Question about Xerox DocuPrint M750 InkJet Printer
Can't print when there's only black ink
Can this printer (Xerox M750) print documents with empty color tanks (and full black one...) ?thanks
  • koby Jan 12, 2008
    i got no message from windows.
    the ink led is blinking alwyas (no color, full black..)
    how can i reset the printer ?
    i remember that it works for me once..
  • koby Jan 28, 2008
    man you are great !!!
    thanks !!!
Here's a trick that worked for me - there are two tiny prisms on the back of each ink cartridge, to refelct light to a sensor indicating whether there is or is not ink in the cartridge. Simply put a small piece of masking tape over the non-mirrored prism, i.e. right next to the mirrored prisms, to make the printer think the cartridge is full of ink. Put the small pieces of tape on each of the three empty color cartridges, being careful not to cover up the mirrored pieces, as light relected from these indicates that there is a cartridge in the slot. The printer will run as if it has full black and color cartridges, but set your defaults to only print black.
Posted on Jan 28, 2008
    Master:
  • 619 Answers
Mostly it connot print w/out color ink if when printer message empty / sometimes the printer no message while ink was empty still black can print. it depends to the chip .
Posted on Jan 11, 2008
6ya staff
SOURCE:
Print black and white
try to print a document with txt only, in some model of epson even when the color ink runs out you cvan still print, i am not sure if it will work with current models of epsom
Nov 25, 2009 | Office Equipment & Supplies
I would like to print black with one color cartridge empty
If you take the empty cartridge out and put a small piece of electrical tape over the little window on the front, the printer will think the ink is full.
Jul 19, 2009 | Office Equipment & Supplies
Can't Print with black ink because all color ink are empty.
yes you need to install all cartridge before printing any page ...I have also this model...but u need to install all 4 cartdge. before printing any page wheather color or blacknwhite..
Jan 08, 2009 | Office Equipment & Supplies
Won't print with only 1 cartridge empty
sorry you can print unless all your cartridge are having some ink
Dec 17, 2008 | Epson Stylus Color 740 InkJet Printer
Help with error 1401
To print without color ink go to START>control panel>PRINTERS & OTHER HARDWARES>PRINTERS & FAXES>Right click to your printer>PROPERTIES>MAINTAINANCE>INK CARTRIDGE SETTING>then select BLACK ONLY.
I think it fix your problem.
Nov 13, 2008 | Canon MP140 PHOTO AIO All-In-One InkJet...
Xerox Phaser 6125 Color Printer
I called Xerox and it seems that it's because the imaging unit is defective. They are seeding me one free of charge. Hope you can do the same...
Sep 20, 2008 | Xerox Phaser 6125 Laser Printer
My Xerox DocuPrint M750 printer will not print black text but will print colour
This is just a suggestion. I recently bought a Staples refilled cartridge and had to return it because it did not work. When returning it the Staples Rep said that 50% of the cartridges do not work and get returned. This was an astounding amount I told the rep. Means nothing to him but to you, you may need to return the black cartridge if it is or is not a refill and try it out again. Let me know if that works.
Cynthia Charczenko
Jan 15, 2008 | Xerox DocuPrint M750 InkJet Printer
Wont print
some printers share the ink from color to black but you can select if you wants to use only black just go to printer than properies than select to use only black but you probably have to remove the empty color one
Dec 18, 2007 | HP DeskJet 3940 InkJet Photo Printer
Cannot print in black only
It is not wise to leave the cartridges empty, causes permanent print-head damage on the empty color area. However, if you want to use the other color, say "black", bypassing the cartridge check is simply resetting the counter of the printer... download the utility file "sscserve.exe" you can search it on the internet. Install it then choose your printer on its list box, then by right-clicking on the printer icon of the utility at the bottom right of your window... you should be able to see what you need. Happy printing!!!
Oct 23, 2007 | Epson Stylus Photo R220 InkJet Printer
Xerox DocuPrint M750 InkJet Printer Logo
2,022 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
