Question about Mitsubishi VS-45607 45" Rear Projection Television
It stays on for a different length of time each time it's turned on. Sometimes will work for many hours per night and 4 or 5 nights, sometimes will stay on for only a few minutes. When it shuts down, you see the 3 color horizontal lines (r,g,b) colapse toward the center of the screen and then goes black and the power goes off. You can immeditely turn it back on, but it will shut down again quickly. if it sits for a while it will stay on for a longer time, usually. I tried to re-solder all the connections on the 3 - CRT circuit boards, since this was a common issue that supposedly caused this problem, but that didn't help.
  • Mitsubishi Master
  • 1,210 Answers
This tv is aging and you many bad grounds on the deflection board [it has the flyback transformer] And many bad grounds on the signal module [has convergence ICs]. And many many bad capacitors..I know as I repaired a few of these.
Posted on Dec 25, 2009
Can I set the Malibu 8100-0600-01 to operate at 2 different times at night-(ie- on at 7:00pm-off at 10:00pm then on again at 5:00am and off at 7:00 am)
Yes: Rotate power pack selector to ON. Buy analog wall timer with 3-prong plug from local store. Plug power pack into analog wall timer that will turn power pack on-off twice a night.
Copy following link to identify timer and also see tips for prolonging power pack life:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#dawn-dusk
Analog timers:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59200
The 1-year warranty digital transformers sold by Malibu and other vendors are made for single on-off events per each night.
If you manually set power pack to ON so lights are on all the time, then plug power pack into ordinary analog wall timer, then the analog timer turns power pack on-off when you want.
Other option is to buy 5-year warranty Intermatic-Malibu power pack with built-in analog timer dial and set trippers to turn on-off when you want. Order extra trippers for more on-off operations per each 24-hour day.
Gene
h
Aug 20, 2013 | Hardware & Accessories
My Liftmaster garage door light sometimes stays on all night after operating the door. If I turn off the circuit breaker for an hour or two, then the garage door opener light stays on for the normal 2...
I would just have someone come and check it out to see if it is the light or the electrical. Hopefully it is only a matter of cleaning it off and and replacing a piece or two. Good luck with the repairs and hopefully it is nothing to serious.
Jason http://goodrowdoorsolutions.com/products-and-services.html
Mar 02, 2013 | Sears Craftsman LiftMaster Chamberlain...
Works sometimes sometimes not
It could be a lot of things; such as, faulty wire connection, cold solder joint, HV voltage arcing, corroded battery terminals. intermittent short in the switches. If it stop work, try gently shaking it several times, push the on/off button several times. make sure the battery makes a good connection in the battery compartment. Wrap it up and put it in your freezer for a few hours. There are electronic components that might get hot/warm and by cooling them down they will start working again. GB...stewbison
Aug 30, 2011 | Night Owl Optics Explorer NOCX3G Monocular
Hey im having a problem, basically all im trying to do it make it so my heat lamp turns on only at night, so, i set my time to the correct time right now and then i pressed prg, set the days (everyday)...
http://waterheatertimer.org/GE-timers-and-manuals.html#zilla
http://waterheatertimer.org/pdf/Zilla-digital-manual.pdf
1) There is no repair for defective timer.
According to manual, under Initial Timer Operation: yellow outlet is ON at 4:00 pm.
Make sure Mode button is not set to OFF.
2) Scheduling timer: Think about the zilla timer this way:
Day is 12 hours and night is 12 hours.
Your total schedule is only 9 hours, but it overlaps day and night.
If timer 'night' starts at 6pm and ends at 6am, then your programming overlaps day and night.
If timer 'night' starts at 12midnight and ends at 12noon, then your programming still overlaps day and night.
3) To solve zilla time problem, set current time differently.
4) Or buy GE or Utilitec 24-hour programmable power strip
Take a moment and vote on answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 28, 2011 | RTO Zilla 24/7 Digital Timer Power Center
TV won't stay on for more than 10 minutes. Won't turn on at all s
Sounds like a power supply issue. Is it out of warranty? If it is, open it up and check the power supply bd. for swollen capacitors....
Apr 07, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
NVN3: No difference with power on or off
Most night vision when switched off will stay 'on' for a period of time. After a short time you should not see anything just black. You can't look through a night vision monocular that has been off for a while. The image you see is actually an image on a screen inside unlike a regular monocular or binoculars. Turning it on powers the screen. When turned off the screen is still warmed up and takes time to turn off. Like some old TV's. If you haven't used it for some time and pull it out for night viewing and can see a picture when you haven't pushed the on button. The unit is malfunctioning as it is staying on.
Jul 06, 2009 | nVision NVN3 Monocular
Oven Doesn't Even turn on
The oven thermostat controls the oven temp. It is not working and you need a new one.
Jul 01, 2009 | Roper FGP305 Gas Kitchen Range
Beeping at night
if it beeps you might as well just unplug it
Dec 08, 2008 | Panasonic NN-C994S Convection/Microwave...
Oven
sounds like a bad ignitor, sometimes lighting and not relighting during extended cooking time. dies it take longer than a minute to ignite gas? more then 10 in to preheat? smell gas while cookin?? all signs of a bad bake ignitor
Mar 08, 2008 | Magic Chef CGR1110 Gas Kitchen Range
Tmobile Mda Wont Turn On
I would call them at 1-800-t-mobile to make sure your service is set up correctly (if it isn't it may explain why it takes so long to locate the network) or you could use their customer care site at http://www.t-mobile.com/Contact.aspx to find a store that will replace/repair it for you.
Oct 13, 2006 | T-Mobile MDA
Mitsubishi VS-45607 45" Rear Projection Television Logo
76 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
