Question about Bunn VPR Coffee Maker
Poured water into a Bunn Vpr coffee maker, the coffe was cold. Why did this happen?
    President:
  • 1,618 Answers
Possible the hi-limit turned off the heater, the thermostat is not working or the elements are damaged, or the inline thermal fuse is damaged.
Posted on Nov 20, 2009
Bad leaking bunn commerical VPR pour-omatic
You will need to replace it, parts are not made for repair except under warranty.
Nov 30, 2016 | Bunn Coffee Makers & Espresso Machines
Poured water into the Bunn Coffee Maker Reservour is not heating the water.
Maybe this will help you, with information, trouble shooting and contact numbers.
BUNN VPS COFFEE MACHINE MANUAL
http://www.bunn.com/pdfs/commercial/manuals/10053.0000.pdf
Also if you could rate this and some kind words would be great. Also here is my direct link to my pages of expertize that might help you. Visit me anytime at :
http://beta.fixya.com/users/mc1bean
Thanks So Much, Mike
Aug 16, 2011 | Bunn VPR Coffee Maker
What can I clean my Bunn proffessional coffee maker with ?
mcdevito75 here, Contact Bunn for their recommended cleaning material for your coffee maker, or see any large store that carries coffee makers for their cleaning kits.
Jul 11, 2010 | Bunn VPR Coffee Maker
I have a Bunn VPR, it brews fine for a couple pots
Try running a quarter-pot 50/50 solution of white vinegar and cold water through to clean out calcium deposits in the pump system. Use a clean filter to catch the pumped debris. When pumped through, let cool somewhat, and reuse the cold mixture again twice more. Pour out the vinegar solution and run several cold water loads through to wash out the taste. Hope this helps!
May 24, 2010 | Bunn VPR Coffee Maker
When I pour the cold water into container it heats the water but it will not pump the water to the filter. What's wrong?
The machine is a gravity brew, pour in another decanter of water until it drips from the sprayhead, when that happens the boiler is full, wait seven minutes then brew you coffee.
Feb 05, 2010 | Bunn VPR Coffee Maker
Hi! I got a new Bunn VPR last week but did not run water through it because I was waiting for our maintenance guy to install a GTRI outlet for it. When he installed the outlet on Saturday he plugged in...
It sounds as though the thermal cutout has been put to the test and it didn't pass. I would advise you to try to get the company that the repairman works for to replace the entire machine, after all it is brand new and changing parts at this venue could void the warantee.
Sep 22, 2009 | Bunn VPR Coffee Maker
Bunn coffeemaker steaming and bubbling over when OFF
You need to replace the thermostat and the hi limit switch punch up bunnomatic.com and get partsthis machine is good for many years
Jul 22, 2009 | Bunn VPR Coffee Maker
WE have the Bunn VPR series. It's a pourover
Hello this coffee maker has a one and a half gallon internal tank, could be one of a few problems, first thing to check is the spray head, unscrew this you may need some channel locks to get it off and check it..use a tooth pick to clear the 6 holes with any lime that may have formed...also if you use a commercial coffee company for your coffee they should have supplied you with a spring to clean the spray head tube. After checking these 2 items the next thing to check is there enough water in the tank..when the vpr is left on and not used for a few days the water in the tank evaporates..it takes approx two and a half pots of water to fill up the internal tank...try pouring another pot of water in...also turn machine off and take the 2 screws out of the top and see if there is lime blocking the drain hole in the fill pan. Hope this helps...please feel free to comment again if you have any other questions...Good Luck!!! Mike
Jul 14, 2009 | Bunn (VPRBUNN) 12-Cup Coffee Maker
I own a bunn and my brother's business owns 2 of these. The rule of thumb as he was told by the salesman is 2 oz of coffee grinds per 48 oz of water.
Jan 23, 2008 | Bunn VPR Coffee Maker
Bunn VPR Coffee Maker Logo
308 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
