Question about Panasonic DMC-TZ5 Digital Camera
Pictures turn out red with backlight need to turn if off
Somehow a backlight got turn on on the camera, we can't get it off. It comes on with BACKLIGHT and a yellow arrow on the lower right screen, and the pictures come out very red. We can't seem to fix it. We have intelligent auto on and auto flash.
    Brigadier General:
  • 11,967 Answers
Go into the menu and scroll to "reset" and follow the on-screen instructions.
Posted on Nov 20, 2009
My rebel XTi won't connect to my mac.
I had the same problem but solved it with iphoto: after turning on the Mac, plug in the XTi and wait for a moment for iphoto to pick up the camera. Rest was an auto process.
May 17, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Picture come on for about 2-3 minute, then goes out has sound no picture, red light come on near power button
Ur LCD inverter backlight board is dead.Replaced this LCD inverter backlight board to get the picture back.Tries Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlight board for the replacement.
Mar 03, 2010 | Philips 60PL9200D Projection Televisions
Camera turns on fine. I could view picture and all. Just that when I switch to camera mode a video screen is blacked out. Why is that?
Your have a "Display" button that toggles thru different display modes .. one of the modes turns off the LCD backlight .. that useful if you are in bright light and dont need the backlight .. you have a very nice "transflective" display that works great in bright light without the backlight ... you can get more shots with the backlight turned off on each battery charge .(about 25% more) .
so each time you operate the display mode button you will get a different display .. one shows a hystogram .. one turns off the backlight and one puts the camera in a normal mode ..
if everything is working right then even with the backlight turned off you should be able to go outside or any brightly lighted area and see the picture on the screen ..
Sep 04, 2009 | Sony Cyber-Shot DSC-T33 Digital Camera
Screen flickering when turning on laptop and sometimes the laptop turns on after flickering and sometimes doesn't turn on at all after flickering. Just stays black.
You may have a faulty inverter or loose power inverter connection. OR
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Sep 01, 2009 | Acer Ferrari 5005WLMi (LXFR506119) PC...
Acer 5515 backlight problem
Defective CCFL backlight may has the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 03, 2009 | Acer Aspire 5500 5570-2609 Laptop
HP Pavilion dv9500 lcd screen issues. Turns pink after warms up.
Mar 29, 2009 | HP Computers & Internet
Compaq 7550 monitor keeps turning pink. Works fine for a few minutes then back to pink and hard to see. Sometimes moving the mouse quickly will help but only for a few minutes. Have tried adjusting all...
· Screen flashs on red/pink and off.
· Picture stays on in red and slowly be come normal.
· Picture flickering with dim display.
· Picture flickering on and off.
Mar 14, 2009 | Acer Aspire 5500 5570-2609 Laptop
The screen is dark on my e71; the back light is off
It seems you have a backlight failure. If you can still see the screen on the device (as far as texts and pictures), you would simply need to replace the screen in the device.
Dec 22, 2008 | Nokia E71 Smartphone
Pictures come out red
Hey JRochester,
I would make sure the white balance settings were not changed somehow. Depending on your level of expertise I would set the white balance to auto if you are not familiar with white balance, and if you are make sure the white balance is set to your shooting conditions each time you capture and image.
Sincerely,
Allan
Go Ahead. Use Us.
May 06, 2008 | Nikon D50 Digital Camera
Flash icon
Same problem with the red flash icon. I can take a picture if I turn off the flash as well, but have to turn off the flash every time I open the lens. Have had the camera for 5 years and haven't had a problem. We needed to replace the lens cover recently and after we replaced the cover we started having this flash problem. It was working fine before the cover came off which leads me to believe we've changed our settings somehow....pleas
Dec 26, 2007 | Olympus Camedia Stylus 300 Digital Camera
Panasonic DMC-TZ5 Digital Camera Logo
137 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
