Question about Akai PT46DL10 46" HDTV-Ready Television
I have a viore IPT46DL30 and it will not turn on, have sound and blinking green light in front. I taken out the light bulb and it look good. Open the back panel and look for blown capacitor or burnt board all look good.Whats next. What is the resistance of a bulb
  • friman454 Nov 22, 2009
    Have replace the TV when it went blank on me and it works fine. Sometime when you turn it on, off severale time it will come on but the white seems to flash or it will come on black and white.
    Guru:
  • 1,738 Answers
You are not getting no signal from your source.
Posted on Nov 20, 2009
Blinking green light
Sounds like a lamp problem itself. Anyway, if you wish to make it sure, check the site linked here. It has details about the blinking codes to Mitsubishi. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 28, 2013 | Mitsubishi WD-73737 73 in. HD-Ready TV
The TV was turned off; and when it was turn on later, the green light blinked (while with only black screen w/no sound, or bulb illumination front/back of unit); and shortly afterwards the status ligh
Lamp is possible----
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jul 17, 2012 | Televison & Video
VIORE TV IPT46DL30 shows no light but power ins going to set??? is there a reset putton???
This tv has no serviceable fuses inside. You may need to replace the power supply module.
Nov 08, 2010 | Akai PT46DL10 46" HDTV-Ready Television
Viore IPT46DL30 has no power, it was working fine and plugged off and then put back to turn on, but noting now , no light and didnt start at all.
Check the output on the wall to make sure you have voltage. If you do then you have a open fuse in the set on the power supply, or the power supply is dead, in the set. You can get a new power supply at www.partstore.com
Oct 16, 2010 | Televison & Video
I have a 46' viore ipt46dl30 and when it turns on all the screen is really flickery. and most the colours come up purple, but this goes away for about 5 ten minutes and the flickery purple screen comes...
Viore ipt46dl30
Same problem, cleaned color wheel, put a few drops of wd40 on bearings, worked good for two months.
Started flickering again, need to replace color wheel.
Feb 03, 2010 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
Viore 52' TV randomly shuts off. front lights blink then stop.
I am having the same problem with my PRT50V24D shutting off and blinking lights. After going to viore.com and calling the number listed, I got recording to call another number. When got rep on line I was told it is made by Samsung, Called their tech support and was told that sounds like power problem or bulb getting ready to go. Also if outside of warranty will have to call repair man to see what's wrong. I will have a repair man out next week and will post his results here. Most likely it's the same issue. This is the tech support number for Samsung 1-888-697-2247. Good Luck man. Matt
Dec 05, 2008 | Televison & Video
New Bulb Doesn't Light
color wheel or light engine,call for service and save your money.
Aug 04, 2008 | Samsung HLN467W 46" Rear Projection HDTV
I have a viore monitor ipt46dl30 which just went black but we can still hear the voice.. help?
I'm in the process of ordering a replacement bulb for a friends set right now. The information below is exactly what's needed to get the correct bulb for this DLP television.
TV Make: Viore
TV Model: IPT46DL30 (Confirmed to be on TV label)
Bulb/Lamp Model: SHP70 (This number is right at the top of the bulb/lamp, where the wires connect)
Housing Model: 140-1027 (This is also known as the Ballast which houses the bulb/lamp)
Now, I've managed to locate the bulb/lamp from a few different sites. Unfortunately, there doesn't appear to be a reputable manufacturer making aftermarket bulbs for this DLP model. The original bulb type is all we have to look forward to. The cheapest price that I've found so far is $120.00. I have also found these particular bulbs for as high as $295.00. Needless to say, I'm going with the former.
http://www.replacementlightbulbs.com/lampshp70.html - $120.00 (Buying)
http://purelandsupply.com/140-1027-Bulb-Akai-DLP-TV-Lamps.html - $277.90 (Too much)
http://www.encompassparts.com/products/?140-1027 - $295.00 (Too much & very skeptical)
Mar 31, 2008 | Televison & Video
Akai PT46DL10 46" HDTV-Ready Television Logo
180 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
