Question about Maytag LAT3600A Top Load Washer
Will not fill with water,it will only operate on spin cycle
  • Maytag Master
  • 3,051 Answers
Hello there
This a fairly common problem ...most likely you need a new water control valve. This valve turns on the cold water for cold, the hot water for hot or both hot and cold for warm water cycles. ok it will cost around 100 dollars depending on the exact model it may be less ok and it is fairly easy to change out which will save you tons of money by doing it yourself just get the part at your local appliance parts repair center and they should be able to tell you or have a diagram on this , or if you wave a warranty still on this you cvan use it too ok?
I hope that this has been very helpful for you
Best regards Michael
Posted on Nov 20, 2009
SOURCE: washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Posted on Feb 21, 2009
  • 14 Answers
SOURCE: water runs but doesn't fill tub and wont spin if put on spin cycl
The drain hose must be higher than the tub of the washer so many times I get called to find the hose on the ground to the drain an this will not let the tub fill.
Posted on Jan 28, 2010
jsrock516
  • 5911 Answers
SOURCE: During the spin cycle water pours continuously like fill cycle
This problem is commonly attributed to either a water inlet valve leaking by, or a pressure switch malfunction. The following link explains how to diagnose the problem:
http://www.fixya.com/support/r3753517-whirlpool_top_load_washer_fills_when_not
I've included parts sources (if required) and how to repair each problem. If you have any questions, please post back and let me know. I hope this information is helpful to you.
Posted on Mar 19, 2010
jsrock516
  • 5911 Answers
SOURCE: washer fills with water will not go into wash cycle and spin out
You need to check your lid switch. This is the most common cause of the problem you are experiencing. Symptoms may include, filling and stopping on the intial fill cycle, stopping right after the wash cycle, not advancing to rinse or spin cycles, and a wash tub that will not drain.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
NOTE: You do not have to drain or bail the water from the washer tub to perform this repair. Once a defective lid switch is replaced, the washer should drain normally.
A replacement lid switch (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average price is about $20 - $30 if you perform the repair yourself. Prices differ between sites so shop and compare.
If you have questions, or need additional assistance, please post back with a complete MODEL NUMBER and let me know. The lid switch is a very simple repair that you can easily perform without the assistance of a repairman.
If this advice does not help you enough, repairclinic.com has a Repair Manual you can order to assist you with all your repairs. The part number is 1170635 and is priced at about $20. Searspartsdirect.com also has a repair manual for about the same price. Part number 4314044L. I hope this information is helpful to you.
Posted on Jun 08, 2010
Testimonial: " I had a repairman check it out. And it was the lid switch. Thanks for the information."
heatman101
  • 43501 Answers
SOURCE: WASHER SPIN CYCLE WON'T WORK. IN ANY CHOSEN SPIN
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Sep 18, 2010
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
Hi, our simpson enduro 701 washing machine does not spin back and forward in the deep rinse cycle. but operates ok and spins in spin cycle. thankyou Tina.
Hi Tina just read your posting. From the information in your posting the machine fills, then when the machine is full of water the agitator moves clockwise then anticlockwise until it gets to the rinse cycle then drains the water ,then it fills for the rinse cycle but does not move the agitator in the rinse cycle.Then it drains and spins the clothes dry .Is this assessment of your posting correct.If it is not 100% correct please reply to tell me what the machine is doing or not doing.If it is correct then the problem with your machine is the control board.Is your model the electronic one with the push buttons?Looking forward to your reply.
Jun 26, 2010 | Washing Machines
Wont fill or spin runs dry
Check the water pressure switch for proper operation
Oct 19, 2009 | GE WBSE3120B Top Load Washer
We just purchased a top load Kenmore 800 washer machine. We have washed 2 loads of clothes and Now it has stopped filling up with water. It will not do it to wash or to rinse. We have gone thru the mannual...
The first thing seems to be the timer,or the water level switch. Try filling the washer with water by hand, if it starts to agitate after being filled its the timer, if not it is the water level switch, let me know if you need further assistance.
Mar 13, 2009 | Washing Machines
Washer will fill fill with water but doesn't start wash cycle
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Washer won't advance from cycle to cycle
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
* It's the timer, if your washing machine fills with water and begins agitating, but the timer never
advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace
the timer.
* It may be a cold-water supply problem, if the washing machine fills with water, agitates,
drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Nov 16, 2008 | Danby DDW1805W Designer Series...
Kenmore washer model 110.49722990 it will not go into the drain or spin part of the cycle, just sits there and hums, won't do anything. It will fill with water and wash,but thats all it won't finish the...
Does it fill with "cold" water?Will it spin?Drain?If the machine will fill up with cold water,will the timer advance by itself to finish?Or if you place the timer in spin cycle will it spin?First off if your not getting "Cold" water to fill inside :Replace the water valve (because when the timer stops after the agitation cycle it wont advance because it cant fill up with cold water.
May 23, 2008 | Kenmore Washing Machines
Spin cycle issue
if this is a frigidaire as in the healine , then see if the tub turns over at all. if not then it may be the inverter board located on the bottom right rear. If there is water left in the tub now that water should drain before it will fill again. check drain pump for obstruction/operation.
for the inverter, there is a techsheet in the bottom attached to the wall, It gives info for checking it. Have a multimeter handy.
Apr 23, 2008 | Frigidaire GLTR1670A Front Load Washer
Maytag LAT3600A Top Load Washer Logo
206 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
