Question about HP Pavilion TX2000Z Notebook
My laptop wont turn on completely. All the lights are on. When I turn it on I get the black screen and I pick start windows normally and then enter my passowrd, But then the windows welcome screen is on for a very long time. I;ve left it on for an hour. It wont go past that. Ive also started on safe mode but there is nothing there just a black screen. Any advice?
  • 3 more comments
  • veena_vd Nov 20, 2009
    No, I don't...
    What if it says restore to a previous date...It doesn't give me options like that. It just says restore to factory defalts. I clicked on advanced options and get another sub-menu.. what should I pick from that?
    I just picked create a back-up and am backing up my files. Could you also help me withi how to access my pictures and documents (I am a student with a lot of assignments on here) from the back up.
    To an external harddrive
  • veena_vd Nov 21, 2009
    First, I'd just like to thank you for helping.
    I have access to another computer and took a look at what backed up and the file type is an application
    (.exe) named backup.1.
    G:\MINWINPC\Backup Files 2009-11-20 020511 is the exact location...and description is RestoreWiz Application.
    I am a little hesistant to run the application because its not my computer... Its another students'. If I run what will happen? Would it affect the users computer? How would I get my files from this type of file? Thanks
  • joecoolvette
    joecoolvette May 11, 2010
    Do you have the Restoration CD disk? Post back if you do, or don't.
  • HP Master
  • 5,660 Answers
Then there are two ways to restore your computer.
1.On the harddrive of your HP Pavilion TX2000Z laptop are restoration files.
They are on a separate partition on the harddrive.
(If I may,....Partition. Think of a house. Now partition it into two rooms by putting a wall in the middle. Each room is then a Partition. The harddrive is divided so there are Two Partitions)
These are accessed by the user by,
A.Laptop off. Press the Power On button. Start tapping the F11 key as SOON, as you see - Press <F11> for recovery
(Bottom of the LCD screen)
B.Select (Click on), Recovery Manager. When Recovery Manager opens....
C.Click on Advanced Options
D.Click on System Recovery, then click on Next.
E.Follow the On Screen instructions.
If it asks if you wish to do a Destructive Recovery, or a Full Install, I advise DON'T.
It means the laptop will be recovered back to Square 1. Back to the day it came from the factory.
This means any personal information you have on the computer is GONE!
No pictures, videos, music, downloaded programs, and applications, or programs, and applications installed by you. No Documents you have generated will be saved.
If it wasn't there when the laptop came from the factory, it will be GONE!
If it asks you if you wish to do a Non-Destructive Repair, or just Repair, I advise using this.
Your personal information is saved.
All that happens is that basic Windows files are repaired.
2.Obtain the Recovery Disk/s from HP
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00810334&lc=en&dlc=en&cc=us&product=3650978&lang=en
Posted on Nov 20, 2009
  • 1 more comment
  • joecoolvette
    joecoolvette Nov 20, 2009
    Where are you backing up to? Are you backing up to a DVD, USB thumb drive, or just to the laptop harddrive itself?
  • joecoolvette
    joecoolvette Nov 21, 2009
    External harddrive? Do you have access to another computer with Windows?
    Computer on, Windows loaded. Click on Start>My Computer. Familiarize yourself with the Drive letters.
    (C:) drive is the Harddrive
    (D:) drive can be a partition on the Harddrive, or it may be the CD/DVD drive.
    (E:) drive, usually reserved for a CD/DVD drive.
    (F:), (G), and (H:) are usually reserved for a removable drive. Such as a USB thumb drive, card reader, or external harddrive for example.
    The reason I am having you look before you plug the external harddrive in, is so you will recognize when there is a difference. When a drive letter has recognized a removable drive, that has been plugged in.
    Sometimes when you plug an external harddrive in, it is recognized. Sometimes not.
    If you Double-click on the Drive Letter, that corresponds with the external harddrive you have plugged in, it will open the external harddrive, and you will have access to it's contents. Forces the computer to recognize the external harddrive.
    My reasoning for using another computer to access those personal files?
    You indicated you are a student with a lot of assignments saved, plus photos you want/need to save.
    My thoughts are to burn these personal documents off to disk/s. Less chance of something happening to this valuable information. More ability to organize the files in a logical order to access files.
    Not only is your personal information saved on that external harddrive, but also Windows basic files.
    In the case that it is not a hardware issue with your laptop, and may be a software issue, (Such as corrupted Windows files, and if you'll excuse me, I'm not a fan of Vista. Too many users with too many problems), then you'll have the personal documents saved.
    Should you decide to restore your Pavilion TX2000 laptop, and something goes wrong, your documents are safe, burned onto a disk, (Or disks), or removable media.
    Rarely anything bad happens with a disk, compared to a thumb drive, external harddrive, or other removable media.
    If you do not have access to another computer, and/or wish to use the backup to restore your laptop;
    Plug the external harddrive into any available USB port on the laptop. Press the Power On button.
    Follow the instructions.
    Problems? Tell me what you see. I need what you see, so I can guide you.
    If it's, Restore with a Backup Copy to your Harddrive, yes, this is what you want.
