Question about Hitachi 43FWX20B 43" Rear Projection Television
My TV had a green look to it, tried the auto focus and it stopped half way through the green focus. Then the screen went out of focus and double colors
    Brigadier General:
  • 4,090 Answers
You have a convergence board failure It is recommenjded by the manufacturer to replace all 3 boards bOth sustain boards and the power board when this problemn occurs. Just replacing the Sustain board is only a temporary fix , about a day or maybe two days before the problem happens again. This gets expensive as a DIY as it really id not a DIY unless you have knowledge of circuitry reading voltahe checking equipment and the ability to generate a hatch pattern on the screen to correctly realign the guns to the screen.
The cost of parts is $250=300 but labour is unknown as i am in Australia and you are probably elsewhere
If its under warranty get it fixed before expiry
But generally its a total of 5-600 in USA so there is a ball park figure for you to go on. get quotes before proceeding as there are a lot of crooks outr there
Please rate my help++++ Thanks for iusing FIXYA
Posted on Nov 20, 2009
2 Suggested Answers
roety
  • 585 Answers
SOURCE: My TV started showing light green color in the
Hi my name is Roety,
I can help you with your issue ,
Most likey you need the convergence ICs replaced.
A repairman would charge about $350 to replace them
Voltage checks and a visual would be needed to determine exactly what is bad in your TV
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Green screen
It depends on how green it went----the set has a block with screen and focus controls---you do not want to touch the focus controls but you could try to lower the GREEN screen until you have a normal picture.
Let me know and I will tell you how to access and adjust for this issue.
Jan 16, 2012 | JVC AV48P776 48" CRT TV
Rectangle in led screen green/ or yellow with exclamation
The camera doesn't have anything to focus on - especially if you're shooting the sky. The auto focus needs something with fairly defined edges to work. Try to focus on the edge of a well defined cloud, or focus on a tree or similar, half depress the shutter to lock the focus, then move re-frame your shot. Alternatively you can use manual focus. Hope that helps
Jul 24, 2010 | Canon PowerShot SX210 IS Digital Camera
My TV started showing light green color in the white areas. Then about a week later when using the auto focus, it stopped when the green focus came up. Short after that the screen went out of wack, waves...
I will reply asap
Thanks
Nov 20, 2009 | Toshiba 42H81 42" Rear Projection...
Toshiba 57h81 green will not focus
Typically this is a convergence problem and can be repair relatively easy. Refer to this video to determine if you truly have a convergence problem. Also make sure you use your TV's original remote to make this adjustment.
Nov 15, 2008 | Toshiba 57H81 57" Rear Projection...
Double focused, red and green, bow in picture top and bottom
hi
You have a convergence problem
If the set has auto focus and will not complete its cycle.
The Auto focus module is bad, (expensive)
If it completes and the problem is still there.
Then check for bad conv. drivers (stk****) or cold solder joint on one or more of the 3 drivers pins.
Guy9
Jul 08, 2008 | Hitachi 65S700 65" Rear Projection HDTV
Sony kp-46wt-500 tv help
if your set has auto focus try activating it if not you require a convergence alignment.
Apr 13, 2008 | Sony KP-53N77 TV
RED AND GREEN DOUBLE AND BLUR PICTURE HELP PLEASE
You have a convergence problem. Components are shorted out and must be replaced. Unless you're a technician, there's really nothing you can do at this point.
C-Dog
Feb 03, 2008 | JVC AV-56WP74 56" Rear Projection...
Hitachi 43FWX20B 43" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
