Question about JVC HD-52G786 52" Rear Projection HDTV
My projection tv picture was flashing a picture in and out. I removed the lamp to see if it looked bad but it looks fine but when I put it back in now the tv will not even power on?
  • heather_roer Nov 20, 2009
    Ok nevermind now I got the tv to come on but it is flashing and the green screen keeps coming in and out. I am assuming it is the bulb but like i said I took it out and it looks fine. Anything I should try before getting a new lamp?
    What is that mechanism and is it something that maybe if I blew the dust out would work again or do I need to have a repair person come out to my house. Thanks
    Guru:
  • 1,738 Answers
Is the mechanism that fires your lamp to come on.
Posted on Nov 20, 2009
Flashing green light
I have a mits. 82738 tv which would shut off after 20 minutes when first turned on .
Loose sound and picture.
Looked up error code in service manual and it said the lap was the problem.
Replaced lamp and now it works fine and the picture quality is great.
Jan 20, 2014 | Mitsubishi WD-82738 DLP TV
No picture no sound lamp light and standy / temp light flashing
Two things to look at---------the lamp to see if shattered inside AND with it removed look where it faces at the color wheel--see attached photo.
Look to see if any segments are broken, missing etc. Many of the wheels fail in this way and some will have a high pitched or even fan like sound before they fail.
Some when really bad will make a grinding noise also. The set monitors the speed of the wheel and if it slows or stops the set will almost instantly turn the lamp off(if possible watch from area where lamp is to see if at turn on to see if it for a moment lights or not.
May 05, 2012 | Samsung HLR5067WX 50" Rear Projection HDTV
Lamp doesnt look blown but lamp light flashing n tv wont turn on
Check the Lamp Fan if it is defective Lamp will try to light but will shut off, And the Ballast board is what turns Lamp on, For Part number o to Encompass parts distrubtion and type in your model they should list the ballast board and PN Then go to Ebay Look under Electronics type in PN, I got mine for $65.00
Lamp for $85.00
Jun 27, 2010 | Panasonic PT-45LC12 45" Rear Projection...
Sony Wega KF-42E200A Projection Bulb
New bulb is just fine.
3 blink shows that lamp cover after replacement of bulb in TV is not fixed properly or not seated well in its position.
Put new bulb and carefully place back lamp cover in its position because lamp cover will press tinny safety switch inside that will send signal to system control of TV that lamp is installed properly.
Turn On TV and get vivid picture of Sony.
Thanks.
Oct 17, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Exact problem, lamp comes on, no picture, lamp light flashes.
remove the lamp and with a light and or mirror look where the front of the lamp faces--there is a color wheel there--if it is shattered or damaged the set will not come on--most of these sets have a high pitched whine or grinding noise if this happens---the wheel is available on the internet and a moderate job to replace--I have seen lots of them bad---if you want an idea of what it looks like--etower.766@netzero.net Steve
Aug 10, 2009 | Samsung HL-P4667W 46" Rear Projection HDTV
Samsung sp50L2hx no picture
You need to replace the Lamp. You have a bad lamp.
Jul 27, 2009 | Sony Grand WEGA KDF55E2000 55" Projection...
No picture after changing lamp, tv will not power up.
Try bringing up the menu. If you can't I'd suspect the fmt board if you can suspect the dm module.
Bill
Nov 24, 2008 | Mitsubishi WD62628 62" Projection HDTV
Blue light and lamp light flashing, no picture.
Look in the owners manual for the directions on how to remove the lamp. Your model the lamp goes in from the front on the left looking at the TV. There is a thumb screw in the back on the corner holding the left front speaker on. Under the panel there is another thumb screw holding the lamp door on. You will need a Phillips screw driver to remove the lamp. You will most likely find that the lamp is bad. You will either have to order a lamp directly from JVC, a service center or a parts distributor.
Apr 21, 2008 | JVC HD-52Z575 52" Rear Projection...
JVC HD-52G786 52" Rear Projection HDTV Logo
98 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
