Question about Bissell Vacuums
Brush not rotating - Bissell Vacuums
  • 65 Answers
Depending on the type of vacuum drive system, you either need to replace the drive belt that attaches to the roller brush or the drive gears. What type of vacuum do you have?
Posted on Nov 20, 2009
Why does the rotating brush not work ?
Check to make sure rotating brush is turned on and check for broken or worn belt
Sep 02, 2014 | Electrolux Vacuums
Spinbrush not working on eureka as1104
If the belt is intact, the brush roller ends may be so jammed (usually with hair) that it cannot rotate. Also, if the brush roller cannot rotate, the motor shaft may be rotating in one spot on the belt and eventually will burn it out. The solution in the case of the brush roller is to remove it and check for free rotation. If the ends are binding, the brush roller will have to be disassembled to remove debris.
Aug 10, 2014 | Eureka Vacuums
My brush is not rotating
Hi there, it's Jack at Dyson.
I'm sorry to hear your DC33's brush bar is not rotating. This is likely to be because the brush control on the cleaner head has accidentally set to 'Hard floors'. In this mode, the brush bar will not rotate. Please recline your machine into the vacuuming position, turn it on, and make sure the brush control is set to 'Carpets'.
I'm confident this will resolve the issue, as using and replacing the wand will not have any effect on the function of the brush bar. It's also important to note that the brush bar will never rotate when the machine is standing upright.
If you would like further assistance after you've checked the brush control is correctly positioned, please get in touch with us directly. You can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Jul 21, 2013 | Dyson DC-33 MultiFloor Upright Vacuum...
Brush bar doesn't rotate.
Either the bearing in the rotating brush is bad and isn't allowing the brush to turn, or in the majority of cases, the belt is broken.
May 20, 2012 | Vacuums
Carpet brush not rotating
Did you check the drive belt for the roller? If not do so, the smell was the belt drive burning up.
Jan 16, 2012 | Kenmore Vacuums
Belt replace panasonic vac
Is it an upright? On mine it's very simple.
Unplug vacuum and lay it on floor so that you are looking at the rotating brush. Remove screws that attach the cowling. Remove the cowling. You will then see the rotating brush ends. One end will have the belt, or what's left of on the brush wheel. You will also see the motor shaft. The belt goes between the shaft and the brush wheel. Carefully remove the brush by holding both ends and pulling straight out. Place the new belt on the brush wheel and replace the brush. With the belt on the brush wheel, stretch it to fit on the motor shaft. Rotate the brush to make sure the belt is riding correctly at both ends. Replace cowling and screws.
Nov 29, 2011 | Vacuums
Brush roller not spinning. belt, spindle okay. roller taken out and cleaned, no thread. replaced but no dice. ???
Use only BISSELL Style 10 Replacement Belts (#32074) in your BISSELL PowerForce Bagless.
  1. Unplug cleaner from electrical outlet.
  2. With Rotating Floor Brush removed from vacuum cleaner, grasp old Drive Belt and remove from Motor Pulley. Discard old Drive Belt.
  3. Place new Drive Belt over Motor Pulley and stretch other end over Rotating Floor Brush in the space between the bristles.
  4. Place ends of Rotating Floor Brush down into slots on sides as shown.
  5. Turn Rotating Floor Brush by hand several times in the direction of Motor Pulley. If properly installed, Drive Belt will center itself on Rotating Brush.
  6. Reposition Brush Cover and snap back into place. Check to be sure all three latches are secured.
  7. When you turn on the vacuum, do you see the motor that spins the belt spinning at the bottom? If not, it sounds like you may have a burned out motor.
If suggested solutions do not correct the problem, call:
BISSELL Consumer Services 1-800-237-7691
Monday - Friday 8 a.m. - 10 p.m. ET
Saturday 9 a.m. - 8 p.m. ET
Jun 01, 2011 | Bissell 6594 PowerForce Bagless Upright...
Need to replace belt and cannot figure how to take it apart to get at the belt --- Took Screws off on the bottom but could not get to the belt
You have already removed the screws so lift the brush cover off. Then grasp rotating floor brush at both ends and lift. Clean strings,hair and other debris from rotating brush, paying close attention to the brush ends. Clean the debris from motor pulley and drive belt areas.Grasp old drive belt and remove from motor pulley. Place new drive belt over motor pulley and stretch other end over rotating floor brush in the space between the bristles. Place the ends of the rotating floor brush down into slots on the sides. Turn the rotating floor brush by hand several times in the direction of motor pulley. If installed properly, drive belt will center itself on rotating brush. Reposition brush cover and screw back into place. I hope that this helps you!
May 26, 2011 | Bissell 3591 CleanView Bagless Upright...
Kenmore 116.23513301
If the motor on the power brush is running the belt is bad, if the motor on the power brush only runs when you push the overload, the overload is bad.
Sep 14, 2009 | Kenmore 22812 Bagged Canister Vacuum
DC07 bottom brush does not rotate.
I can not pinpoint what exactly solved the issue. I opened the bottom conver, cleaned any presence of hair, cleaned all hoses (yes hose was completely clogged), made sure that the brush bar was engaged by switching the selector back and forth few times from Carpet to Bare floor. (On bare floor setting, brush bar won't rotate).
Now I am happy that the vacuum is completely cleaned and back in operation!
Nov 05, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuums Logo
66 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
