Question about Ricoh SP C221SF Aficio Printer
Need to enter service mode to reset fuser, which locked up after power brownout. I know it is done by entering some key combinations on the printer panel but don't know the sequence. thanks!
  • 3 more comments
  • Gustavo Saito Nov 20, 2009
    Model is Ricoh Aficio SP C221SF
    It gives error code SC542, which started occurring after a power outage. I read that this is a fuser lock-down protection mechanism and I need to reset the fuser configuration under service mode.
    I actually need support as to (i) how to enter service mode and (ii) how to reset this error code.
    Thanks!
  • Gustavo Saito Nov 21, 2009
    There is no yellow / reset button on my printer. I saw this solution somewhere else on the internet but I don`t think it is designed for my model.
    Thank you for tyhe reply but my printer does not have neither an ONLINE key nor a ESCAPE key. I saw this Online/Escape key solution elsewhere on the internet but I think it applies to other models, not mine. Mine is a Ricoh Aficio C221SF. Thank you.
  • Gustavo Saito Nov 24, 2009
    I managed to contact a Ricoh representative who gave me correct sequence for this printer. It is 90% similar to the "1,0,7" combination I was presented by some of the experts here, but there are small twists that were preventing the sequence from working before. Below I transcribe what I received from Ricoh:
    <<< Error code "SC542" reset procedure for Ricoh SP C221SF: >>>
    A) Entering the Maintenance Mode Menu
    1. Turn on the machine.
    2. Press these keys in the following order: "Clear/Stop", "1", "0", "7" and "Color Start"
    3. "Maintenance Mode" is displayed on the LCD.
    B) Selecting an Item
    1. To select an item, press the "Up" or "Down" key.
    2. To go into the next level of an item, select an item then press the "OK" key.
    3. To return to the previous level of an item, press the "Return" key.
    C) Fixing SC542 error code
    1. Select "Engine Maintenance" and press "OK"
    2. Select "Fuser SC Reset" and press "OK"
    3. Select "Execute" and press "OK"
    4. Return to main screen by either pressing "Return" key several times
    D) Turn off and then turn on. Error code should disappear.
    This worked like a charm! Printer is good as new.
  • Jerome Piercy Mar 12, 2013
    thank you so much Gustavo, yours was the solution to my problem, finding the way to reset. It took 4 hours before I hit on your solution. Thanks to you I have my printer back!
  • 2,335 Answers
To enter the service mode of a Ricoh Afficio:
Hold down the two arrow keys and count to 5, hit the enter key.
This is for a 3800 not a 221SF, but I suspect the access to service mode is the same. Let me know if it is not & I will source the proper sequence for you.
I hope that helps.
Posted on Nov 24, 2009
  • 466 Answers
Press the Clear key, enter 107 (one hundred seven) on the keypad and press Clear key. Clear key must be kept pressed for 3-4 seconds.
The reset fuser code may be found here (for the 200 model, but Ricoh is quite consistent in using the same codes wherever they can).
http://www.scribd.com/doc/8007865/Codici-Errore-Ricoh
Posted on Nov 21, 2009
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. This error mostly occurs due to power outage. This error means that the fuser temperature and hot roller temperatures have warm up. After occurring of this error the printer will not work until your clear this error code.
To clear this error code follows this step by step procedure---
  • To Enter in Service Mode hold down the Online + Escape keys simultaneously and then turn on the printer.
  • Use up and down arrow keys to select SP2
  • Press Enter
  • Use up and down arrow to locate SP5
  • Press Enter
  • Use up and down arrow keys to select 810
  • Press Enter
  • Confirm the selection
  • Power off and on.
This will resolve the issue by clearing the error code.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
    Genius:
  • 3,422 Answers
Below is the reset method:
1. Press the yellow (reset) key
2. Type 107 on the keypad
3. Press and hold down the red (clear/stop) key until the display changes (3-5sec)
4. Turn Main power switch Off and then On again. The main switch placed behind a lid or on the side of the printer, not the power switch close to the keypad.
