Question about Panasonic Lumix DMC-LC1 Digital Camera
Then lens is not working correctly. I cannot see anything to take pictures of. It comes up black in the review when i hit the shutter.
  • 130 Answers
SOURCE: canon powershot a610..pictures come out black..
When you say the shutter is open, you can see the purple glass lens from the front?
Posted on Apr 23, 2006
jackboy
  • 2985 Answers
SOURCE: Sony Cybershot Lens Stuck inside!!!
I guess you are Doomed. The Zoom mechanism is smashed and an economic repair is going to be a no no You could try a local repairer or Sony Tech help team but I feel it would be more prudent to buy the next camera.
Posted on Jul 06, 2007
SOURCE: No screen, no pictures
I have the same issue. i believe my mom dropped this too and i don't know what to do. i think the lens go messed up cause it's not allowing to view what im wanting to take a picture at. DARNIT!
Posted on Sep 29, 2008
SOURCE: Blank screen
I had just bought a new camera because I had the SAME problem but I decided to check the website before I bought a new one. Well, I'm so glad I did because I found out that all you need to do is press DISP (display) which is located on the big round button at the bottom of the camera. I pressed it a few times and IT WORKED:)
Posted on Dec 19, 2009
mail2pvs
  • 390 Answers
SOURCE: lcd screen is completely black
i think this is generally the symptom when there is a problem with either the CMOS or the CMOS circuit not able to collect the image, if its worth it you might want to change it but normally it would cost almost as much as the camera
hope could be of help
Posted on Mar 28, 2011
When i take pictures on my pentax optio s10 the pictures are coming out black but the lcd screen is working, is there anything i can do to fix this?
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 04, 2011 | Pentax Optio S10 Digital Camera
Camera not displaying images as seen through viewfinder. The screen is black. Image controls and info can be seen but the picture is just black. Takes photos which are also black; but previous photos...
A stuck shutter is another common failure mode for digital cameras, particularly for the SD1000. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
By the way, my wife's SD1000 also has this problem every once in a while. I easily fix it by using the following steps from the link: powering on the camera, opening and closing the battery door, and flicking the end of the lens barrel with my fingertip (or you can tap it with a pencil as discussed in the link).
Feb 06, 2011 | Canon PowerShot SD1000 Digital Camera
When i turn my camera on the screen is black. when i take a picture the screen remains black and when i press review of the picture i took that is black as well. is that a back light problem or something...
Try downloading the picture to your computer to see if it is also black. If so, then yes it may be a shutter issue. A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Dec 21, 2010 | Kodak EasyShare C330 Digital Camera
Cannon sd1000 lcd screen black. Can review pictures, but cannot take new pictures.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 06, 2010 | Canon PowerShot SD1000 Digital Camera
The screen is black, i cannot see anything on the
First thing to check is to make sure that you didn't just accidentally press the DISP or DISPLAY button on the back of your camera, manually turning the screen off. Press the DISP button once with the camera turned on. If that didn't correct the problem, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Apr 10, 2010 | Canon PowerShot SD500 / IXUS 700 Digital...
Canon Powershot A510 black screen when taking photos
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 20, 2009 | Canon PowerShot A510 Digital Camera
Review windows is black, pictures are black
A stuck shutter is a common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Jun 12, 2009 | Cameras
Black screen through screen and eye view finder
Jun 07, 2009 | Canon PowerShot SD870 IS Digital Camera
My Kodak Easyshare LS443 is taking black pictures
Dec 15, 2008 | Kodak EasyShare LS443 Digital Camera
Canon sd300 cant see pictures taken
This may sound silly, but did you check the shutter on the end of the lens when the camera is on to make sure that the shutter is open? Sometimes some dirt or sand can get into the lens barrel and make the shutter get stuck in the closed position. If this happens, gently open the shutter with a a toothpick or something (NOT your finger because of the oils and NOT something that will scratch the lens).
If the shutter is open and the pictures turn out black both on the camera's LCD and on the computer once you download them, then I'm guessing something happened to your CCD, which is the tiny electronic chip that records the light coming through the lens. Either something inside the camera has fallen in front of the CCD and is blocking the light (unlikely) or the CCD chip has died. If that's the case, I hate to say it but buying a new camera would be more cost effective (and probably cheaper) than getting it fixed.
Apr 10, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
Panasonic Lumix DMC-LC1 Digital Camera Logo
24 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
