Question about Electric Jazzy 1115 Power Wheelchair
My jazzy 1115 joystick controller flashing and the chair doesnot move .
  • 4 Answers
Look on jazzy web site for lockout procedures.I have seen people accidentally engage the lockout thru the joystick.It is a simple procedure
Posted on Nov 21, 2009
  • 29 Answers
1. make sure it's not still pluged in recharging.
2. make sure both free wheel levers are engaged.
if the jazzy is still flashing and not moving refer to the flash code in your owners manual. count the flashes between pauses. get back to me if you don't have the manual. Mike
smithrm70@hotmail.com
Posted on Nov 20, 2009
Blinking yellow wrench light on pride jazzy 614 HD
Your version has a Dynamic Controls model controller and joystick.
Unplug the charger and engage the motor/brake lever so the chair is no longer in free-wheel mode (con't push by hand)
Turn the chair off, wait 5 seconds, turn the chair back.
If chair still does not run and your wrench is flashing you have a problem. Count the wrench flashes - the flash count indicates the error detected. 3, 4, 5, and 6 flashes indicate and error with the motors.
3=Left motor fault
4=Right motor fault
5=Left brake fault (may not be engaged)
6=Right brake fault (may not be engaged)
Any other fault code usually means the electronics or wiring is bad and not worth fixing.
Jan 06, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
Jazzy 614HD will not move. Lights flash from right to left, then cuts off. Unlock instructions are not effective. Chair is fully charged.
If chair has a tilt, recline or lift seat on it it may be going into lock-out mode on its own due to a limit switch fault. If you don't have any of these options then I suggest you remove the joystick, controller and any wire harness between the two and send them to a shop like mine for repair.
The usual lock out light chase is from left to right - not right to left so this is suspect of a different issue.
Dec 28, 2012 | Pride Jazzy 614 Hd JAZZY 614HD
Pride jazzy 600 power wheelchair controller lights flash
make sure the motors are not disengaged, turn off chair, can you move it by pushing it? if so lock the wheels and try again. next is the controller in lockout. press and hold the on button till it beeps push joystick forward til it beeps pull it back til it beeps turn off try again. you can call 1-800-800-8586 for tech support
Sep 28, 2012 | Pride Mobility Products Pride Jazzy 600
I JUST PURCHASED A JAZZY WHEEL CHAIR AND IT IS I THINK 2003 MODEL WHEN TURNED ON THERE ARE 3 RED LIGHTS AND 4 YELLOW LIGHTS FLASHING AND NOTHING HAPPENS
the 7 lights indicate a joystick problem which means the joystick/controller will have to be replaced since there is no self repair fix Unless you can locate a good used joystick/controller for cheap (around $600.00 rebuilt) I would return the chair and get my money back Hope this helps
Jun 20, 2011 | Pride Jazzy 1103 Ultra Standard Power...
CONTROLLER LIGHTS UP OK AT START. BUT IF U MOVE THE JOYSTICK, ALL THE LIGHTS FLASH RAPIDLY AND IN UNISON. WHAT FAULT DOES THIS REPRESENT?? THX U
I think you might have a joystick fault but first make sure that the chair is not in freewheel. If the chair is not in freewheel then you have a joystick problem and it will have to be replaced Hope this helps
Feb 12, 2011 | Pride Mobility Products Jazzy 1170 XL Plus
Put in new batteries chair still will not move
Does the lights on the joystick come on? If not you probably have the batteries wired wrong check that red on red, black on black. There should be a wiring diagram under the shroud check to make sure it is correct. If the joysticks comes on make sure that you are not in freewheel
Aug 18, 2010 | Electric Jazzy 1115 Power Wheelchair
Jazzy 115 will not move. Controller has 3 red and one amber bar flashing
Pride doesn't make a Jazzy 115. Please check your chair and owners manual to get the correct model so we can help. How old is the chair? The flash codes you are getting depend on the model, year it was born, and the tkype of controller installed.
Also, the flash code should be literally, flashes. 2 lights flash twice, stop, then go again, etc. They all mean something, so repost with more info please.
Jul 07, 2009 | Electric Jazzy 1115 Power Wheelchair
My Jazzy select wheelchair does not run
you move the joystick and can hear something quicking in the motors
May 17, 2009 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
Jazzy 1121 power chair won't go
If your chair is run by a Pilot VSI controller, the error code----3 red/4 yellow/ 1 green---indicates a controller failure. I am having controller problems of a different kind on a Jazzy 1107 and it appears that few shops will work on the controller. Replacement is very costly.
Apr 12, 2009 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
The chair just died and the key lock symbol is blinking and it wont turn on
sounds like the joystick is locked out. try pushing and holding the on/off switch for 5 seconds
Jan 01, 2009 | Electric Jazzy 1115 Power Wheelchair
Electric Jazzy 1115 Power Wheelchair Logo
601 people viewed this question
Top Electric Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you an Electric Health and Beauty Expert? Answer questions, earn points and help others
