Question about Apple iPod nano 2nd Generation MP3 Player
My iPod wont start. Couldit be the battery? - Apple iPod nano 2nd Generation MP3 Player
  • 281 Answers
The first thing you should try is hooking the unit up to a wall socket, not to your computer. Once the unit is hooked into the wall, try reseting the unit. This can be done by holding down the menu button and the center button at the same time. Hold the buttons for several seconds, and this should reset the unit. If this does not fix your unit, then yes it can be your battery, or your main board of the ipod. Look on the bottom of your unit and make sure there are no signs of corrosion(liquid damage). Also see if you see any bent pins at the bottom this can cause your unit to not charge also. If you have any other questions feel free to contact www.wiredextreme.com.
Posted on Nov 20, 2009
I let the charge run out and now it wont turn on take charge or anything any ideas, the device is only a month old
Similar thing happened with me as well.
Just keep the iPod plugged in for an hour, it should come back to life.
When the battery is critically low, the iPod doesn't get enough juice it needs to power up, so the battery needs a bit more charging to get the iPod started.
Aug 12, 2013 | Apple iPod nano 7th Generation
91 gmc sonoma wont shift out of first gear
on first gear it shifts rough it likes gives u a jump and after that it shifts good couldit be the pumpkin
Feb 06, 2011 | 1991 GMC Sonoma
When I Connect My Ipod Touch 8gb To My Computer It Wont Turn On And I Didnt Charge It For Like A Month What Should I Do Please Help Me!!!
You are right, it doesn't have enough power to turn on because the battery was drained. You're saying that it wont charge? It could only be the USB cable problem. Try to use a different iPod USB cable and check if it charges the iPod. Another thing is try to charge the iPod using the stand alone USB charger. Your iPod requires high power input. If that doesn't work, you may start to think that it is a battery failure.
Feb 03, 2011 | Apple iPod touch
Ipod touch wont charge
After a while the ipod batteries go bad.
Have a technician install a new battery for you and your ipod will work fine.
I DO NOT recommend this as a do it yourself Job.Th ipod touch has a battery that is soldered in and is not easy to install. pay the money to have a tech do it and you will be happy you did.
I charge my customers around $35.00 (installed) for the battery so you should be able to find it for somewhere around 35.00 - 50.00
May 10, 2009 | Apple iPod touch
Water damage to ipod battery, wont take a charge
take it apart and use hair deyr and brush and start drying it.
Mar 13, 2009 | Apple iPod MA446LL/A MP3 Player
My ipod wont start and wont show up in my computer or itunes
Have you changed the power cable? most likely faulty power cable. but if that doesnt fix it your ipod has an internal problem and needs to be sent in for repair I had same problem but new cable fixed it.
Feb 06, 2009 | Apple iPod MA446LL/A MP3 Player
Dead ipod
get a new battery :)
that's fine if you have to replace it. you can get em anywhere.
you can ither order the battery and install it yourself, or send it in, and have someone else do it
Sep 30, 2008 | Apple iPod classic MP3 Player
30 gig Ipod wont come on
Hello HBB-Wildman,
It sounds like the battery in the iPod may have failed. The internal battery pack in the iPod is designed to last a long time but will eventually fail and require replacement.
I would suggest either taking the unit into your local Apple Store or following the procedure on the iPod support page to get service on the unit.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 03, 2008 | Apple iPod MA446LL/A MP3 Player
Is my nano dead?
The battery inside you iPod has failed.
Apple store will try and get you to buy a replacement iPod rather than repair it. Although you can get a replacement battery from a number of places for around £10, eBay is a good start.
It's an awkward job to chane the battery but only takes around 30mins.
Once you replace the battery your iPod should function as normal.
Nov 04, 2007 | Apple iPod nano
Apple iPod nano 2nd Generation MP3 Player Logo
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
