Question about KitchenAid KEMC377K Convection / Microwave Oven
My Kitchenaid Superba kaw38avm726 microwave does not heat
My Kitchenaid Superba kaw38avm726 microwave does not always heat. First use, yes, use again immediately and it won't heat. Wait 15 minutes and it heats. Repeats this over and over.
  • KitchenAid Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
dhjjd
Posted on Sep 30, 2010
UNIT HAS A BD MAG TUBE. IT GETS HOT AND SHUTS OFF THE THERMAL FUSE MOUNTED ON YHE MAG TUBE. I BELIEVWE THAT IF YOU REPLACE THE MAGNETRON YOU WILL CORRECT THIS PROBLEM.
Posted on Dec 16, 2013
Something dripped between the slots on the top edge of the oven door. The drip went down between the glass. How do you clean the glass when its between the two? Please advise.
Posted on Dec 26, 2012
  • MICHAEL DEVENEY
    MICHAEL DEVENEY Dec 16, 2013
    only way to clean this is to disassemble the door. check for process on you tube.
Where can I find out the wattage of my Kitchenaid Superba 853879154001 Combination Microwave? It is not on the door sticker.
Sarah,
That model number is not coming up as a good number, but another model that I looked at said that particular model was a 900 watt microwave.
Aug 08, 2015 | KitchenAid Microwave Ovens
Kitchenaide Superba #4450786A unit turns on but will not heat at any setting. What can I do to fix?
Magnetron needs replaced.
CAUTION: Your microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. We strongly suggest you seek the assistance of an appliance repair technician when conducting any microwave oven repair.
Cheaper to buy a new Microwave oven.
Jul 11, 2014 | KitchenAid KCMS185J Microwave Oven
Kitchenaid Superba KEMS307D Microwave buzzes, looks like it works, but doesn't heat. Full normal display, tray rotates, but fan doesn't sound normal.
Most likely causes - shorted high voltage rectifier, or failed high voltage transformer, or shorted high voltage capacitor, or shorted magnetron. If an odor accompanied the failure, high voltage rectifier or transformer most likely. All of these components operate on 4000 v, or more - with enough current to kill you. Make sure the unit is unplugged, and the high voltage capacitor is fully discharged before testing.
Apr 10, 2014 | KitchenAid Microwave Ovens
Kitchenaid Superba range oven will not ignite
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Apr 26, 2011 | KitchenAid Microwave Ovens
Kitchen aid Superba Microwave/convection built in above over. Need to change light bulb. what do I have to remove to pull micro out to change light bulb. model KAW38AVM726
Usually removing the appliance from the mains supply and taking the case off will reveal where the lamp is and depending whether it is an ES or Lucar fitting will depend on how tp remove it.
It is quite straight forward.
Replace the lamp with an identical lamp.
Hope that helps.
Dec 09, 2010 | Microwave Ovens
The burners on the kitchen aid superba range work, but the oven doesn't?
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Aug 19, 2010 | KitchenAid Microwave Ovens
Kitchenaid superba combo. Microwave gives
HI, this is an indication of a failed door switch. When the switch fails, the control cannot recognize the closed door signal. Simply replacing the door latch mechanism will solve this issue.
Replace the door latch assembly, asap.
Dec 22, 2009 | KitchenAid Microwave Ovens
I have a KitchenAid Microwave that the tension spring is broke. I need to order a replacement part. The model is KAW38AVM726. I have seen the same model number on your website, but it seems the model...
That model number does not look right. Please check the tag on or in the unit again.
You can find helpful exploded view diagrams and order parts here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you should be able to download it here.
The door springs must be replaced in pairs to keep the wear even.
Dec 12, 2009 | KitchenAid KEMC377K Convection / Microwave...
KitchenAid Superba Microwave/Oven, Microway Door message
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you only need a switch, you can order one from us for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Sep 22, 2008 | KitchenAid KEMC377K Convection / Microwave...
KitchenAid KEMC377K Convection / Microwave Oven Logo
2,193 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Stu Ungar
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
