Question about LG 52SX4D 52" HDTV
The picture is green and pink only just chaned the
The picture is green and pink only just changed the lamp what could it be?
Just chaned ink cartridge and every thing printed out pink clean the pink and now nothing is printing tried cleaning the head and did the nozzle check and still not printing
It seems to me, if you have changed your colour cartridge that is, that you do not have enough black ink in your black ink cartridge, so you should change this also.
Barbara Grey
Oct 15, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Yesterday, our 61 inch panasonic projection tv showed pink colors on the lighter colors in the picture. This morning it has two large black stripes across the picture. What could this be? We changed the...
You may have not reset the lamp counter after replacing the physical lamp. To do this 1. Press the “POWER” button so that the projector projects the picture on the wall (projection screen)
2. Press the “MENU” button to show the “MAIN MENU”
Use buttons “F” or “G” and select “OPTION”
3. Confirm this by pressing “ENTER” so that “OPTION” is shown
Using buttons “5 / 6”, select “LAMP RUNTIME” (lamp operation counter)
4. Select and press the “ENTER” button for at least 3 seconds
5. The “LAMP RUNTIME” (lamp operation counter) will change to “TIME RESET[POWER OFF]”
6. Turn the device off by pressing “POWER” and unplug the power cord
Sep 09, 2010 | Panasonic Televison & Video
Pink line across top of sony wega 46" tv
after changing the lamp, I still had the same problem as you. I contacted sony and they offered me a brand new 40 inch bravia flat screen tv replacement...at no cost! If I chose a 46" or 55" there would be a charge between $325
Dec 24, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
I replaced the XL-2400 complete bulb replacement now I have a pink hue at the top of my screen and green hue at bottom of my tv screen
I change the lamp 4 my tv sony vega XL-2400 and I steel send me a signal to change the lamp what can I do 4 setup.
Oct 05, 2009 | Sony Office Equipment & Supplies
Line pink and green
this would definitely won't be the lamp, the issue is either with you video board or the dmd board, go to the menu and if that line still shows up on the menu, the issue will be with your dmd board, on the contrary the issue would be with your digital video board
Jul 21, 2009 | Samsung HCN436W 43" Rear Projection...
Color gets hazy & basically is only pink & green
try to open the unit.then check for anything suspicious, like connectors if properly connected etc.then , power it on.look for something that causes the fan to stop running or anything related to that.check the lamp, too.
May 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Display has gone bad with fine vertical pink lines
Connect an external monitor to your laptop, if you get a clear image on this monitor the the video card in the laptop is OK.
The fault could be a defective inverter that supplies high voltage to the CCFL lamp or a faulty CCFL lamp. Most likely a faulty CCFL lamp.
Defective CCFL backlight may has the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) as reached the end of the life and all you need to do is replacing the CCFL lamp
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 06, 2009 | Toshiba Satellite 5205-S703 Notebook
My NEC MT850 projects with a pink picture you can still see image but it is a very bright pink.
A pink image normally means a loss of green signal.If you are using Computer input you should try replacing your input cable to see if this is the problem. If it is pink with video also then the projector most likley has a internal problem.
Mar 05, 2009 | NEC MT850, MT1050, MT1055, MT1056...
Picture distorted
this a problem with the motherboard. not the lamp.
Feb 05, 2009 | Toshiba 56HM195 56" Projection HDTV
Picture problems
CRT green gun is not working properly , maybe dry soldered or no green drive signal. Pink and red colour is due to missing of green colour.
Sep 09, 2007 | Sanyo DS27820 27" TV
Open Questions:
See all LG 52SX4D 52" HDTV Questions
LG 52SX4D 52" HDTV Logo
Computer Repairing
Computer Repairing
