Question about Sony Audio Players & Recorders
I have a sony str-d2090 am/fm reciever.what would i compair that model to of todays sony recievers.
5 Suggested Answers
SOURCE: I NEED INSTRUCTIONS ON HOW TO CONNECT ALL COMPONENTS TO THE SONY STR-DE598 RECIEVER
codes for remote
Posted on Dec 23, 2007
welcomejee
  • 10594 Answers
SOURCE: My reciever does not work
Power Amp IC gone in your set, replace it.
Posted on Jul 30, 2008
tns_davao
  • 32 Answers
SOURCE: my reciever sony str-k740p reads (protect) and it
Grounded speaker wire check your lines going to the speakers
Posted on Jul 10, 2009
  • 52 Answers
SOURCE: I HAVE A SONY RECIEVER STR-DH700, I get no sound
make sure the FM antenna is connected and in a good place then check to see if the A-B speaker selector is selected properly.check to see that the sound field is set properly, My 800 allows for several different options and if your speaker wires are reversed or not in the correct position front left at front left etc it will not send the signal to those speakers. try using the TEST TONE feature if you have one it will send a signal to each speaker in sequence (LF< C< RF<in order) it will go all the way around to see if they are connected properly, that way you can tell if they are connected at all or in the wrong spot on the back interface. I dont know if that is what you meant by AUTO CAL, but that is a seperate feature when you use the connected mic to determine range, height and distance to the position in the room you are most likely to be seated for optimal sound.
Posted on Nov 29, 2009
Sony reciever shows protect on display
May be bad connections on the preamp ic's. Otherwise there is a short in the amp that needs to be repaired.
Jan 02, 2013 | Sony Str-d350z, Av Am/fm Reciever, Home...
How do i get my sony DA30ES am -fm reciever out of protector mode
Here is a guide for you: STR DA30ES Protect
let us know how , if you need further assistance.
Jun 09, 2012 | Sony STR-DA30ES Receiver
NEED A USERS MANUAL FOR SONY RECIEVER STR D-1015 . I BOUGHT A USED RECIEVER WITHOUT A MANUAL AND CAN'T FIGURE OUT HOW IT WORKS
Please follow this link for a free download of your receiver manual:
http://safemanuals.com/user-guide-instructions-owner-manual/SONY/STR-D1015-_E
Dec 17, 2009 | Sony Audio Players & Recorders
Nov 29, 2009 | Sony STR-DH700 A/V Receiver
Need unlock code for sony str-dg520 5.1
The HDMI inputs are pass through inputs only. The reciever cannot recieve any sound signals through the HDMI's. The reciever acts as a selector switch for the HDMI inputs only. Whatever input you have selected on the reciever is the one that is being sent through the output to your TV. The "unlock" display shows when there is no sound signal sent to the reciever. There is no code to unlock. This is the reciever's way of telling you that there is no sound being sent to it from that input. Since there is no sound being processed from the HDMI's, you need to hook up an additional audio cable from the device to the reciever (preferrably an optical cable). When the reciever recieves an audio signal, it will then "unlock". I know it is confusing. I had to look into this problem myself, so I'm happy to help. Higher end recievers will actually recieve and process sound signals from the HDMI's. When I bought this one I thought it was going to do the same. That's what I got for trying to save a couple bucks on the cheeper model! Although it is still a good reciever.
Dec 25, 2008 | Sony STR-DG520 Receiver
Sony receiver sound
what is hooked up to the input of the tv/sat inputs?
it may be the recievers input has a component problem or the output device hooked up to the reciever
Nov 06, 2008 | Sony STR-DG800 Receiver
Jul 30, 2008 | Sony STR-DE575 Receiver
Manually tuning the reciever
you should be able to tune in manually.
press tune
press fm or am
press d. tuning
enter the frequency of the station 4 or 5 digits ie 9370 or 10450
another thing to look into would be getting a yagi fm antenna, they are directional and although you may have to rotate it for best results, they work great.
Nov 20, 2007 | Sony STR-DE985 Receiver
492 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
