Question about Moen Trim kit for 2 handle lav with drain assembly - T6506CPM - Platinum
What valve system use ? - Moen Trim kit for 2 handle lav with drain assembly - T6506CPM - Platinum
  • 36069 May 11, 2010
    Need to know model of your trim package before giving a definite answer.
  • 119 Answers
#9300 for mini widespread M-PACT model
#9000 for 8" widespread
What you have pictured is the 4" mini widespread
Posted on Nov 23, 2009
Is there a fuse for the vent solenoid? getting P0449 code but vent is good.
code p 0449 refers to evaporative emission (EVAP)system, vent valve ---circuit malfunction===causes --wiring ---EVAP cannister purge valve ---ECM
check the wiring for breaks , bad connections
replace the purge valve
the vent valve is part of the purge system of the EVAP system( fuel system)
Oct 08, 2016 | 2005 Chevrolet Equinox
Tip
Water Softener maintenance tips: By-Pass Valves
There are many types of factory By-Pass valves and 3-Valve By-Passes systems used on residential water treatment equipment. Over the course of years if these valves have not been used they become very hard to turn and may require the use of a wrench to turn them. This can create a big problem if an emergency occurs with the water treatment system and the water needs to be turned off. Using a wrench on any bypass valve has the potential to break it and then it won't work or worse, you have a flood on your hands as water comes gushing out of the valve!<br />What is the solution? The easiest solution is to turn the by-pass valve on and off several time every time you add salt to the system. By doing this it loosens any debris, keeps the o-rings lubricated an the valve moving freely. <br />Many systems incorporate by-pass valves with handles that simply turn 90 degrees for on and off. While manufacturers like GE, Sears, Ecowater, Culligan, Northstar, Hague among others incorporate a simple push pull valve to by-pass the system. Other companies by-pass systems may be "hardplumbed" with a 3-Valve by-pass that incorporates an inlet, outlet and center (By-Pass) valve to divert hard water past the treatment system when needed. <br />Which ever type is used with your system it is best to turn or push these valves ON and OFF several times every time salt is added (generally quarterly) to assure proper operation of the by-pass system to prevent any problems when it is crucial for them to work properly.<br />Practice these tips and your water treatment system will give you many years of quality water with fewer service issues.<br />Good Luck and Good Water,<br />RJ<br /><br />
on May 22, 2011 | NRS Fleck 5600 - 64,000 Grain Timer Water...
What is a fuel trim bank 1 on a 2006 xc90 volvo an whatvis a evap emission system switching valve mean
  • P0170 Fuel Trim Malfunction Bank 1 OBDII Engine Light ... www.engine-codes.com/p0170.html Possible Causes and Repair Information for P0170 code. Learn what does P0170 means? P0170 Fuel Trim Malfunction Bank 1
  • P0170 Volvo Fuel Trim Bank 1 - Car OBD Code www.carobdcode.com/p0170-volvo-fuel-trim-bank-1 Dirty air filter, air filter housing or Mass Air Flow (MAF) sensor, or faulty MAF sensor are common causes for the P0170 Volvo code.
  • P2420 Volvo Evaporative Emission (EVAP) System Switching ... www.carobdcode.com/p2420-volvo-evaporative-emission-evap-system... Trouble Code Description: Evaporative Emission (EVAP) System Switching Valve Control Circuit High
  • P2420 Evaporative Emission System Switching Valve Control ... www.engine-codes.com/p2420.html P2420 Evaporative Emission System Switching Valve ... Evaporative Emission System Switching Valve ... P2420 SCION Evaporative Emission Pressure Switching Valve ...
    http://www.carobdcode.com/p2420-volvo-evaporative-emission-evap-system-switching-valve-control-circuit-high#.V4_T_uSV-P8
  • http://www.carobdcode.com/p2420-volvo-evaporative-emission-evap-system-switching-valve-control-circuit-high#.V4_T_uSV-P8
    Jul 20, 2016 | 2006 Volvo XC90
    What is a pcv valve
  • How the PCV system works - Agco Automotive www.agcoauto.com/content/news/p2_articleid/197 What are the Symptoms of a Bad PCV Valve. ... Symptoms of a bad PCV valve. We see varied symptoms from a bad PCV valve, depending on the way it fails.
  • Crankcase ventilation system - Wikipedia, the free ... https://en.wikipedia.org/wiki/PCV_valve The PCV valve is only one part of the PCV system, which is essentially a variable and calibrated air leak, whereby the engine returns its crankcase combustion gases ...
  • How does a positive crankcase ventilation (PCV) system ... auto.howstuffworks.com/positive-crankcase-ventilation-system.htm How does a positive crankcase ventilation (PCV) ... Positive crankcase ventilation involves recycling these ... the PCV valve is designed to close off when this ...
  • What does the PCV valve do? - Autorized.com www.autorized.com/auto-maintenance/what-does-the-pcv-valve-do.shtml What does the PCV valve do? By Jakob Jelling Autorized.com. The PCV valve is a control device which sends partially burned gases that come from the engine's ...
  • Jan 17, 2016 | Cars & Trucks
    What does code p0446 mean on a 2001 Buick Centry?
