frig. Check your freezer temp it should be at 0 degress at manufactor setting. If the temp is below -10 you freezer sensor is bad. Otherwise your frig sensor is bad. CHECK FREEZER FIRST!!!
May 27, 2011 | GE Profile 25.5 Cu. Ft. Side-by-Side...
GE side by side, GSS22UFMWW, water dispensor does not work, when I try it water leaks from the bottom of the frig. I can hear it pumping.
Turns out there is actually a small drain hole on the bottom of the freezer where condensation and such goes. Take out your bottom drawer/shelf and look in the back of the freezer.
Pulled out the bottom white tray that is under the wire shelving and at the back of the freezer is a small hole. Pour in a cap full of bleach and then 1 cup of boiling water. There can be condensation builds up and clogs the hole.
Sep 09, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Side by side frig/freezer. Freezer auto defrost
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Jul 03, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Water leaking from outside bottom
the waterline going in the freezer door may have a hole take the kickplate off while looking underneath use the water in door to see if any water is leaking from that tube
Apr 27, 2009 | GE Profile TPX24PBDCC Side by Side...
GE Freezer Leaking
Open the freezer door, remove the bottom tray, smash the ice on the floor with your fist to remove it. Now get a glass of hot water and pour it into the trough which is at the bottom of the back wall of the freezer. Allow a few minutes for the ice to melt then remove it with an ice pick or scrrewdriver. Once the ice is out, pour more hot water into the trough. Now take a long tube ( an old washer fill hose works perfectly) and stick one end in the hole in the trough. Now fill your mouth with warm water and blow it very hard through the tube. Once the drain is clear, pour some hot water and a very little amount of bleach through the hole.
Apr 06, 2009 | GE Refrigerators
GE Side by Side, water leak inside freezer door
you will need to [possibly replace the solinoid valves on the backdside of the refrigerator
Jan 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side by side,water drips from bottom freezer door
I have the same problem. Just talked to a friend that's a great appliance repairman. he said I have to remove the panel in the back inside of freezer and there is a drain that gets clogged up, a little hole or tube.
clean that and should work fine and stop leaking. I haven't had time yet, but this weekend I'll do the deed. Hopes this helps ya!
Frig side is not cooling.
Check if there is frost on the back wall of the freezer, if so it is not defrosting. Many GE fridges need a new defrost heater every couple of years. If it's not defrosting, you can get by for a while by unplugging the fridge and leaving the freezer door open for 24 hrs, then plugging back in.
Jun 30, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge refrig
I have a ge profile side by side. when it auto defrosts the water runs to the bottom and out the freezer door instead of down the drian??
May 31, 2008 | GE Profile Arctica Stainless Steel Top...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
1,973 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Joe Lamb
Joe Lamb
