How do u remove lcd inverter for dell vostro 1000
    President:
  • 2,653 Answers
Pretty much every laptop is the same. Dell, HP, Gateway. Just use the same principles. Most have either rubber or plastic over the screws around the lcd plastic. Just find them, unscrew the screws and carefully pull the lcd apart. Video should give u an idea.
Posted on Nov 20, 2009
In my dellvostro a860 , rite side of the screen colours are spreaded,it it looks like shade,,whats the problem in that i m not getting please help me..........
It is the screen Inverter, or the LCD screen itself.
Screen Inverter: A small circuit board located behind the Display Bezel, and mounted towards the bottom of the LCD screen,
http://support.dell.com/support/edocs/systems/vosA860/en/sm/display.htm#wp1183775
The yellowish long object, at the bottom, is the screen Inverter.
Here is another look at it,
http://www.batterycenturys.com/dell-vostro-a860-inverter-p-185294.html
Dell Support > Vostro a860 Notebook PC > Service Manual,
http://support.dell.com/support/edocs/systems/vosA860/en/sm/index.htm
In the list clicking on -> Display, will get you to the first link above.
Need guidance in replacing the screen Inverter, post in a Comment.
(Just a basic guide using a Vostro 1014/1015 Notebook PC. Not yours, but good for basic guidance. This is replacing the LCD screen,
http://www.insidemylaptop.com/replace-lcd-screen-dell-vostro-1015-1014-laptop/
[ Primer:
An LCD screen cannot produce light by itself,
http://solutions.3m.com/wps/portal/3M/en_US/NA_Optical/Systems/BehindTheScenes/Optics101/
( Click on the small window with the monitor in it )
It needs an additional light source. A Backlight is the additional light source.
A Backlight can be a CCFL, (or more than one), or a series of LED's used as lights.
The Dell Vostro a860 Notebook PC uses one CCFL, for a Backlight, OR there are Vostro a860's that use LED lights.
(If you replace the LCD screen, make sure FIRST of what type of Backlighting it uses)
A CCFL is a Cold Cathode Fluorescent Lamp. Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
[Average thickness of a CCFL is 2mm. That is a little larger than 1/16th of an Inch.
Average length is almost as long, as the LCD screen is in height ]
A screen Inverter is used to convert the power from the laptop, for the Backlight, and LCD screen.
Most of the time the fault is the screen Inverter.
The Vostro a860 Notebook PC's, that uses LED's as a Backlight, MAY also use a screen Inverter.
Primer over.
For your problem it could be the screen Inverter, but I lean more towards the LCD screen itself, is the problem.
How to test a screen Inverter? Requires a very sensitive multimeter.
Read; Expensive,
http://www.fonerbooks.com/test.htm
For a layman who does not have access to a sensitive multimeter, the method is to just replace the screen Inverter, and see if it is the problem.
'Parts changing', I know, but if you do not have the proper equipment to test with?
Screen Inverter replaced, and problem still persists, replace the LCD screen,
http://www.laptopscreen.com/English/model/Dell/VOSTRO~A860/
For additional questions please post in a Comment.
Regards,
joecoolvette
Jun 23, 2012 | Dell Vostro A860 Notebook
HOW TO REMOVE SCREEN FROM DELL VOSTRO 1000 AND CONNECT TO A MONITOR
if laptop is still running with a broken LCD screen , it id possible to use an external monitor, if laptop totally died or broken, not possible to use with external monitor.
Mar 26, 2012 | Dell Computers & Internet
Dell vostro 1000 laptop power problem.when you plug in the power supply before its plugged into the computer the green lite is onwhen you plug the adapter into the laptop the light goes out and there...
older vostros usually have a broken dc jack right where the power connector plugs in. otherwise try another ac adapter and also try removing and replacing the battery underneath.
Jan 30, 2018 | Dell Vostro 1000 Laptop
I had two lines in my dell vostro 1000 series laptop...what i have to do for that
Sounds like your LCD inverter has gone out.Sounds like you may need to replace it.
Apr 04, 2010 | Dell Vostro 1000
Dell Vostro 1000 Dark screen
Mark, you have nothing with your hardware, just check your Lcd connections, and try again. If it didn't work, you must replace the Lcd once more. Hope it works for you.
Jan 26, 2010 | Dell Vostro 1000
Dell Vostro 1500 Repair manual and parts for backlight and inverter
You cannot replace the backlight. It is incorporated into the lcd panel and not available as a separate part. The inverter board is very easy to replace. It is located right behind the dell logo at the bottom centre of the display panel. Remove the screws on the front of the lcd bezel (under the rubber pads) and the inverter board is right there. Call 1-800-www-dell or look on ebay. Hope it's only the inverter board, as a new lcd panel is $350+. If the display is dead you can still use the laptop by connecting an external monitor to it.
Hope this helps!....let me know how you make out.
Dec 12, 2009 | Dell Vostro 1500 Notebook
I turn my dell vostro 1000 on and the screen is dark but if I hook it up to a another monitor and press fin f8 I can see my desktop how do I check my back light I think this is the problem
The first thing I would suggest is to tighten the LCD hinge screws on the bottom and back corners of the chassis. The LCD grounds through the hinge and if the screws work loose, then there isn't sufficient contact.
If that fails, the inverter or the LCD will likely need replacement.
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=Inspiron+1000+lcd&_sacat=See-All-Categories
Nov 19, 2009 | Dell Vostro 1000 Mobile AMD Sempron...
I HAVE A iNSPIRION 9300 AND A WHITE VERTICALE LINE ABOUT 1" WIDE HAS APPEARED HOW DO i FIX?
Check the rubber connector of the LCD if it's loose, you can do this by pressing at both the edges on the joint of the LCD and if the line dissapears then it's loose, you just have to have it tighten up. Hope this helps.
Oct 21, 2009 | Dell Vostro 1000 Notebook
Need to install a dell vostro 1500 LCD inverter
Are you good with a screwdriver? Here's a step by step procedure for replacing the LCD screen on a Dell 1500.
http://www.insidemylaptop.com/replace-damaged-lcd-screen-dell-vostro-1500-laptop/
Is fairly easy, but be extremely careful of the ribbon cables, they break very easily!
Good Luck!
Jun 25, 2009 | Dell Vostro 1500 Notebook
Computers & Internet Logo
728 people viewed this question
David Payne
David Payne
