Question about Cell Phones
I have a problem with the outbox of my Nokia 6280. I cannot delete messages that are in there and my phone will not send Multi Media. I have had this problem for a while and have just about had enough. Please help
  • sue_coaldrak Nov 20, 2009
    Thanks Coolguy,
    However, I cannot even open the outbox it just comes up with a msg "Opertation failed. Try again".
    I have tried to re format the phone or whatever you call it and that didn't work either. I haven't even got my phone hooked up to my computer. Sorry a bit computer iliterate when it comes to things like that. My phone is a Nokia 6280.
    Cheers
    Sue
    OMG,
    What a dummy. Thanks Coolguy. I will give it a whirl over the weekend and let you know.
    Thanks
    Sue
    Scholar:
  • 105 Answers
I hope the following information helps you out regarding your phone. I found this information in the users manual for your phone. I know there is a lot of information to follow but it a try, step by step and good luck!
Delete messages
To delete messages one by one, select Menu > Messaging > Delete
messages > By message and the folder from which you want to delete
messages. Scroll to the desired message, and select Delete. If one or
more messages are marked, select Mark. Mark all the messages you
want to delete, and select Options > Delete marked.
To delete all messages from a folder, select Menu > Messaging > Delete
messages > By folder and the folder from which you want to delete the
messages. Depending on the folder, the phone asks if you want to delete
the messages. To delete, select Yes. Otherwise, if the folder contains
unread messages or messages which are waiting to be sent, the phone
asks whether you want to keep them. To keep these messages, select
Yes.
To delete all messages from all folders, select Menu > Messaging >
Delete messages > All messages > Yes.
Write and send a multimedia message
The wireless network may limit the size of MMS messages. If the inserted picture
exceeds this limit, the device may make it smaller so that it can be sent by MMS.
1. Select Menu > Messaging > Create message > Multimedia.
2. Enter your message.
Your phone supports multimedia messages that contain several
pages (slides). A message can contain a calendar note and a business
card as attachments. A slide can contain text, one image, and one
sound clip; or text and a video clip. To insert a slide in the message,
select New; or select Options > Insert > Slide.
To insert a file in the message, select Insert or Options > Insert.
You can fetch images and video clips from the Gallery, or to take
them directly from the viewfinder, select Options > Insert > New
Image or New video clip.
3. To view the message before sending it, select Options > Preview.
4. To send the message, select Send; or press the call key
5. Enter the recipient’s phone number in the To: field. To retrieve a
phone number from Contacts, select Add > Contact. To send the
message to multiple recipients, add the desired contacts one by one.
To send the message to persons in a group, select Contact group and
the desired group. To retrieve the contacts to which you recently sent
messages, select Add > Recently used.
Send a message
Copyright protections may prevent some images, music (including ringing tones),
and other content from being copied, modified, transferred, or forwarded.
When you finish writing your message, to send the message, select
Send, or press the call key. The phone saves the message in the Outbox folder, and sending starts. If you select Save sent messages > Yes, the sent message is saved in the Sent items folder.
Note: When the phone sends the message, the animated is shown.
This is an indication that the message has been sent by your device to
the message center number programmed into your device. This is not
an indication that the message has been received at the intended
destination. For more details about messaging services, check with your service provider.
It takes more time to send a multimedia message than to send a text
message. While the message is being sent, you can use other functions on the phone. If an interruption occurs while the message is being sent, the phone tries to resend the message a few times. If these attempts fail, the message remains in the Outbox folder. You can try to resend it later.
Posted on Nov 20, 2009
    Genius:
  • 3,422 Answers
HI,
Select the message and press update button.This should fix the issue.If it doesn't then go to C:\Documents and Settings\%username%\Phone Browser\Nokia E70\Messages\Outbox\
And delete all the messages which you don't want from the outbox in the pc that will delete it from the phone too.
Give your phone a restart.IF the problem persists then reinstall the pc suite and this issue will be solved.
Thank you for using fixya.
  • Priya darshan Nov 20, 2009
    HI Sue,
    Let me explain it more clearly.What you need to do is first connect the phone to your pc and then open up my computer.Double click the C drive to open it>Similarly open the Documents and settings folder>open the Messages folder>Open the outbox folder and you will see some files in it.They are the the stuck messages so you need to delete them all.After that close the windows,disconnect the phone and restart it.The outbox should be empty on your phone now.If not then reinstall the Nokia Pc suite.
I cant delete 1 message from my outbox.. cant even able to send it again...
Hi
If you want to delete message from outbox, Just Go to outbox defer sending then agen go to option select move to draft from there you can delete that message
Regards,
Harish
// Feel free to vote this answer with 4 thumbs up //
Jun 16, 2011 | Nokia N70 Cellular Phone
How to delete the outbox messages from nokia 5230
Hello thanks for using fixya
In outbox those messages are present which are in process of sending or failed to send
If u want to delete messages from you outbox
Go to the menu>>Click the message>>Go to outbox messages,you will see your messages>> Go to options options there>>they will be second option as delete message>> Press Ok. Message will be delete
I hope this solution will helpful 4 u. Best of luck
Please keep thumbs up in do rating
THANKS & Keep using fixya
Jan 03, 2011 | Nokia 5230 Cell Phone
My nokia N72 showing in the screen ''massaging not enough memory to perform operation.delete some data first'' when i want to write msg.
sir delete the inbox,sent message,outbox,draft,messages to get the enough memory from the phone and then you can send the message...........
Nov 22, 2010 | Nokia N72 Cellular Phone
While sending text message it says memory full delete some data?
hi..
This is because when you send the message it stores up in outbox and then only it wil be sent,As your phone memory is full no space is there for storing in the outbox. So please delete the inbox and draft and savedmessages so that you will not get this message again.
Thanx
Jul 21, 2010 | Nokia N73 Cellular Phone
Outbox cannot delete
switch off the phone and on it... reboot ur instrument.
Sep 04, 2009 | Nokia N76 Cellular Phone
I cannot delete messages from outbox
switch off ur mobile and turn it on back
then delete, it will
Jun 25, 2009 | Nokia 6600
Unable to send text messages on my new nokia 5800
All you have to do is go to your message setting on your phone:
1. Open Messaging
2. On New message sellect options at bottom
3. Open settings
4. Open Text message, you should see: Message centre, message centre in use ect..
5. Open message centres this should go to next screen then open again, this screen should have : Message centre name & Message centre number (from your network provider you need to find out what is the message centres name & number are e.g in Australia it should be SMSC1 and number is +61411990001) then just manually enter these in there.
Feb 26, 2009 | Nokia 5800 XpressMusic Smartphone
6280 memory full
Steps to follow when the phone memory is full:
  1. If the message memory is full you’ll be shown Memory full. Unable to receive messages is
  2. To delete old messages, Select OK and Press Yes and the folder.
  3. Navigate to the desired message and Select Delete.
  4. Choose Mark, to delete more messages. Mark all the messages you want to delete, Choose Options and Press Delete marked.
Feb 10, 2009 | Nokia 6280 Cellular Phone
My phone will only send multi media messages?
I did more searching and found the answer! Clean out your inbox and outbox, and your phone should go back to sending normal messages. You might need to restart it afterward.
Jan 04, 2009 | Motorola Mobility RAZR V3
Phone won't send text messages
reset your phone to factory settings!
Just go to settings....factory settings......then just type 12345 for the sec code.
Kindly rate this up! thank you very much!
Oct 13, 2008 | Nokia 6126 Cellular Phone
Cell Phones Logo
53 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
