Question about Cell Phones
How do u put new contacts on ur sidekick id - Cell Phones
I just put my at&t sim card into my sidekick id and i can make calls but its not allowing me to go into my simcard contacts or text message or even go online help me pllleeeaaassseeee
the sim card might be similar enough to the one the phone needs that it will allow u to make calls but not anything else u might have to get a new sim card and have a prof transfer ur contacts
hope this helped :)
Mar 29, 2013 | Cell Phones
I just got an unlocked sidekick lx 2009 and put in my att sim card. I can make calls but it is not reading my contacts. what do i do?
More than likely your contacts are still located in the old phone. Replace the Sim card back into the old phone and copy the contacts onto the Sim card, place back in your Sidekick and you then can locate your contacts.
Mar 11, 2011 | T-Mobile Sidekick ID Cellular Phone
My phone deleted all of my contacts, pictures, emails, ect.
Are your pictures, contacts, etc. on the desktop interface still? Go check your desktop interface. If it is, pull the battery let it sit for a moment and place it back in. Turn on the Sidekick and Danger's servers should put your stuff back on your phone.
Sidekick ID does not have the SD card slot, so it can't be an issue with your SD card. This was the first thing that came to mind.
Hope this helps,
Bill
Oct 04, 2009 | T-Mobile Sidekick ID Cellular Phone
Sidekick id
-take a battery out for 2 mins then put it back in. -switched it on and see if the screen is visible. (dont be freak out if everything gone, it will come back in fews so give it some times to have them back up again *contacts, notes, etc etc*)
if nothing worked, then youre more than likely looking at get a new screen for sidekick id.
you can find some around on ebay for cheaper or broken id with a good screen in a good condition.
good luck and let me know if need any more assistance, im more than be glad to help some more if i can.
Feb 24, 2009 | T-Mobile Sidekick
T-Mobile Sidekick ID Unlock
1.your sim needs a password
2.turn off ur sidekick 3
3.place ur cingular card in
4.turn on sidekick 3
5.itz gunna ask you for a special code ignore it
6. go to settings den sim center
7. if ur sim lock is disabled jus enable it
8.den change ur sin pin to wateva you want
9.once u change it you will signals bars go up
10.go 2 settings network options
11. press scan scan select manually
12. select ur network
13. and datz it your sim iz workin on sidekick 3
if u turn it off u will have 2 do da same process again
Nov 09, 2008 | T-Mobile Sidekick
Switched sim card into different sidekick and lost everything?
no ure done dude , unless you try to check main sim contact might be in there
Nov 08, 2008 | T-Mobile Sidekick ID Cellular Phone
SIDEKICK ID IS BROKEN
well the problem is the sidekick not the battery i suggest using ur battery in a friends id or 2 or 3 and see if it works if it does well that sidekick id is no good
Sep 19, 2008 | T-Mobile Sidekick ID Cellular Phone
Sidekick id screen
Seems you need a new Lcd assembly i can provide you with one very cheaply please contact me at sk3repair@yahoo.com I can sen you a new Lcd or u can send me the phone for repair
Jul 21, 2008 | T-Mobile Sidekick ID Cellular Phone
Sidekick ID LCD Replacement?
well finding stores is a bit difficult and im not aware of where you live. BUt if you live in Brooklyn, NY, then downtown brooklyn on futon mall street, theres a stores which sells sidekick screens. Chances of finding an ID screen are unknown to me. By the way this store is close by Futon Mall street and Jay STreet
Jan 28, 2008 | T-Mobile Sidekick ID Cellular Phone
My sidekick3 screen is blank
If your sidekick ID or Sidekick 3 screen is a blank white, then the lcd flex cable has come loose. It is a little difficult to repair but any one can do it. The worst that will happen if you try to repair yourself is that it will not work and you buy a replacement screen from ebay for 45 dollars.
Here are the detailed instructions. Just reinstall your lcd instead of putting a new one on.
Sidekick 3 LCD Screen Only Replacement
Here is a link to find lcd screen on ebay.
Sidekick 3 LCD Lens
Oct 27, 2007 | T-Mobile Sidekick® 3 Cellular Phone
Cell Phones Logo
22 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
