Question about Olevia 332V LCD TV
I want to use with Dish network as a 2nd tv. Previously I was able to get the satellite signal on channel 73 with an old analog CRT set. I don't get the signal on the Olivia on ch 73 - or any other channel.
  • Olevia Master
  • 8,457 Answers
Tries unplug,replug the Dish network box for updated data.
Posted on Nov 20, 2009
Dual control noted on Dish tv screen but cannot change stations separately on both tvs
Each TV receiver has to be fed with a separate cable from the lnb. They can not be bridges or split.
Mar 09, 2015 | Dish Network/Pansat Dish Network Dish 500...
Want to run Dish network DVR 2nd TV thru cable to Sharp lc-c5255u Dish uses channel 73. It was not on my TV. I did a channel search and it did not find it. It also erased all channels and I can't...
Go into the setup menu and do a channel search again selecting digital and analog channels. Then change the input type to cable and you should get your channels back.
Aug 31, 2011 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Our new vizio tv is hooked up just like our old tv, (satellite provider being dish network) and it says no signal with a blue screen
Hello. This is usually an easy issue to fix. To get the DISH Network back on the screen, i have included a few steps:
If you are at TV1, where the receiver box is located, the tv needs to be on channel 3 or 4. Depending on the cable that is running between the receiver and the tv, the tv may need to be on an input, such as video 1 or 2. If you are at the TV2 location, where there is no receiver, then the tv needs to be on channel 60 or 73.
If you are using an HDMI cable, then the TV will need to be on an HDMI input
If you are using Component cables, your TV will need to be on a component input. (Usually Comp 1 or 2)
If you are using RCA cables, then the TV will need to be on a VIDEO input (Usually Video 1 or 2)
If you are using COAX cables, then the tv needs to be on channel 3 or 4 (If you are at TV2, then the TV needs to be on channel 60 or 73)
Becki Barned
DISH Network Customer Service
Feb 26, 2011 | Vizio VX32L Television
I bought a new TV for my #2, but is says I'm not getting a signal when I hook it up to the cable. I have it on channel 60
djpeter770
You can go to TV 1 to make sure TV 2 is suppose to be set to channel 60. Did you run the auto setup on your TV? If you have already run the auto setup on your TV, unplug the receiver from the electrical outlet for 10 seconds and then plug it back in. This will make the receiver reboot and re-acquire satellite signal. Then see if you get a picture on your TV 2. If not, the last thing you can try is changing the channel from 60 to 73 through the receiver.
With your DISH remote at TV 1, press the Menu button - Main Menu will display on the TV 1. Then press 6 (System Setup), 1 (Installation), and 5 (Modulator Setup). On the Modulator Setup screen, move over to TV 2 Out and select Cable, then press select on the remote. This will automatically change the channel from 60 to 73. Highlight Done on the right and press select. Cancel out of each screen till you get back to the TV screen. Go to TV 2 and put the TV on channel 73. You should get a picture. I hope this helps.
Ray Calo
DISH Network
Feb 16, 2011 | DISH Network ViP622 DVR DTV Receiver /...
Trying to setup tv 2, just upgraded the tv from an old school analog set to a brand new phillips 40pfl3705d/f7. can't get a signal on the tv and have tried both "air" and "cable"...
Hi carltonmarcumy name is Mike Houston of DISH Network and for the TV2 you want the Modularset to cable and channel 73, and then make sure the TV itself is set to channel73. After you have the modular set to channel 73 and the TV set to channel 73and you do not see a DISH Network picture you will then make sure theconnections from the wall to the TV are tight as well as from the receiver tothe wall. Then you will want to unplug the receiver for 10 seconds and plug itback in it will power up and acquire the signal and once you see that check TV2and you should see the same thing on the screen. I will send a link that will helpout with these steps. http://www.dishnetwork.com/SupportSection/black-blue-tv2
Feb 13, 2011 | DISH Network ViP622 DVR DTV Receiver /...
I need to get to channel 73 to connect to Satellite Dish network, but it keeps telling me there is no channel in list ???? what do i do..Thanks
If the TV will go to channel 60 go to TV1 hit menu 6-1-5 go to tv2 out select air. This should change tv2 out to read 60 make sure you don't change the TV 1 output. Select done to save your changes and it should be resolved!
Daniel Busa
Feb 01, 2011 | Haier HTF20 20" TV
We would be happy to help with that. Some TV's are not ableto go as high as channel 73. This sounds like you're having an issue with yourTV2, this would be the TV located in a different room than your DISH Networkreceiver. Go to the main TV by the receiver, press the menu button located onthe top left of your DISH remote. Once in the main menu, press the numbers6-1-5, this will take you to the "Modulator Setup" screen. Once there we want to highlight the "Air"option located below "TV2 Out" then press the select button. TheChannel should change from 73 to 60. Change the channel of the TV you arehaving an issue with to channel 60; you should get the DISH Network programmingat that point. We hope these steps help you get that fixed. Thank you for beinga valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Oct 16, 2010 | Haier HTF20 20" TV
My RCA has a black block come up in the bottom of the screen? We have Dish Network Satellite and have programed the remote from the remote code guide. TV volume and channel changer work, but picture is a...
This has hopefully been resolved for you, but if not, here are some steps to go through. The black box that comes on the screen is usually signaling that closed Captioning is activated on the tv. Closed captioning does not run through the DISH Network receivers, so you can turn that feature off in your tv settings. The fuzzy picture could be a few things. You will want to check that all of your cables on the back of the receiver box and tv are tight as possible, and also make sure that the tv is on the correct channel. If you are in the room with the receiver, the tv will need to be on channel 3 or 4, and sometimes an input; usually video 1 or 2. If you are in a number two room, where there is no receiver, than you want to make sure that the tv is on channel 60 or 73. I hope that this helps!!!!!
Becki Barned
Sep 11, 2010 | RCA F36650 36" TV
Setting up 2nd television for dish network receiver
You have to check the modulator setting (menu 6 1 5 ) if tv 2 is set for air then tv needs to be on 60 cable it is 73. check tv2 if it goes to 73 and the modulator is set for 60 change modulator to cable 73 and tv should work fine
Jun 02, 2010 | Sansui DTV2760 27" TV
Toshiba 36a41 television
You should be able to use your remote control to do this.Your channel 73 is more than likely UHF 73 so you need to put your tv in the antenna setting rather than cable setting. Once you do this just input 73 with your remote. Hope this helps! Stargazer
Jan 21, 2007 | Sony KV-36XBR250 TV
Olevia 332V LCD TV Logo
222 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