    If you have burned off your personal documents to removable media, (Such as CD/DVD disks, USB thumb drive/s, etc.), then choose - Restore to factory defaults.
    Your laptop will be as it came from the factory. Plain Jane.
    Then you can install the documents you want back onto the laptop.
    If the laptop has a hardware problem such as a harddrive with bad sectors, or other hardware issues, you will still have your personal information saved on that removable media.
  • joecoolvette
    veena_vd I would advise at this time that you go back to your laptop, and plug the external harddrive in. Then turn the laptop on. Advise me as to what happens.
    (NO, DO NOT open this file on the other students computer. Please do the above)
  • 448 Answers
Disconnect all the peripheral components from the Computer including the AC Adaptor and remove the Battery pack.
Then remove the RAM, clean the RAM slots and reinstall it.
Next, connect the AC Adaptor to the Computer and boot it into the BIOS and reset the BIOS to its default settings.
Then, turn on the Computer to boot it into Windows.
Start up problem
Sounds like you need to do a complete system reinstall or bring it in to a repair shop and have them see if they can fix it for you.
Jun 25, 2012 | Acer TravelMate 220 Series Laptop Charger...
Windows not starting. everytime i started it it goes to safe mode and say windows did not start. it wont let do anything \.
I suggest you to try Last known good configuration.
Follow the steps below,
Step 1: Shut down your PC completely.
Step 2: Turn on the Power button.
Step 3: As soon as you turn it on start hitting the F8 key on your keyboard until you get to a black screen called "Windows Advanced option". (If you don't get to that that screen but you end up reaching the blue screen than that means you have delayed in hitting the F8 key. start again from step 1.)
Step 4: As soon as you reach "Windows Advanced option" use your down arrow keys to choose an option called "Last know good configuration".
Step 5: Select that and HIT ENTER.
Dec 22, 2010 | Compaq Armada M700 Notebook
Gateway MT6707 Laptop...Will not boot. I get an error at start up to "fix problems or Start Windows Normally........I have tried both. Just gets to the screen That shows Gateway and Please...
You need to launch the Last know good configuration to get this fixed.
Step 6: your PC will boot to the windows.
Dec 19, 2010 | Gateway MT6707 Notebook PC
My dell insprion 1520 wont go past boot screen it stars then goes to a black screen that says start up repair or start windows normally but when i click star up repair nothing happens then i pick start...
Place your windows cd/dvd in the tray and boot to the cd. When asked if you want to install windows, there will be a repair option further down towards teh bottom, or you will be asked to click R like before. The repair only works if the cd is in the tray.
Aug 26, 2010 | Gateway 7325GZ Notebook
I have a Presario C500 Compaq laptop
when upower up press F8 key then enter in enable vga mode.
then set screeen resolution to 1024*768
and if u r not abled to login enable vga then enter in safe mode.
then go to start menu run then type in run "chkdsk /r"
thats it
then restart it then it fix error on hardddisk.
Jun 08, 2009 | HP Compaq Presario C500t Notebook
Windows vista wont start
Ok,Try safe mode with command prompt,If you can get to the command prompt
Type these in one at a time and press enter ( let each one completely finish before typing the next one.)
Bootsect.exe /NT60 c:
Bootrec.exe /FixMbr
Bootrec.exe /FixBoot
Bootrec.exe /ScanOs
Bootrec.exe /RebuildBcd
bcdedit.exe /import C:\Boot\BCDBackup
May 21, 2009 | Toshiba Satellite A135-S2276 Notebook
My computer starts up perfectly fine, i click the " start windows normally" button, and it loads. Then after loading the screen turns black ( I can still see the LED light and cursor) PLEASE HELP!
When it ask you how you want to start the computer the select Last known Good Configuration. It should boot up normally.
Then go o the control Panel - System - Hardware - Device Manager and check for any devices that didn't install (the ones with the yellow ?)
You will need to reinstall these drivers.
Apr 18, 2009 | Compaq Presario PCCOM2232US Notebook
Computer keeps resetting
this blus screen you speak of wouldnt happen to have a fatal error screen would it? you would be able to tell if there is a bunch of text on the screen.
unfortunately though, it sounds like you have a virus that has affected the boot sector of your system. the best way to ensure that the problem is solved is to format your drive and create a new partition.
if there is info you are needing to save you can try a data recovery program that runs without the use of the hard drive, like the one here, http://download2.lsoft.net/BootDiskDemo-Setup.exe
this is a great tool since it boot from the disk you creat instead of your hard drive. from here you can save any docs or info to an alternative storafe device before formating.
use this tool and allow it to run a complete check and get back with the results
good luck!
Mar 11, 2009 | Microsoft Windows XP Professional
Lap top wont boot up past the windows screen
This generally indicates that a sector in the hard drive has failed, and the hard drive will need to be replaced. With a bad sector the drive reads to the point of the bad sector and past the bad sector, but can't put the info together, so it tries to boot, but can't. Unfortunately, your only option is replacing the hard drive.
Aug 01, 2008 | HP Computers & Internet
HP Pavilion TX2000Z Notebook Logo
384 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
