Question about Maytag Microwave Ovens
Center plate is not rotating - Maytag Microwave Ovens
  • tandechee Nov 20, 2009
    Yes thank you very mush
  • Maytag Master
  • 3,051 Answers
Hello there:
the reason that your plate is not turning is because there is a drive motor under this that drives the plate.
what you need to do is to unplug the microwave and turn it over and unscrew the bottom of the microwave now turn it back over and lift the top section off or almost all of the way off and you will see the drive motor and shaft assembly now simply disconnect the wires that is connected to it and mark where they went to so you do not forget and remove the motor from the shaft it should just slide out
now get a new motor reconnect the shaft to the motor and reconnect the motor and the wires and you are finished here>
now just put the cover on the microwave and replace the screws and plug in the unit and test and you are finished ok?
I hope that this is verey helpful for you
Best regards Michael
Posted on Nov 20, 2009
How do I replace the interior light bulb?
What model of microwave oven do you have?
jvm3670sf02, you need to remove the exhaust plate above the door. The bulb will be in a pocket to the right of center. Usually there are snap tabs holding the cover in place on top, then rotate down.
Jan 02, 2016 | Microwave Ovens
How can I keep the turntable from revolving when using a dish that is too large to turn?
Try removing the M/W turntable and placing a shallow bowl upside down centered over the rotating device. Then place your plate on top of the bottom of the bowl. The device will still rotate but will not be in contact with anything.
Nov 21, 2015 | Kenmore Elite Black 1.5 Cu. Ft. Convection...
Food not cooking in center
What make and model?? Sounds like it is not a carousel model. Have you tried a "Micro Go Round" ?? Otherwise, try rotating the 'plate' each quarter cycle...ie; every 30 seconds on a 2 minute cook time. Be sure to push the stop button first before you open the door to save wear and tear on the door switches......
Nov 04, 2013 | Microwave Ovens
Center will not rotate
The glass plate is driven by a motor underneath. Power may not be getting to the motor or the motor may have failed
Jan 17, 2013 | Emerson MW8102SS 1100 Watts Microwave Oven
I hv a 24ltr Sharp Carasoul Microwave. Few days back, its plate stopped working, but its heating the food fine. Why has the plate stopped rotating? Will the food be evenly heated even though the plate...
The turntable system typically consists of the motor, the coupler, the turntable support with rollers, and the tray.
Here is a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You order Sharp parts Encompass here or call them toll-free at 866-779-5835.
> Will the food be evenly heated even though the plate is not rotating?
No.
Sep 07, 2010 | Sharp R-1480 Microwave Oven
Glass plate does not rotate
on the bottom of the micro underneath the shield there is a small moter for turning the plate.. also if the plate and roller are not centerd correctly it will not turn ,.. remove the plate and balence a glass on the triangle in the center of the micro shut door and start micro observe if turning ..also some micros have a button selection on the control to reverse the micro plate rotation and stop it --check these things and get back to me..
Aug 10, 2009 | Microwave Ovens
Need to replace Panasonic NE8070 model, 15in dia,microwave plate
hi my name is mark, i found panasonics part website follow link http://www.pstc.panasonic.com/Epartr/PartsListChoice.asp?validate=1 if this helps please rate how i did. thanks for you question.
Mar 18, 2009 | Microwave Ovens
Oven cooks but turntable will not turn, so it cooks unevenly. How do I reset the keypad so it goes back to normal factory presets, in case I entered something that stops the turntable revolving. Is there...
The manufacturer has set the rotational plate in motion at the same time the microwave tube is energized. They work together as a team. At no time should the plate be idol, unless you remove it completely, and then only the center spindle will turn by itself. It is possible for the rotational spindle in the center of the oven to break, but that is unusual unless some sort of pressure (like stopping it when it was moving) was applied. Also, it has been reported that some individuals tend to put items with too much weight or too large for the oven to manage; thus damaging the rotator. As long as the oven still provides Microwaves to cook your food, it is still OK. Years ago, there were no rotating plates and using the energy was all it took to get the job done. For even cooking, just manually stop the oven at times and turn the food to avoid over heating in one spot.
Jan 14, 2018 | Kenmore 62222 / 62229 1100 Watts Microwave...
Revolving plate no longer rotates . All else works, it continu;es to cook, but we need to move the items of food from time to time
Remove the plate, and check if the square shaped gear that normally spins the turntable is rotating.
If it is rotating, then replace the turntable gear.
If it is not rotating that means that the motor that spins the microwave turntable does not rotate, and must be replaced.
Mar 01, 2009 | Amana Radarange Microwave Oven
Microwave does not heat food placed in the center of the turntable. Leaves a cold spot in the middle of the food.
This is normal. That's why I always recommend to my customers that the food be placed slightly off-center on the turntable. An analogy I refer to is stirring paint: If you stir paint with a stick by simply rotating the stick in the center of the can, it's far less effective than pulling the stick around an imaginary circle halfway bewteen the center and the edge.
Jun 09, 2006 | Whirlpool MH6150XMS Microwave Oven
Microwave Ovens Logo
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
