Question about Panasonic PT-52LCX65 44" HDTV
PT-52LCX65-K PROJECTION TV FROM COSTCO
THERE IS NO AIR FILTER IN MY TV BUT THE MESSAGE "CLEAN AIR FILTER, TV WILL SHUT OFF IN 1 MINUTE" WON'T STOP COMING ON.
I JUST REPLACED THE BULB AND THAT DIDN'T WORK. NOW I CAN GET THE FIRST SERVICE MENU TO COME UP BUT THE SECOND MENU WHERE I COULD RESET THE FILTER HOURS WILL NOT COME UP BECAUSE MY REMOTE DOES NOT HAVE A STOP/SWAP BUTTON AND NONE OF THE OTHER BUTTONS WORK...HELP
    New Friend:
    Problem Solver:
  • 10 Answers
There is a filter and fan to cool the LCD pannels Red Blue and Green inside by the optical lens. Phil
Posted on Apr 28, 2013
I just googled this problem and found this:
http://www.ceqna.com/tvs/1895-tvs-3.html
Hope it helps.
Posted on Apr 07, 2008
2 Suggested Answers
welcomejee
  • 10594 Answers
SOURCE: my panasonic rear projection pt-52lcx65 wont turn
Sounds TV needs Ballast Supply board replacement, it is available in Part Store.
If you wish to replace above board by yourself, should have service manual copy that is available HERE for small fee.
Or call local TV tech for fix.
Thanks.
Posted on Aug 06, 2009
I get a message to clean filter. I removed back but could not find filter. Cleaned all visible dust and reinstalled back. Worked great for 2 months and got message again. Next day worked ok again. ...
hi,
To clan the air filter you have to remove the projection unit.You can see the projection unit behind the lamp blast board.There are three air filters in this unit. You have to clean these air filters. I have added the picture which showa the location of air filters. If you can give your email address the i will sent the service manual. Which will help you to remove and clean these Air filters. Remember one thing remove lamp first then only remove the projection unit from the rear side.
OK
Apr 20, 2011 | Panasonic PT-52LCX65 44" HDTV
The tv is only 4 years old and just stopped working while we were watching it. it is a "52 model number pt-52lcx65-ka.
If lamp in tv has not been replaced in last 3-4 years then check lamp and replace it.
Did tv showed lamp replacement requires warning/ message on screen before going to shut down?
Did you hear any pop sound inside tv when it get shut down? that pop sound could be lamp that got broken.
Let me know if you have additional question.
Thanks.
Feb 27, 2011 | Panasonic PT-52LCX65 44" HDTV
Where is the air filter on a Panasonic PT-52LCX65 Projection TV
THE AIR FILTERS ARE INSIDE THE ENGINE YOU MUST TAKE APART MANY PIECES LET A REPAIR CENTER DO THIS!!
Apr 25, 2010 | Panasonic PT-52LCX65 44" HDTV
Panasonic pt-61LCX65 osd air filter cleaning came on screen and the unit shut down in 1 minute. I would like to know exactly where the air filter is where I can clean it myself.
This is stright from Panasonic.
The consumer is not able to change the air filter. It will have to be done by an
authorized Panasonic service center."
Jan 22, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
Warning light comes on that T.V. will shut off in one minute & to call a technician to clean air filter.
Sounds like a plasma, or projection system. Find the fan inlet filter, remove the foam filter, and vacuum with a dust buster. You can use a can of compressed air to blow the filter clean, too.
Jul 24, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Clean filter
In order to clean the air filters properly. The projection unit must be removed from the rear. This unit is very expensive! I would recommend calling for service. But you can find the service manual online for free if you feel daring.
Oct 18, 2008 | Panasonic PT-52LCX65 44" HDTV
OSD Message Panasonic PT-50LC14 Air Filter Needs Cleaning
I had the same problem and the stupid tv would shut off after 1 minute. We opened the silver front panel , took the bulb out cleaned it, took the cover off the grey box to the right and very carefully vaccumed the filter and wiped it off with a microfiber cloth. It works great now!!! Make sure you unplug your tv before messing with it.
Sep 28, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Pt-52lcx66-k multimedia projection hdtv - air filter needs cleaning
Good Day,
It sounds like your lamp sensor is defective. Change it and it should correct your concerns. I hope this helpful.
Jun 11, 2008 | Panasonic PT-52LCX66 Projection Television
Reset lamp meter on Panasonic PT-43LC14 television
While TV is on, simultaneously press and hold both the TV's Volume Down button and the remote's PP/Play button for 7 seconds.
Jun 03, 2008 | Panasonic PT-40LC12 40" Rear Projection...
Panasonic PT-52LCX65 44" HDTV Logo
1,399 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