This will fix the issue.
Thank you for using fixya.
Posted on Nov 20, 2009
    President:
  • 2,185 Answers
Hi there Gustavo,
May I have the make and model of your printer or copier? We need that so we can help you further.
Canon2202ir E0000-000 This error code deals with the fuser unit. It is saying that the fuser is not warming up. It needs to be reset in service mode.
How can I enter service mode on canon ir 2202? - Fixya
www.fixya.com/.../t25374950-any_one_help_me_enter_service_mode_...
Jan 19, 2015 - In standby mode, press the "Settings/Registration" key. 2. Press the "Reset" key. 3. Press the "Back" key. 4. Press the "Settings / Registration" ...
Error Code ir 2202n - CopyTechNet.com
www.copytechnet.com > ... > Copier Technical Discussion > Canon
Nov 22, 2014 - 3 posts - ‎2 authors
... pls help me ....i know how to enter service mode but ......pls help. ... Copier Technical Discussion · Canon. [Error Code] ir 2202n ... ir 2202n. how to print jam history in ir 2202.......i dont know pls help ... mm its a new machine , i need to know how to enter the service mode if u please ... Press the "Reset" key. Error Code canon image ronner 2202N
Aug 21, 2014
Canon IR 2200 error E000001-002
Jun 18, 2009
More results from www.copytechnet.com
Dec 21, 2015 | Office Equipment & Supplies
How t reset fuser error c6000 for taskalfa 180
Fuser reset: Press 'system menu/counter' key, select 'service setting', then while pressing 'start' and '#', press 'enter'. Select 'Maintenance mode', then press 'enter'. Enter '163' using the up/down keys, then press 'enter'. Turn machine off to exit Maintenance mode. C6000 indicates fuser did not come up to temp in the allotted time; you 'may' have a bad heater lamp if code reappears. Good luck.........
Thanks,
Sep 05, 2014 | Office Equipment & Supplies
Error code c6000 of copystar cs1815
SIM 163 Reset (only do this one SIM, by doing others you could cause your machine to no longer function. Also see note at bottom.
Entering Simulation Mode
1. Press the system menu/counter key.
2. Select Service setting using the up/down cursor keys.
3. While pressing the start key and the # key, press the enter key. (Maintenance mode is entered.)
4. Select Maintenance mode using the up/down cursor keys.
5. Press the enter key.Enter the maintenance item (163 Resetting fuser problem) number using the up/down keys.
6. Go to step 1 under method below.
Resetting the fusing problem data Description
Resets the detection of a service call code indicating a problem in the fusing section.
When a service call concerning the fusing section occurs, turn the power switch off and open the front cover.
Then, turn the power switch on and press the system menu/counter key to enter the maintenance mode.
Purpose
To prevent accidents due to an abnormally high fusing temperature.
Method
1. Press the enter key. A selection item appears.
2. Select Execute using the up/down cursor keys.
3. Press the enter key. The fusing problem data is initialized. (Four service calls, namely C6000, C6020,C6050, and C6400 are reset.)
Completion
Press the back key. The indication for selecting a maintenance item No. appears.
Note:Sometimes in order to do the reset when the machine is in an error state you need to open the top cover (like to replace the toner) and leave it open until you have performed the reset.
Mar 20, 2011 | Kyocera COPYSTAR CS-2050 Printer
C 0 e 0 0
the C000 code is a fuser error code on this machine. It can "sometimes" pop up after a power surge/spike/loss event, and needs to be reset in service technician mode. If it doesn't reset, but rather comes back, you probably need a sevice call for something defective in the fuser (lamp, fuse, thermister).
IF YOU'RE GAME, here it is...
To enter service simulation: press"Additional Functions" to enter "User mode". Press # key. Press </> to select a menu item. enter new data using number keys. Press "Set/OK" key. Press Stop/additional functions to exit.
