Question about Force 10 Galley Range
I have a new force 10 three burner with oven - I used the broiler and heard a pop - half ay through the meal found a few pieces of gasket compound in my meal. Upon examination of the stove, it seems to be the fillet used between the stainless top of the oven and the ceramic broiler element. Where the broiler element edge meets the stainless top of the oven, the angle at the fillet is 45 degrees. Where it spalled off, it is ninety degrees. What is the material and how toxic. I may have eaten more than I should.
    Top Expert:
  • Force 10 Master
  • 26,089 Answers
You will need to ask the manufacturer as we have no idea but if an item is used in a food preparation device, all materials that are likely to fall or come off must be food grade and non harmful.
Posted on May 18, 2017
Oven made pop noise now won t heat
It sounds like the control board blew out. I have had a couple of these just blow like that lately. The bake and broil wont work. . Check for any bad wiring but the control board is most likely the culprit.
Feb 20, 2014 | Ovens
Broiler shuts off
Make sure you keep the oven door OPEN when using the broiler, otherwise the thermostat will shut it off.
Jan 18, 2013 | Maytag Gemini MGT8655X 30" Freestanding...
Lower oven burner will not light.
Hi I have a older GE that the oven won't light. It is a gas range that is electric ignited. The top burners do work but the oven will not light. Is it pricey to have this fixed?
May 28, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven and broiler will not heat elements have continuity when oven was turned on heard a pop after that the problem started
do you have voltage? you have to have 240 volts if you only have 120 this might happen check your breaker. does your bake element work? if neither bake or broil work always check the breaker first and let me know
May 28, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Whirlpool super capacity 465 oven quit lighting
Check the burner ports near the ignitor for blockage. I had one of these units, and the ignitor was not mounted correctly, and caused a similar problem
May 02, 2009 | Ovens
I have an old (20 years +) Tappanr 4 burner range with a double oven. I am missing the knob for the cleaning cycle but it says it is self cleaning. I need a replacement. I'd also like to find replacement...
chances ar erte hlower oven door , is your broiler, the older models didnt have a seperate broiler inside oven, rather they used 1 burner bar ,and depending on wher oyu place the food you would either bake(above) or broil( under) made sense, just pain in the rear to bend down to use it. as far a knob and gasket , perhaps you can find a model number under the main top assy so we can look up for you
Mar 07, 2009 | Tappan MPF500PBW Gas Kitchen Range
Hole in Bake Tube Kenmore oven....
heres the apart nuber forthe burner bar, the unfortunate thing for you is that the new burner bar comes with the ignitor already attached ,no worries hold on to either the one becauseit will go bad again. but no real trick to it 1 or 2 screws holds in place no gaskets or seals WB16K10035
Jan 20, 2009 | Ovens
I have a double gas oven and no instructions
I have an O'Keefe & Merritt double oven gas stove. The model number is 72 7242 23. The upper oven is about the size of a large microwave and sits above the range burners. The lower (full-size) oven is below the burner unit and includes a broiler draw below it.
So, when you say, double oven, I wonder if you are just talking about the main oven with broiler drawer (both of which are below the burner unit.)
Mine was a builder-supplied appliance in the new house we purchased in 1986. The upper oven has never performed very well. And, yes the upper oven can only be used for baking.
I have an instruction manual for it, but it doesn't provide that much information. Getting parts for it is extremely difficult, since Tappan is no longer manufacturing this brand. (I've been trying to locate a flat oven ignitor for the upper oven and can't seem to find a replacement that's the same 6-1/3" length.) In the 1980s Tappan apparently purchased O'Keefe & Merritt and marketed this brand for several years. Models originally manufactured by O'Keefe & Merritt in the 1930s-1950s are considered collectible antique stoves!
If you want to email me, I'm at oldvic@erols.com
Apr 20, 2008 | Stoves Premier 900GRa Gas Double Oven
Convert from natural gas to propane
Step 6:
To prepare the new unit for LP gas you need to adjust several items. First you will need to replace the range orifices or spuds. These are individually sized with marks and colors.
remove_spud-s.jpg Step 7:
Using a nut driver, loosen the old spud and replace with the new one.The trick to keeping from dropping the spud down inside the range is to use a small piece of aluminum foil between the driver and the spud. This should provide enough "grip".
If you do drop one down inside, you'll need torx wrenches to disassemble the burner units and get inside.
orafice_setting-s.jpg Step 8:
tighten_orifica_on_broiler-s.jpgThe oven orifices need to be adjusted. Using an open-end wrench, tighten down the brass fitting on the oven burner valve.
Step 9:
There may be two orifices, one for the broiler and one for the main oven burner.
reverse_for_lp.2.jpg Step 10:
You will need to reverse the plastic pin in the regulator underneath the range. Remove the hex nut and flip the plastic pin and reassemble the nut.
Do not over tighten!
The last step is to open the air shutters on each burner as per directions included with the range conversion kit.
Nov 07, 2007 | GE Profile JGSP44 Dual Fuel (Electric and...
Force 10 Galley   Range Logo
88 people viewed this question
Top Force 10 Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Force 10 Kitchen Range Expert? Answer questions, earn points and help others
