Question about Homelite Garden
My homelite leaf blower UT # UT08023B is running badly all of a sudden. when i pull the trigger to get it to full speed, it acts like it doesn't want to get to full speed only about half speed and it seems like it's laboring, what's going on?
My Homelite leaf blower had a similar issue. I could hear a metalic clicking sound when it was running.
It turns out the flywheel has a cast in place key which is soft aluminum. The bolt holding the blower impeller and the flywheel in place had loosened up enough to allow the soft key to be destroyed.
I carefully re-installed the flywheel using Loctite® 660™ Quick Metal® Retaining Compound. The important issue here is to make sure the flywheel in aligned on the output shaft to retain ignition timing.
The blower runs perfectly after this repair.
Posted on Nov 25, 2009
  • 430 Answers
Its a fuel delivery problem. Its running lean.
Check the fuel line in the tank to see if the filter fell off. If the filter is loose in the tank than the best way to repair is to replace the fuel line. Also the diaghrams in the carb are dry or the screen is clogged. Lastly, if the fuel lines are not rotted and the screen in the carb is clear and everything is in proper working order then you can adjust the carb ( if it has adjustments). Start by turning the low speed needle out ( counterclockwise) 1/2 turn.
Posted on Nov 20, 2009
NEED PART # FOR PRIMER BULB ON HOMELITE BP30185
Thanks for providing the UT number.
When cross reference the carburetor part of up00651 it came as as Zama C1U-H36 which has a Zama 0057003 which is superceded to Zama 0057030
Mar 18, 2015 | Homelite Backpack Leaf Blower
Homelite mighty lite 26bv gas Blower won't run full speed or only in Full Choke
Sounds like a lean condition. Rebuild carb, replace fuel lines and fuel filter and you should be ready to blow the leaves.
Nov 10, 2012 | Homelite Mighty Lite Blowervac
Homelite ut-08068-r leaf blower leaking fuel
If we are talking about a hand held leaf blower. The fuel leaking from the carb is likely caused by a stiff metering diaghram holding the needle open. Rebuild your carb ( I suggest also replacing the fuel lines and primer bulb while you are at it) and double check the lever adjustment.
Oct 23, 2012 | Homelite Garden
Gas/oil ratio for a Homlite UT 08026H blower?
I USE SOME STUFF CALLED OPTI THAT WAY YOU ONE CAN FOR ALL YOUR 2 CYL STUFF ITS GOOD STUFF
Sep 29, 2009 | Homelite 'Yard Broom' Leaf Blower
Would like to find out how to set carb hi/low speed on homelite mod ut 08030 leaf blower
This is not difficult but it takes patience. First screw both screws in full, then unscrew them out one full turn each.
Start your engine and working on the low screw first adjust it along with
the throttle control screw until you have ticking over nicely, then do the same with the H screw. Make your adjustments very little at a time. Stephen
Sep 06, 2009 | Homelite Garden
I am trying to start my homelite leaf blower but i dont have the starting instruction sticker that came on it. the sticker had all the steps on how to adjust the two valves, throtle and choke. so if...
Hello ben_brumett:
On My Homelite Blower I Simply Set the Throttle Lock. Pull Out the Choke (on the other I Move a Lever) and Turn on the Switch. Now Pull Until it Starts or Attempts to Start. Remove the Choke and Allow it to Warm Up for 2 or 3 Minutes.
You can Get a Manual from the Following Site Addy;
https://register.homelite.com/contact_us/new and Fill Out the Required Information. Remember to have the UT Number if this Unit has One.
Apr 17, 2009 | Homelite 'Yard Broom' Leaf Blower
Mightylite 26 leaf blower
have you tried changing the air filter and spark plug?
Nov 20, 2008 | Homelite Consumer Products MightyLite...
Homelite 26bp backpack won't run up to full throttle
I have let my leaf blower run and warm up before throttling up and still it bogs down and shuts down. There is no air cleaner to clean should I just blow out the carb. and fuel lines?
It runs and idles just no high speed to blow.
Nov 16, 2008 | Homelite Consumer Products Backpack...
Garden Logo
192 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
