Question about Razor Pocket Mod-bistro Retro Scooter
Razor pocket mod will not run. When I twist the throttle, I hear a click from the controller, but nothing else happens. Battery and charger both test fine.
SOURCE: battery charger shows charged. however
Make sure it is not battery or motor, jump the battery + & - to the motor + & -, if it works it will be the control box
30 minute fix for very cheap
ITEMS NEEDED
Get a Potter & Brumfield relay (5 poles)
2-3 feet of wire
4 female wire ends to plug into relay
HOW TO FIX
Take apart razor so you can see the black control box
Unhook throttle plug, this is the one with 4 wires (2 brown & 2 orange on mine)
Wire relay:
85: Ground
30: Red wire from switch to control box, if you wire this straight to battery it will work with switch on or off (killing battery)
87: Red wire to motor
86: Brown wire from throttle plug
Run a wire from 12v (battery) to other brown wire on throttle plug
END RESULT
When the throttle is activated, it closes the loop in the brown wires, triggers the relay, activates the motor
You WILL NOT have the throttle control, it is wide open or off when you activate/de-activate the throttle
This will save you $30 for a new control (brain) box.
Posted on Jun 10, 2012
SOURCE: razor e300 scooter charger light stays green,
I have this same problem? What do you do? I bought a new charger thinking it was that and the light stays green on it too.
Posted on Sep 09, 2010
  • 25 Answers
SOURCE: Pocket Mod -battery charged. when
none
Posted on Jun 21, 2011
  • 11 Answers
Does the Razor charger light go straight to charged? If so the battery has gone & needs replacing, please check the voltage output & load test the battery (weight on scooter while battery connected straight to motor). very common but overlooked issue can just be the On/Off switch, check there is voltage present across the terminals. If you are hearing a clicking noise then the control module may have gone.
Posted on Jul 05, 2011
mc1bean
  • 3053 Answers
SOURCE: I've replaced the batteries and
Hello, I believe what the problem is, in your throttle switch or more often the connection to your battery, even though your battery might be good, bad or loose connection can cause this. Most electric toy cars, go carts, buggies, and other similar electric toys, all operated on a electrical switch mechanism. They are effective when working, but unfortunately from my experience poorly built, meaning they wear out real easy. When working properly, you press the pedal, activates the electrical circuit by way of the switch. Think of the switch as like the ignition on a automobile. It works kind of the same method.
I believe personally it is in your connection to your battery. However here is what did here to help you out. I have put to REAL GOOD links to help you. One link is to the sight, which shows you parts and cost for parts, and on same site i gave you the link that takes you to the Ground force trouble shooting guide of possible problem and solution based on the symptom. I think this will help you. Links are below and please copy and paste them in your browser and let me know if anything else i can help you with. Thanks Mike
http://www.razorama.com/razor-ground-force-drifter-parts-section.html
http://lib.store.yahoo.net/lib/razorama/GFtroubleshooting.pdf
Thanks Again, Mike , (Fiya Expert.)
Posted on Aug 02, 2011
Hannah Montana razor scooter says charged but wont go whats wrong
I haven't used my razor scooter in years. I just bought a charger and it seem like it is charging but it keep saying it is on low. I twisted the gas thing and it is making a noise like it want to go. But I am not sure I have charge it for 12 hours now. Do I need a battery or is it just taking it time to charge.
Sep 17, 2015 | Electric Razor Pocket Mod Scooter
How can i test electrical compontents on the mx500 dirt bike? i bought it used. it will not run the lights on the the throttle light up that the battery is full but when i twist the throttle nothing...
If the lights on a the throttle are showing a full battery then try disconnecting the brake switches at the controller one at a time. If the bike works after disconnecting a brake switch then that switch is faulty and should be replaced.
There is some excellent information on trouble shooting and testing components here http://www.razorama.com/razor-installation-guides.html
also wiring diagrams here http://manuals.monsterscooterparts.com/recreational/Razor/Wiring/
Oct 07, 2013 | Razor MX500 Dirt Rocket
Razor Bella scooter problem
yes sounds like the control module, you can always jump the batteries directly to the motor to make sure that the motor is ok
Jun 25, 2012 | Razor USA Razor Pocket Mod Electric...
How do you operate Bella mod
there is an on/off switch right below the seat next to where you plug in the charger, then you have to twist the right hand grip
Apr 29, 2012 | Razor USA Razor Pocket Mod Electric...
Pocket Betty throttle
It sounds like you have to replace the electric motor. Good luck!
Apr 22, 2012 | Electric Razor Pocket Mod Scooter
Battery charger shows charged. however when tun throttle, nothing. no indication of loose wire connections. have a pocket mod
ITEMS NEEDED
2-3 feet of wire
HOW TO FIX
Wire relay:
85: Ground
END RESULT
Jun 10, 2011 | Razor E100 Electric Scooter
Razor Pocket Mod-bistro Retro Scooter Logo
1,480 people viewed this question
Top Razor Toys Experts
Clif Roberts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
David Payne
David Payne
Are you a Razor Toy Expert? Answer questions, earn points and help others