    P0446 Evaporative Emission Control System Vent Control Circuit Malfunction The code P0446 is set when the engine computer recognizes a fault or restriction at the vent control part of the Evaporative emission control system (EVAP). The description of the fault varies between different car manufacturers, but one thing is common, the code P0446 doesn't directly point to a defective part; some testing might be required to pinpoint the faulty component. What can cause the code P0446: - faulty vent control valve - blockage at the vent hose, vent filter or vent control valve - open or short in the vent control valve circuit - bad charcoal canister - EVAP system leak - faulty EVAP system pressure sensor - bad vacuum switching valve (VSV) - stuck open purge valve (solenoid)
    Aug 13, 2014 | 2001 Buick Century
    Code p1443
    without knowing your make or model:
  • p1443
    Evaporative Emission Control System Control Valve
  • audi
    EGR Valve Position Sensor Signal Too Low
  • bmw
    Leakage Diagnostic Pump Control Circuit Signal High
  • ford
    EVAP Control System Purge Control Solenoid or Purge Control Valve Fault
  • hyundi
    EVAP System Tank Cap Missing
  • infinity
  • lexus
    Secondary Air Injection Vacuum Switching Valve Circuit Malfunction Bank 2
  • mazda
    Evaporative Emission Control System Large leak detected
  • mitsubishi
    EVAP Purge Control Valve 2 Circuit Malfunction
  • nissan
  • suburu
    Evaporative Emission Control System Vent Control Function Problem
  • suzuki
    EVAP Purge Control Valve Malfunction- Stuck Open
  • toyota
  • volkswagon
  • Dec 07, 2013 | Cars & Trucks
    Fill-trol what does do on the heating system?
    How the Amtrol FILL-TROL(c) Expansion Tank System Works:
    Water enters the FILL-TROL valve, pushing open the check valve, and flows into the heating system. The automatic shut-off valve is kept open by the diaphragm pressing against the pressure plate, raising the stem of the fill gate, which compresses the automatic shut-off valve spring. When the heating system reaches fill pressure, the tank's diaphragm depresses, and the automatic shut-off valve is closed.
    Whenever system pressure falls below 12 psig, the automatic shut-off valve is pressed open by the diaphragm. Make-up water flows into the system to restore pressure.
    http://www.plumbersurplus.com/Prod/Amtrol-110-FILL-TROL-Expansion-Tank-4-4-Gallon-110-1/7938/Cat/219
    The AMTROL FILL-TROL(c) system consists of a specially adapted EXTROL pre-pressurized, diaphragm-type expansion tank, and the FILL-TROL, a specially designed, automatic, fill valve.
    • Provides accurate system make up
    • Eliminates need for a separate, automatic fill valve
    • Fully adjustable up to a maximum working pressure of 100 psig
    • Factory pre-charged; tank pressure controls system fill
    http://www.amtrol.com/filltrol.html
    Nov 08, 2013 | google.com
    Can the a/c on 2002 Ford Explorer be re-charged with Freon or is it actually a sealed system?
    All systems can be charged, there are valves to charge the system up, theres a highside and a lowside valve, the highside is the larger valve and the lowside is the small valve. the system is charged through the low side valve. good day.
    May 15, 2011 | 2002 Ford Explorer Sport Trac
    What does po440 on a 2003 saturn vue mean with a service engine soon light on
    That is a problem in the evaporative emission control system.
    Could be anything causing it
    Clogged filter in the charcoal canister
    A leak in one of the vacuum lines
    The purge valve not working,,,etc.
    The best thing is to take it and have it checked out, they might have to do a smoke test to find the problem.
    All they do is inject smoke into the system, if there is a leak the smoke will come out of it. All it takes is a pin hole in these emission systems to screw it all up.
    Aug 13, 2010 | 2003 Saturn VUE
    I checked the codes and one comes up its po446. i dont under stand what it mean so i cant fix it to get the light to go out.
    P0446 Evaporative Emission System Vent Control Circuit.
    The following are descriptions of all Evaporative possible codes:
    P0441 Evaporative Emission System Incorrect Purge Flow
    P0442 Evaporative Emission System Leak Detected (small leak)
    P0443 Evaporative Emission System Purge Control Valve Circuit
    P0444 Evaporative Emission System Purge Control Valve Circuit Open
    P0445 Evaporative Emission System Purge Control Valve Circuit Shorted
    P0447 Evaporative Emission System Vent Control Circuit Open
    P0448 Evaporative Emission System Vent Control Circuit Shorted
    P0449 Evaporative Emission System Vent Valve/Solenoid Circuit
    P0450 Evaporative Emission System Pressure Sensor/Switch
    P0451 Evaporative Emission System Pressure Sensor/Switch Range/Performance
    P0452 Evaporative Emission System Pressure Sensor/Switch Low
    P0453 Evaporative Emission System Pressure Sensor/Switch High
    P0454 Evaporative Emission System Pressure Sensor/Switch Intermittent
    P0455 Evaporative Emission System Leak Detected (large leak)
    P0456 Evaporative Emission System Leak Detected (very small leak)
    P0457 Evaporative Emission System Leak Detected (fuel cap loose/off)
    P0458 Evaporative Emission System Purge Control Valve Circuit Low
    P0459 Evaporative Emission System Purge Control Valve Circuit High
    At least the cap isn't loose for the gas tank.
    I would clear the code with an OBD-II Scanner 'erase code' button, and see how long it takes for it to come back.
    Aug 06, 2010 | 1996 GMC Jimmy
    Moen Trim kit for 2 handle lav with drain assembly - T6506CPM - Platinum Logo
    63 people viewed this question
    Top Moen Plumbing Experts
    john h
    Donni Steen
    Don Numinen
    Don Numinen
    Are you a Moen Plumbing Expert? Answer questions, earn points and help others
