Question about Frigidaire GLRS264ZA Side by Side Refrigerator
Bad Oder My unit has a bad oder when doors are opened .Freezer and refrig have been cleaned but oder is still there.
  • 236 Answers
Some unit have odor filter try to read your manual, if there is an odor filter then you have to change it.
sample only...
Posted on Jan 12, 2008
My dishwasher emmits a strong bad oder when i open the door
Roll up your sleeves and do the mother of all cleaning jobs. Use chlorox bleach all over and rinse. Then clean all with sudsy ammonia. Leave nothing untouched. Check under the gaskets, everything and clean thoroughly..
Jul 31, 2015 | Dishwashers
I purchase 3 months ago a pair of Chaco with black sole,I can get bad oder of stinkly feet.Please help me! What can I use to clean them? "Love wearing them
fill with baking soad an put in the freezer. moisture will be absorbed and oder causing bacteria killed. if smell persists consider putting insoles in the washer. allow to air dry
Sep 12, 2013 | Chaco Maddie Shoes for Women
My Kenmore Refrigerator is not refrigerating
if the freezer and fridge are warm check the start device on the compressor,alot of times you can smell a burning oder when this pops,also you can remove it and shake it,if you hear pieces rattling around then it's bad,also if there's ice on the back inside wall of the freezer then you have a defrost problem,also when you open the freezer door do you hear the fan blowing,if not you could have a bad defrost fan motor,open the fridge door,up near the ceiling on the right side you'll see the model number,send it to me,let me know if you found ice or frost on the back wall of the freezer or what you see and i'll be glad to help you
Oct 31, 2010 | Kenmore 53642 / 53644 Side by Side...
BAD ODER COMING FROM THE A/C UNIT.
Replace Cabin filters.
A/C system may need to be cleaned.
Oct 25, 2010 | 2005 Nissan Quest
Ice can not be used, has a bad oder (it has always had this ; at first I thought it was because it was new). What do I need to do to get this oder out of the ice unit?
install a add on water filter and do replace the org one inside at same time . these odors come from the water and it needs to be filtered . other oders come from un covered food and meats n freezer that are not cold enough . freezer tempt need s to be around 0 to 5 deg . .. hope this hepls mm ..
Aug 17, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
I have an oder in my fridge and freezer. no spoilage in there. both the fridge and freezer has an odor and gets into all the food. cleaned it out, shut it off for a day and still i have it. would would...
ok.its a very common issue.just tie a handful of baking soda in a soft cloth and keep such1 or 2 pads in both the freezer and fridge section.this will absorb all the bad odor within a day or two.once the odor is gone throw the pas away.repeat this once in three months to prevent the bad odor from coming again.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Feb 28, 2010 | Amana ABB1927DE Bottom Freezer...
Has a bad oder - water seems to sit in the tubular connection. What do I do to remove the smell?
their is a cleaning kit called affresh available at most lowes stores in the appliance department that if u follow the directions will help alleviate the problem. these units r sealed sysems and after u shut the door they do not breath, it would be like never cleaning your shower after using it and just shutting the door. follow the directions and make sure u repeat it about once a month. it might take two or three tries the first time to knock odour down, but it will come back without regular maint.
Oct 08, 2009 | Kenmore Elite 45986 Front Load Washer
I have a very bad odor coming fron m my GE Zoneline 2100 ac unit. What can i do to get rid of the smell?
You have what they call dirty sock oder. You need to clean the coil. Use bleach 50-50 mix and spay the coil let it set a few minutes and spray water on it to rinse. Russ
Jul 26, 2009 | Heating & Cooling
Horrible oder
You are going to have to take the back cover off and investigate. Check the defrost drain pan first. If anything from the freezer, like raw meat juice, went down the defrost drain, it would end up in the defrost drain pan, usually located very near, possibly on both sides of, the fan motor at the bottom of the refrigerator. The next thing to look for is a dead mouse. They like the warmth from the refrig., and can get killed from a fan blade, electrocution, or if they ingested poison, that makes them thirsty and the warmth plus the availability of the water from the defrost drain makes an ideal place for the to curl up and die. (A dead mouse usually dehydrates and stops smelling after a few days.) All that sounds like lots of fun, right? Happy hunting and good luck.
Jan 13, 2009 | Kenmore Refrigerators
Oder inside washer
On newer other machines, there is a cleanout cycle that uses 2/3 cup of bleach, no detergent and I believe uses more water. Suggest you use a load of white towels, no detergent, the bleach and put it through a normal or soak cycle where the bleach has a chance to kill off the germs and other bacteria, then rinses itself clean. They also recommend that the door be left open on these machines to allow the moisture to clear and dry assisting in curtailing further development of the same. The cleanout procedure they present is suggested for monthly using their special cycle which doesn't exist on my HE3T either. Hope this helps some. NOTE: There are cautions about leaving the high level of concentrations in the washer for extended periods or too often.
Sep 08, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Frigidaire GLRS264ZA Side by Side Refrigerator Logo
203 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
