Need pin numbers for 98 yukon ECM
I have a 99 chevy silerado with a 4.3, and manual transmission. I took out the 4.3 and put in a 98 yukon 5.7 that had a automatic transmission. does my ecm have to be programmed. Do you know whare i can get the pin numbers on the ecm. A wire diagram just shows the color of wire going in the ecm, i need the pin numbers.
    Guru:
  • 1,738 Answers
You will have to go to the gm dealer and get the ecm program. You are playing with trouble, if you miss up once, your vehicle may not be able to run.
Posted on Nov 20, 2009
Chevy transfercase I have 1995 2 door cab 2500 what years will work
gmc and chevy k1500 pickup and suburban years 95-99
k2500 pickup years 95-98
k2500 suburban 95-96
gmc k2500 and yukon 95-98
I hope that helps if so please rate my answer
Dec 26, 2014 | 1995 Chevrolet C2500
Why does ecm-b fuse blow as soon as I put it in?
you are either pulling to much power from some where or wrong kind of fuse
Sep 09, 2014 | 88-98 Chevy Pickup / 95-99 Chevy Suburban...
How can I get a 99 1500 suburban motor and transmission to wire to a 98 1500 pickup?
same transmission? same engine? 98-99 was the cut-over year for changing small block chevy motors
Nov 28, 2013 | Chevrolet Cars & Trucks
Took all the wires off distributor
1-8-4-3-6-5-7-2 is the firing order for a v8 chevy, look at the cap locate the number one on it, tunk the starter and note rotation, and wire accordingly... chevy is odd numbers on the drivers side 1-3-5-7 and evens on the passenger side 2-4-6-8
Aug 29, 2011 | 1995 GMC Yukon
How do I remove old pins and bushings in a 99 chevy silerado
put a jack under door to hold up take a big screw driver pull spring out the use screw driver to drive both pins out thenpull door away from truck replace bushings then put door back put pins back in hinges
Jan 21, 2011 | 1999 Chevrolet Silverado 1500
89-98 chevy blazer
It's not worth doing all that conversion, buy the time you spend the time and money to convert the 89 4.3 to work on the 98 blazer, it would be cheaper to install a 98 vortec rebuild. The 89 4.3 have a TBI fuel injection system and the ecm on the 98 will not work and the bad news is that the ecm on the 98 also controls the transmission shift points and the 89 will not, so even if you swap the ecm to have the 89 4.3 engine work. the transmission will not shift. Sorry for the bad news but it would be cheaper to replace the 98 engine with the years of 1996 to 2001. Good luck and hope this helps.
Jul 21, 2009 | 1989 Chevrolet S-10 Blazer
Missfire on #4 cylinder for 1998 kia sportage
had the same problem....broken spark plug. try replacing your plugs.
Nov 29, 2008 | 1998 Kia Sportage
Televison & Video Logo
88 people viewed this question
Top Televison & Video Experts
Electro Med Services...