Note: To reset E000, E001, E002, E003, go to service mode 4. select SET, go to "#7 PRINT-ER," in service mode. Then press Execute "#4 PRINTER RESET." Power the unit off/on.
Nov 29, 2010 | Minolta EP4000/5000 CS/PRO Copier
My spare Ricoh AP3800c has decided to show a SC541 warning, I understand that has to be reset in 'Service Mode' is it possible/safe to do this myself? if so can anyone give me an idiots guide to doing it?...
Power off the printer, wait a while and power on back, while the printer is loading, unplug the printer from the AC power source and wait for some minutes before you plug in back and power on. This should reset your Ricoh AP3800c printer. if problem persist, follow the below procedure.
Hold down the two arrow keys and count to 5, hit the enter key, the machine should be in service mode if nor repeat. use arrow key and scroll to machine press enter scroll to data log press enter scroll to pm counter reset press enter, scroll to fuser oil press enter and execute this mod Please. DO NOT GO INTO ANY THING ELSE or you could do serious damage to your machine!! If your machine has a Copy feature expander you must press Clear mode, Press 1-0-7 and then hold down the stop cancel key 4sec. go into copy mode press 7-804-809 press execute button again Please DO NOT GO ANY WHERE ELSE as damage can be done to your machine.
Take care.
Jul 20, 2010 | Office Equipment & Supplies
Sc541 appears on the copier
Your problem in the fuser unit.Clean the fuser thermistors.To reset enter in the service mode Total clear key(yellow)-107-clear key(red) enter in the SP mode,open the front door,turn OFF the power switch and unplugged the cords.Wait 15 seconds plugged ON the power cord,close the front door and turn ON the copiers.
Nov 17, 2009 | Ricoh Office Equipment & Supplies
Need to know how to reset the oki c5400n to factory defaults
Procedure:
  1. Power ON printer while holding both the "+" and "-" buttons until “OKIUSER” message apear in LCD.
  2. Press ""+ or "–" button until “ENGINE DIAG MODE” is displayed
  3. Press "ENTER", will be displayed "DIAGNOSTIC MODE XX.XX.XX S-MODE"
  4. Press "+" or "–" button until “NV-RAM INITIAL” is displayed
  5. Press "ENTER" again
  6. Appear "TABLE 1" message
  7. Press "ENTER" until "EXECUTING RESET" message appears. "NV-RAM INITIAL" message will BLINK... IT resets TONER, DRUM, FUSER and BELT...
  8. Power OFF printer, wait 10 sec, and power ON again
To access Service Mode in C9300:
  • Power ON printer with 0, 1, 6, 7 at same time...
Nov 09, 2009 | OKI C5400 Laser Printer
How to enter service mode in ricoh aficio 3800
Hold down the two arrow keys and count to 5, hit the enter key, the machine should be in serrvice mode if nor repeat. use arrow ke and scroll to machine press enter scroll to data log press enter scroll to pm counter reset presss enter, scroll to fuser oil press enter and exicute this mod Please. DO NOT GO INTO ANY THING ELSE or you could do serious damage to your machine!! If your machine has a Copy feature expander yopt must press Clear mode, Press 1-0-7 and then hold down the stop cancel key 4sec. go into copy sp mode press 7-804-809 press exicute button again Please DO NOT GO ANY WHERE ELSE as damag can be done to your machine. Hope this helps!!
Jun 09, 2009 | Ricoh Aficio AP3800C Laser Printer
Canon D861 copier
Garner,,, the C000 code is a fuser error code on this machine. It can "sometimes" pop up after a power surge/spike/loss event, and needs to be reset in service technician mode. If it doesn't reset, but rather comes back, you probably need a sevice call for something defective in the fuser (lamp, fuse, thermister).
Oct 11, 2007 | Office Equipment & Supplies
Ricoh SP C221SF Aficio Printer Logo
482 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
