Question about HP Compaq 6910p Notebook PC PC Notebook
Used my 6910 with battery power. It evetually dies. When I got home I plugged it in and it won't turn on. Took the battery out and it still won't turn on. Get green lighting bolt but won't power up. Help
  • 448 Answers
Disconnect the AC adaptor and remove the battery pack from the computer, then press and hold the power button for 30 seconds.
Second, remove the RAM module, clean the slots then reseat it.
Now, turn on the Computer by connecting the AC adaptor and with the battery out of the Computer.
Posted on Nov 20, 2009
What does error code 6910 mean on canon printer mg5440
Description
A printer error has occurred.
Resolution
  1. Turn off the machine and unplug the power cord from the power supply.
  2. Plug the machine back in and turn the power on.
    NOTE- If you disconnect the power plug, all the faxes stored in the machine's memory are deleted.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility.
Apr 16, 2015 | Canon Office Equipment & Supplies
Why does 2005 Kia Sorento die randomly
I was on vacation in S.C. and engine would die every 20 mins. or so, I took it too dealer and they could find nothing wrong except a bad plug wire periodically wouldn't fire. I said replace it and 3 years later problem is still fixed. Must have caused a glitch with computer.
Jun 06, 2014 | 2005 Kia Sorento
Dodge dakota pickups won't run. cam sensor or pickup sensor?
I would need to know what year and engine size you have.
If you know for a fact you have no spark to the plugs, it could be a relay, a faulty coil, or a sensor. You would check for voltage and a ground signal at the coil first.
Sep 13, 2012 | Dodge Dakota Cars & Trucks
I haven't used my calculator in some time. Now when I go to use it, it won't turn on. I've pressed on and clear and reset. Nothing. It is solared powered and its not like I just change the...
If it is solar powered and hasn't been used in some time, the battery may have died, permanently. If there is no battery to replace then it is broken forever. Sorry.When batteries are left without juice for a long period of time they die, and cannot be recharged.
Sep 14, 2011 | Office Equipment & Supplies
My sidekick will just die or barely run it died
last year, OBD1 car (dumbb ECU)
no scan tools for it
if you run on the road with that hack , and wreck
expect a nice fire. fuel fire.
if you used a voltmeter and say 12vdc there, all hotwiring stuff
need not be done. (
it stalled (misfire)
and then would not what? start but cranks ok?
4wd?
3sp ,4sp auto or 5speed stick
16v engine or 8v, both are G16s but EFI radially different.
16v is MPI with 4 injectors, 8v is 1 injector TBI
try a new
cap,.rotor spark wires and spark plugs yet?
cant burn fuel with bad spark
i guess the cam bent did not slip as it run ok later, but is 60,000 mile belt. and will slip ignored.
next time it stalls
check headlamps they work, and all electric
then see if CEL glows key on, i must or ECU lost power
it has 3 fuse that can rust, IG coil, FI, and DOME.
the CEL must glow, is first checks.
Mar 21, 2017 | 1995 Suzuki Sidekick
I have an 1999 Acura 3.5 RL the power to my car just turns off randomly and resets my time and radio. i checked my battery connections and they are fine. its has happened once while i was driving but...
Had similar problem, went to dealer told battery posts were dirty and loose. Battery was checked and said to be fine. Posts were cleaned and tightened. Next day on way home from work car died. Got a boost from a freind and made it home took out battery went to Autozone and found out battery no good!!!!!!!!!!!! Change your battery that may be the problem.
Mar 18, 2009 | 1999 Acura 3.5RL
My streetpilot c330 won"t shut off.
IT'S CALLED A FROZEN SCREEN...
2 OPTIONS
ONE, RESET IT !!! (See resetting instructions below)
TWO, let the battery die out!
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Mar 12, 2009 | Garmin StreetPilot C330 GPS Receiver
C330 wont turn on or power up
It took a nap...
Jan 22, 2009 | Garmin StreetPilot C330 GPS Receiver
No power from transformer
I had the same thing happen on my original Roady2. I suspect the powerplug port on the Roady2 unit is not getting a good connection. Does the transformer plug have a plastic tip? You can try to cut that off with a sharp razor blade. Sometimes that will make a good tight connection. What I did was buy a used Roady2 unit on ebay. Also another cause is
the power connection is not being made by an internal problem or wear caused by constantly plugging and unplugging the power port. I use a Cambridge XM playdock boombox at home. I bet getting a different unit will solve the problem. The only problem is that finding a used unit might take some work. Good Luck
Oct 27, 2008 | Delphi Roady2 SA10085 XM Radio Receiver...
Street pilot is dead
It took a nap...
Aug 30, 2008 | Garmin StreetPilot C330 GPS Receiver
HP Compaq 6910p Notebook PC PC Notebook Logo
486 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
